    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.8k Views 109 Watching
    • tt_suT Offline
      tt_su
      Some times? Not consistently?
      Do you use the META tag to force embedded IE to use the actual IE IE render engine? Embedded IE is more conservative and it uses an older render mode even if you have a standard doctype. See the Lost Manual for more details: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki/Doctype---Quirks-vs-Standard-vs-Superstandard
      I also think that in one of the recent SU versions there was a registry setting set that would bump up this doc type one version (and that would affect older SU versions on the same machine.) So that might be the reason to why you get seemingly random reports of this. It might be they have versions that trigger the IE7 mode.
      By the way, should you not be detecting older versions as well, not just IE7?
      <!--[if lte IE 7]> <![endif]-->
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        That's interesting.
        But how can we force the last version ? Let's say I put <meta http-equiv="X-UA-Compatible" content="IE=10"/>, how will IE8 behave with this ?
        Of course I do πŸ˜‰ , I just display different things depending on the version, so I have two of these.
        • tt_suT Offline
          tt_su
          @jiminy-billy-bob said:
          That's interesting.
          It will use the newest it can - IE8.
          I'd recommend you set it to: <meta http-equiv="X-UA-Compatible" content="IE=edge"/> - it will then always pick the latest mode available. Like a normal browser would do. (See example in the SKUI project: https://github.com/thomthom/SKUI/blob/master/src/SKUI/html/window.html#L4)
            jiminy-billy-bob
            Ok thanks ! πŸ˜„
            • H Offline
              huckrorick
              any progress on not updating scenes and changing layers activated in a scene?
                monmonred
                just thank you. jiminy-billy-bob! are you working on the option to hide/show multiple layers at a time? can this also have a hotkey?
                brilliant work!
                +Greatness may be measured on how much we have lost for the betterment of mankind+
                • Bob JamesB Offline
                  Bob James
                  New version 0.7 beta !
                  Changelog :
                  • Added a dark bar at the top to minimize/maximize the dialog
                  • Added CTRL+G : Group selected layers
                  • Added CTRL+SHIFT+G : Ungroup layers
                  • Added CTRL+A : Select all
                  • Added CTRL+E : Merge selected layers
                  • Added different color for groups
                  • Layer0 is now selectable
                  • Fix bug with sorted groups
                  • Potential fix for IE version bug
                  Super improvements - have made a donation
                    jiminy-billy-bob
                    Did you miss version 0.6 ? πŸ˜‰
                    New version 0.6 beta !
                    • Fix scene auto-update (This is now an option)
                    If was trying to find a good way to do this. Hotkeys are a good idea, thanks.
                    Thanks a lot Bob !
                    • Rich O BrienR Online
                      Hi Thomas,
                      I get this consistently in SU8...
                      ...not on SU2013
                        jiminy-billy-bob
                        I had this as well when trying to update it from the pluginstore inside SU8.
                        (I use SU8 to check everything is right after an update)
                        I deleted Layers Panel in the plugin folder and installed it again from the PS. Works fine... I thought it was a permission issue, but maybe the fact that you have it proves it's something else ?
                        I already had this kind of problem in the past, with files not being properly replaced during an update with the PS.
                          If you have changed a script file etc then it might be advisable to popup a warning to tell the user to restart SketchUp to effect the changes - depends on how the menus/toolbars etc are written.
                          BUT if you have a file that is still loading that shouldn't be - e.g. you have replaced it with a new file [with a different name] BUT that older now-not-needed legacy-file is left behind and is loaded/going-to-load-next-time, then your code really needs to do its own tidying up and delete these legacy-files as it itself loads; AND if so; then warn the user to restart SketchUp to effect all of the changes...
                            jiminy-billy-bob
                            Nope, no new file, just updated ones. And restarting SU does not solve this...
                              YEs, I restarted 6 times and still error occured.
                              I needed to remove and install fresh.
                              But there is something funky going on with Layers Panel for me for a while. It needs gets listed as needing an update in My Plugins and I could never figure out why.
                              Great plugin BTW. I ain't knocking it just doing some investigation while I have some time
                                If you manually remove all of the plugin's subfolder-of-support files and the lone loader .rb... then re-auto-install it is there still the error ?
                                If so something is wrong in the files/archives - the error message tells you that some js code is adrift ??
                                Your newly install script needs to tidy up after itself IF there are file changes...
                                πŸ’­
                                As a 'trusted author'... Are you really sure that you are properly making the two files needed for inclusion in the PluginStore database - the RBZ for the page and then the 'second-format' needed for the in-SketchUp dialog etc ??
                                What ZIP program are you using to make the ZIP you are renaming as RBZ ?
                                Are you using definitely v8 to process the RBZ into the 'second-format' and NOT v2013 ? OR if it has to be made in v2013 are you remembering to do a Save_as to v8, to keep it compatible with earlier versions...
                                I suspect this might be the core issue - i.e. archives from an author who fails to provide the dialog-version in the required v8 compatible format ! The server-side database built-in version-checker for the 'second-format' ought to trap this, so it is disallowed... but it might be failing ??
                                GΓ‘bor πŸ˜’
                                Comments need asap - an author should NOT be able to upload incorrectly versioned 'second-format' archives to the PluginStore - they must all be v8.
                                Please all reread the Author's Guide sticky in the special forum if you are in any doubt as to what you must do...
                                  jiminy-billy-bob
                                  Nope, no error after a clean install.
                                  In this case it's JS, but some time ago I had the same issue with the main CSS file.
                                  How can I detect it has been updated ?
                                  Yes
                                  Windows Explorer
                                  Yes
                                    You don't need to detect if a file has been updated.
                                    All files in the RBZ or second-format are extract and overwrite any preexisting files.
                                    The problem comes if you have some files from an older version that are not included in the newest installation.
                                    Now they a left behind in the subfolder and might still load if you globally 'require' or 'load' files, or the html etc is still referring to them [you might have removed them but the user hasn't] - iin that case adjust the current code too.
                                    If you know that some files are obsolete then your loader rb file' code needs to check for their existence - make an array of their subfolder_location/names: then use:
                                    File.exist?(obsolete_file)
                                    If it does then
                                    File.delete(obsolete_file)
                                    AND increment a counter.
                                    If the counter!=0 then you need to popup a message that old-legacy files have been deleted and SketchUp needs to restart to complete the new installation. Otherwise the older files code is still loaded and will often break your new installation OR SketchUp itself...
                                      Bob James
                                      I had the same problem(s). Turns out that the new version is called jb_layers_panel and jb_layers_panel.rb whereas the previous version did not have the "jb".
                                      I unloaded the new version, deleted the old version, and restarted SU.
                                      SU immediately crashed 😲
                                      Restarted SU and loaded in a model.
                                      Worked okay except
                                      1. The saved options where not in effect.
                                      2. Still got the unexpected ')' error and had to click four times "yes" before it went away. When I did that the saved options took effect.
                                      I tried it the other way around: loaded SU (no error), then opened a model. The Layers Panel filled out but the options were wrong and I got the error message and had to click yes four times to make it go away.
                                      It clearly has something to do with the options.
                                      I could implement all of the new functions.
                                      I can resize the dialog, but "Added a dark bar at the top to minimize/maximize the dialog" is not there
                                        Bob James
                                        If you click Ctrl-Z while in the panel you get the same error
                                          In that case == BIG mess up.
                                          If you have 'layer_panel' as your plugin name and others have installed it before then issuing a new version called 'jbb_layer_panel' is regarded as another tool.
                                          ALL of the legacy files for the old version continue to load their old code in tandem with you new version - causing inevitable clashes when similar module/methods are called...
                                          When you decide to rename a plugin it cannot be entered into lightly.
                                          Your new version must find and delete all earlier versions that are using the older name, these will NOT get overwritten by an auto-install and load and mess things up...
                                          Also consider that an .rb file in the Plugins folder might have been 'managed' or 'uninstalled' so you need to look for say layer_panel.rb and layer_panel.rb! and layer_panel.rbx files in case they exist !!!
                                          The files in the 'layer_panel' subfolder need deleting and then the folder removing, you cannot [easily] delete a folder that currently contains files...
                                          If this is the cause of this issue I suggest you immediately 'unpublish' the plugin and we agree a strategy for a new version to correct the legacy issue files/folder, and advise current users to at least disable ALL versions they have installed. πŸ˜’
                                            Bob James
                                            Thank you! But the difference in the light grays is not very discernible.
                                            If you move a group with all the layers showing, after moving the layers are no longer showing, but the arrow is still down. You have to click on the down arrow (which opens up the layers) and then click the arrow again to collapse the layers.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
