    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 73.5k Views 31 Watching
    • guanjinG Offline
      guanjin
      @renderiza said:
      Very happy to see everyone is comments thank you! ๐Ÿ’š
      Thank you for your hard work ๐Ÿ˜
      • halroachH Offline
        halroach
        Another suggestion. a toggle to be able to orient the component to the surface it is being dropped on, Or the ability to maintain it's "glueing" properties that were set upon the component's creation.
        FlexTools - Super Quick Windows, Doors, Slats...
        • O Offline
          orchard collie
          Hi Renderiza
          Have just installed Canvas 1.1.3 on MacBOok Pro and can't seem to make it work. It loads the Dialog Box but there are no parameters or any of the other features you talked about in your video. Am I doing something wrong, or is Canvas only for Windows. If so - Please make a Mac version it looks such a fantastic plugin.
          Tried Component Spray and couldn't make it work either
          Any ideas?
          I would love to get it up and running as I have a tree covered island to vegetate with 1000 trees or more!
          Cheers
          Orchard from Darwin
          • renderizaR Offline
            renderiza
            That would be very good addition to the plugin indeed, it will eventually be on my to do list. ๐Ÿ‘
            @orchard collie said:
            Any ideas?
            Do you have internet explorer 9 or higher installed?
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            • O Offline
              orchard collie
              HI Renderiza
              There is no IE for Mac. Best I could do was change agent in Safari to IE9. downloaded plugin again - can get at all the settings, but it just doesn't copy anything. Selected object is a Component by the way.
              Cursor changes to a small hollow red square but nothing happens on mouse click
              Any more ideas?
              Orchard
                renderiza
                Any more ideas?
                Verify every option under 'Only Add On' menu is unchecked and see if it works.
                If not please open 'window>Ruby Console' and then try to run the plugin to check if any errors show up in Ruby Console. If you see something please let me know what it says.
                Can you put it to IE 10 instead?
                • O Offline
                  orchard collie
                  Hi Renderiza
                  Tried 'nothing selected' in Only Add On Menu - no difference still little red square
                  Ran Ruby Console by typing "load 'plugins/RND_Canvas.rb'"
                  Hit Return key and it wrote
                  load 'plugins/RND_Canvas.rb" underneath on line 2
                  Nothing else happened.
                  PS never opened Ruby Console before so am a total newbie
                  Regards
                  Orchard
                  • O Offline
                    orchard collie
                    Hi Renderiza
                    Me again
                    Just noticed your comment on switching to IE 10
                    The latest version of Safari doesn't go higher than IE9 I'm afraid
                    Orchard
                      renderiza
                      Uploaded a modified Canvas plugin to PluginStore, please re-download it again to see if it solved the problem.
                      What I changed was a line in html document...
                      From
                      <meta http-equiv="X-UA-Compatible" content="IE=10">
                      To
                      <meta http-equiv="X-UA-Compatible" content="IE=9">
                      Hope this solves it. ๐Ÿ˜•
                      Also what version of SketchUp are you using?
                      • O Offline
                        orchard collie
                        Hi Renderiza
                        I'm afraid that didn't work. Still the little red square and no duplication.
                        I did uninstall the old version before downloading the new one.
                        Tech info
                        MacBook Pro 2.3 GHz Intel Core i7
                        4 GB 1600 MHz DDR3
                        Mac OS 10.8.5
                        SketchUp Pro 2013 V 13.0.4811
                        Hope this helps
                        Orchard
                          renderiza
                          Can you right click on SketchUp 2013 icon and click 'Run as administrator' to see if that solves it.
                          If not here is an attachment with older version of Canvas (1.1.0) which doesn't need IE9 for HTML5 & jQuery compatibility.
                          Older version of Canvas that doesn't need IE9 or higher.
                          How to Install RBZ...
                          • O Offline
                            orchard collie
                            Hi Renderiza
                            Sorry it's taken time to get back to you
                            Eventually loaded 1.1.0 (neat interface BTW
                            Unfortunately still doesn't run on Mac just the empty red square attached to the arrow cursor.
                            Have any other Mac Users encountered problems that you know of?
                            I'd love to make it work
                            There''s nothing else like it
                            Here's hoping
                            Cheers
                            Orchard
                              renderiza
                              We need another Mac user for testing if this plugin works or not. Wish I had one myself to test my plugins before releasing them. ๐Ÿ˜•
                              Can you verify if your folder permission are set to full?
                              Also can you try Thomthom: VirtualStore Check v1.1.0 to check if there's files in the Plugins folder that's ended up in Window's VirtualStore.
                              • O Offline
                                orchard collie
                                Hi Renderiza
                                I can't believe I'm the only Mac User of your plugin!
                                There must be more out there. I think the concept is fantastic. I just wish I knew what the problem is.
                                There is of course no Windows Virtual Store on Mac and I have full permission on all files, folders and applications
                                Here's hoping we find an answer
                                Cheers
                                Orchard
                                  renderiza
                                  ๐Ÿ˜ข
                                  Do you have the same issue on all of my plugins? Maybe we can learn something if you test them as well. ๐Ÿ˜‰
                                  • EdsonE Offline
                                    Edson
                                    I am a mac user who is also having problems with canvas, it just does not work for me. I tried with groups and components. I am only able to select the options on the input box after hitting the space key but that does have any consequence: I just cannot place a single instance of the selected group/component.
                                    mac os 10.8.5 and sketchup 13.0.4811.
                                    edson mahfuz, architect| porto alegre โ€ข brasil
                                    http://www.mahfuz.arq.br
                                    • E Offline
                                      energywebb
                                      HI
                                      I am on a Mac, and Canvas is not working for me at all.. neither the 1.1.3 nor the v.1.1.0 which you uploaded on this forum. Neither in sketchup 2013 nor sketchup 8 ... a great shame!
                                      any help appreciated
                                      thanks
                                      • romboutR Offline
                                        rombout
                                        Is there any news or updates on getting this to work on mac. Is it just the issue with canvas not running on mac, cause canvas is supported by chrome and safari. Isnt it cause the header of the html page states content"IE=10", i did try to set this to chrome=1 but didnt help
                                        edit
                                        i just noticed that version 1.1 does give me some feedback in the ruby console
                                        `onLButtonDown'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/RND_Canvas/RND_Canvas_loader.rb;390
                                        Error; #<NoMethodError; undefined method `material' for nil;NilClass>
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/RND_Canvas/RND_Canvas_loader.rb;390;in `onLButtonDown'
                                          driven
                                          @rombout said:
                                          Is it just the issue with canvas not running on mac,...
                                          the plugin dosen't use the <canvas> tag and the html works fine in safari, the problem lays elsewhere...
                                          look in the ruby for PC only calls...
                                          • soloS Offline
                                            I cannot seem to get this to work with SU 2014 or 2015.
                                            All installs correct, dialogue box and toolbar appear yet cannot select anything.
                                            Anyone?
                                            • 4 / 5
