    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 83.7k Views 31 Watching
    • Z
      Zacchia
      Thank you for it!
      • JQLJ
        JQL
        Hi Renderiza,
        Excellent Plugin, beautifully excecuted, with a great visual appearence and a perfect video tutorial!
        What more could one wish for?
        Congratulations and thanks!
        JQL
        www.casca.pt
        Visit us on facebook!
        • renderizaR
          renderiza
          Very happy to see everyone is comments thank you! πŸ’š
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • guanjinG
            guanjin
            Thank you for your hard work 😍
            • halroachH
              halroach
              Another suggestion. a toggle to be able to orient the component to the surface it is being dropped on, Or the ability to maintain it's "glueing" properties that were set upon the component's creation.
              FlexTools - Super Quick Windows, Doors, Slats...
              • O
                orchard collie
                Hi Renderiza
                Have just installed Canvas 1.1.3 on MacBOok Pro and can't seem to make it work. It loads the Dialog Box but there are no parameters or any of the other features you talked about in your video. Am I doing something wrong, or is Canvas only for Windows. If so - Please make a Mac version it looks such a fantastic plugin.
                Tried Component Spray and couldn't make it work either
                Any ideas?
                I would love to get it up and running as I have a tree covered island to vegetate with 1000 trees or more!
                Cheers
                Orchard from Darwin
                • renderizaR
                  renderiza
                  That would be very good addition to the plugin indeed, it will eventually be on my to do list. πŸ‘
                  @orchard collie said:
                  Any ideas?
                  Do you have internet explorer 9 or higher installed?
                  • O
                    orchard collie
                    HI Renderiza
                    There is no IE for Mac. Best I could do was change agent in Safari to IE9. downloaded plugin again - can get at all the settings, but it just doesn't copy anything. Selected object is a Component by the way.
                    Cursor changes to a small hollow red square but nothing happens on mouse click
                    Any more ideas?
                    Orchard
                    • renderizaR
                      renderiza
                      Any more ideas?
                      Verify every option under 'Only Add On' menu is unchecked and see if it works.
                      If not please open 'window>Ruby Console' and then try to run the plugin to check if any errors show up in Ruby Console. If you see something please let me know what it says.
                      Can you put it to IE 10 instead?
                      • O
                        orchard collie
                        Hi Renderiza
                        Tried 'nothing selected' in Only Add On Menu - no difference still little red square
                        Ran Ruby Console by typing "load 'plugins/RND_Canvas.rb'"
                        Hit Return key and it wrote
                        load 'plugins/RND_Canvas.rb" underneath on line 2
                        Nothing else happened.
                        PS never opened Ruby Console before so am a total newbie
                        Regards
                        Orchard
                        • O
                          orchard collie
                          Hi Renderiza
                          Me again
                          Just noticed your comment on switching to IE 10
                          The latest version of Safari doesn't go higher than IE9 I'm afraid
                          Orchard
                          • renderizaR
                            renderiza
                            Uploaded a modified Canvas plugin to PluginStore, please re-download it again to see if it solved the problem.
                            What I changed was a line in html document...
                            From
                            <meta http-equiv="X-UA-Compatible" content="IE=10">
                            To
                            <meta http-equiv="X-UA-Compatible" content="IE=9">
                            Hope this solves it. πŸ˜•
                            Also what version of SketchUp are you using?
                            • O
                              orchard collie
                              Hi Renderiza
                              I'm afraid that didn't work. Still the little red square and no duplication.
                              I did uninstall the old version before downloading the new one.
                              Tech info
                              MacBook Pro 2.3 GHz Intel Core i7
                              4 GB 1600 MHz DDR3
                              Mac OS 10.8.5
                              SketchUp Pro 2013 V 13.0.4811
                              Hope this helps
                              Orchard
                              • renderizaR
                                renderiza
                                Can you right click on SketchUp 2013 icon and click 'Run as administrator' to see if that solves it.
                                If not here is an attachment with older version of Canvas (1.1.0) which doesn't need IE9 for HTML5 & jQuery compatibility.
                                Older version of Canvas that doesn't need IE9 or higher.
                                How to Install RBZ...
                                • O
                                  orchard collie
                                  Hi Renderiza
                                  Sorry it's taken time to get back to you
                                  Eventually loaded 1.1.0 (neat interface BTW
                                  Unfortunately still doesn't run on Mac just the empty red square attached to the arrow cursor.
                                  Have any other Mac Users encountered problems that you know of?
                                  I'd love to make it work
                                  There''s nothing else like it
                                  Here's hoping
                                  Cheers
                                  Orchard
                                  • renderizaR
                                    renderiza
                                    We need another Mac user for testing if this plugin works or not. Wish I had one myself to test my plugins before releasing them. πŸ˜•
                                    Can you verify if your folder permission are set to full?
                                    Also can you try Thomthom: VirtualStore Check v1.1.0 to check if there's files in the Plugins folder that's ended up in Window's VirtualStore.
                                    • O
                                      orchard collie
                                      Hi Renderiza
                                      I can't believe I'm the only Mac User of your plugin!
                                      There must be more out there. I think the concept is fantastic. I just wish I knew what the problem is.
                                      There is of course no Windows Virtual Store on Mac and I have full permission on all files, folders and applications
                                      Here's hoping we find an answer
                                      Cheers
                                      Orchard
                                      • renderizaR
                                        renderiza
                                        Do you have the same issue on all of my plugins? Maybe we can learn something if you test them as well. πŸ˜‰
                                        • EdsonE
                                          Edson
                                          I am a mac user who is also having problems with canvas, it just does not work for me. I tried with groups and components. I am only able to select the options on the input box after hitting the space key but that does have any consequence: I just cannot place a single instance of the selected group/component.
                                          mac os 10.8.5 and sketchup 13.0.4811.
                                          http://www.mahfuz.arq.br
                                          • E
                                            energywebb
                                            HI
                                            I am on a Mac, and Canvas is not working for me at all.. neither the 1.1.3 nor the v.1.1.0 which you uploaded on this forum. Neither in sketchup 2013 nor sketchup 8 ... a great shame!
                                            any help appreciated
                                            thanks
                                            • 4 / 5
