    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 82.3k Views 31 Watching
    • guanjinG Offline
      guanjin
      • renderizaR Offline
        renderiza
        Don't see that error on my Ruby Console but I uploaded another file to Plugin Store to solve it so please install that to see if the error goes away.
        Thanks and sorry for inconvenience.
        NOTE: IMPORTANT! You need to install the latest Internet Explorer version. This plugin uses HTML5 & jQuery and if your browser doesn't support that it can cause problems.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • guanjinG Offline
          guanjin
          Thank you,
          • Z Offline
            Zacchia
            Thank you for it!
            • JQLJ Offline
              JQL
              Hi Renderiza,
              Excellent Plugin, beautifully excecuted, with a great visual appearence and a perfect video tutorial!
              What more could one wish for?
              Congratulations and thanks!
              JQL
              www.casca.pt
              Visit us on facebook!
                renderiza
                Very happy to see everyone is comments thank you! 💚
                • guanjinG Offline
                  guanjin
                  Thank you for your hard work 😍
                  • halroachH Offline
                    halroach
                    Another suggestion. a toggle to be able to orient the component to the surface it is being dropped on, Or the ability to maintain it's "glueing" properties that were set upon the component's creation.
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • O Offline
                      orchard collie
                      Hi Renderiza
                      Have just installed Canvas 1.1.3 on MacBOok Pro and can't seem to make it work. It loads the Dialog Box but there are no parameters or any of the other features you talked about in your video. Am I doing something wrong, or is Canvas only for Windows. If so - Please make a Mac version it looks such a fantastic plugin.
                      Tried Component Spray and couldn't make it work either
                      Any ideas?
                      I would love to get it up and running as I have a tree covered island to vegetate with 1000 trees or more!
                      Cheers
                      Orchard from Darwin
                        renderiza
                        That would be very good addition to the plugin indeed, it will eventually be on my to do list. 👍
                        @orchard collie said:
                        Any ideas?
                        Do you have internet explorer 9 or higher installed?
                        • O Offline
                          orchard collie
                          HI Renderiza
                          There is no IE for Mac. Best I could do was change agent in Safari to IE9. downloaded plugin again - can get at all the settings, but it just doesn't copy anything. Selected object is a Component by the way.
                          Cursor changes to a small hollow red square but nothing happens on mouse click
                          Any more ideas?
                          Orchard
                            renderiza
                            Any more ideas?
                            Verify every option under 'Only Add On' menu is unchecked and see if it works.
                            If not please open 'window>Ruby Console' and then try to run the plugin to check if any errors show up in Ruby Console. If you see something please let me know what it says.
                            Can you put it to IE 10 instead?
                            • O Offline
                              orchard collie
                              Hi Renderiza
                              Tried 'nothing selected' in Only Add On Menu - no difference still little red square
                              Ran Ruby Console by typing "load 'plugins/RND_Canvas.rb'"
                              Hit Return key and it wrote
                              load 'plugins/RND_Canvas.rb" underneath on line 2
                              Nothing else happened.
                              PS never opened Ruby Console before so am a total newbie
                              Regards
                              Orchard
                              • O Offline
                                orchard collie
                                Hi Renderiza
                                Me again
                                Just noticed your comment on switching to IE 10
                                The latest version of Safari doesn't go higher than IE9 I'm afraid
                                Orchard
                                  renderiza
                                  Uploaded a modified Canvas plugin to PluginStore, please re-download it again to see if it solved the problem.
                                  What I changed was a line in html document...
                                  From
                                  <meta http-equiv="X-UA-Compatible" content="IE=10">
                                  To
                                  <meta http-equiv="X-UA-Compatible" content="IE=9">
                                  Hope this solves it. 😕
                                  Also what version of SketchUp are you using?
                                  • O Offline
                                    orchard collie
                                    Hi Renderiza
                                    I'm afraid that didn't work. Still the little red square and no duplication.
                                    I did uninstall the old version before downloading the new one.
                                    Tech info
                                    MacBook Pro 2.3 GHz Intel Core i7
                                    4 GB 1600 MHz DDR3
                                    Mac OS 10.8.5
                                    SketchUp Pro 2013 V 13.0.4811
                                    Hope this helps
                                    Orchard
                                      renderiza
                                      Can you right click on SketchUp 2013 icon and click 'Run as administrator' to see if that solves it.
                                      If not here is an attachment with older version of Canvas (1.1.0) which doesn't need IE9 for HTML5 & jQuery compatibility.
                                      Older version of Canvas that doesn't need IE9 or higher.
                                      How to Install RBZ...
                                      • O Offline
                                        orchard collie
                                        Hi Renderiza
                                        Sorry it's taken time to get back to you
                                        Eventually loaded 1.1.0 (neat interface BTW
                                        Unfortunately still doesn't run on Mac just the empty red square attached to the arrow cursor.
                                        Have any other Mac Users encountered problems that you know of?
                                        I'd love to make it work
                                        There''s nothing else like it
                                        Here's hoping
                                        Cheers
                                        Orchard
                                          renderiza
                                          We need another Mac user for testing if this plugin works or not. Wish I had one myself to test my plugins before releasing them. 😕
                                          Can you verify if your folder permission are set to full?
                                          Also can you try Thomthom: VirtualStore Check v1.1.0 to check if there's files in the Plugins folder that's ended up in Window's VirtualStore.
                                          • O Offline
                                            orchard collie
                                            Hi Renderiza
                                            I can't believe I'm the only Mac User of your plugin!
                                            There must be more out there. I think the concept is fantastic. I just wish I knew what the problem is.
                                            There is of course no Windows Virtual Store on Mac and I have full permission on all files, folders and applications
                                            Here's hoping we find an answer
                                            Cheers
                                            Orchard
                                            • 4 / 5
