    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 85.6k Views 31 Watching
    • O
      orchard collie
      Hi Renderiza
      Have just installed Canvas 1.1.3 on MacBOok Pro and can't seem to make it work. It loads the Dialog Box but there are no parameters or any of the other features you talked about in your video. Am I doing something wrong, or is Canvas only for Windows. If so - Please make a Mac version it looks such a fantastic plugin.
      Tried Component Spray and couldn't make it work either
      Any ideas?
      I would love to get it up and running as I have a tree covered island to vegetate with 1000 trees or more!
      Cheers
      Orchard from Darwin
      • renderizaR
        renderiza
        @halroach said:
        Another suggestion. a toggle to be able to orient the component to the surface it is being dropped on, Or the ability to maintain it's "glueing" properties that were set upon the component's creation.
        That would be very good addition to the plugin indeed, it will eventually be on my to do list. πŸ‘
        @orchard collie said:
        Any ideas?
        Do you have internet explorer 9 or higher installed?
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • O
          orchard collie
          HI Renderiza
          There is no IE for Mac. Best I could do was change agent in Safari to IE9. downloaded plugin again - can get at all the settings, but it just doesn't copy anything. Selected object is a Component by the way.
          Cursor changes to a small hollow red square but nothing happens on mouse click
          Any more ideas?
          Orchard
          • renderizaR
            renderiza
            Any more ideas?
            Verify every option under 'Only Add On' menu is unchecked and see if it works.
            If not please open 'window>Ruby Console' and then try to run the plugin to check if any errors show up in Ruby Console. If you see something please let me know what it says.
            Can you put it to IE 10 instead?
            • O
              orchard collie
              Hi Renderiza
              Tried 'nothing selected' in Only Add On Menu - no difference still little red square
              Ran Ruby Console by typing "load 'plugins/RND_Canvas.rb'"
              Hit Return key and it wrote
              load 'plugins/RND_Canvas.rb" underneath on line 2
              Nothing else happened.
              PS never opened Ruby Console before so am a total newbie
              Regards
              Orchard
              • O
                orchard collie
                Hi Renderiza
                Me again
                Just noticed your comment on switching to IE 10
                The latest version of Safari doesn't go higher than IE9 I'm afraid
                Orchard
                • renderizaR
                  renderiza
                  Uploaded a modified Canvas plugin to PluginStore, please re-download it again to see if it solved the problem.
                  What I changed was a line in html document...
                  From
                  <meta http-equiv="X-UA-Compatible" content="IE=10">
                  To
                  <meta http-equiv="X-UA-Compatible" content="IE=9">
                  Hope this solves it. πŸ˜•
                  Also what version of SketchUp are you using?
                  • O
                    orchard collie
                    Hi Renderiza
                    I'm afraid that didn't work. Still the little red square and no duplication.
                    I did uninstall the old version before downloading the new one.
                    Tech info
                    MacBook Pro 2.3 GHz Intel Core i7
                    4 GB 1600 MHz DDR3
                    Mac OS 10.8.5
                    SketchUp Pro 2013 V 13.0.4811
                    Hope this helps
                    Orchard
                    • renderizaR
                      renderiza
                      Can you right click on SketchUp 2013 icon and click 'Run as administrator' to see if that solves it.
                      If not here is an attachment with older version of Canvas (1.1.0) which doesn't need IE9 for HTML5 & jQuery compatibility.
                      Older version of Canvas that doesn't need IE9 or higher.
                      How to Install RBZ...
                      • O
                        orchard collie
                        Hi Renderiza
                        Sorry it's taken time to get back to you
                        Eventually loaded 1.1.0 (neat interface BTW
                        Unfortunately still doesn't run on Mac just the empty red square attached to the arrow cursor.
                        Have any other Mac Users encountered problems that you know of?
                        I'd love to make it work
                        There''s nothing else like it
                        Here's hoping
                        Cheers
                        Orchard
                        • renderizaR
                          renderiza
                          We need another Mac user for testing if this plugin works or not. Wish I had one myself to test my plugins before releasing them. πŸ˜•
                          Can you verify if your folder permission are set to full?
                          Also can you try Thomthom: VirtualStore Check v1.1.0 to check if there's files in the Plugins folder that's ended up in Window's VirtualStore.
                          • O
                            orchard collie
                            Hi Renderiza
                            I can't believe I'm the only Mac User of your plugin!
                            There must be more out there. I think the concept is fantastic. I just wish I knew what the problem is.
                            There is of course no Windows Virtual Store on Mac and I have full permission on all files, folders and applications
                            Here's hoping we find an answer
                            Cheers
                            Orchard
                            • renderizaR
                              renderiza
                              Do you have the same issue on all of my plugins? Maybe we can learn something if you test them as well. πŸ˜‰
                              • EdsonE
                                Edson
                                I am a mac user who is also having problems with canvas, it just does not work for me. I tried with groups and components. I am only able to select the options on the input box after hitting the space key but that does have any consequence: I just cannot place a single instance of the selected group/component.
                                mac os 10.8.5 and sketchup 13.0.4811.
                                http://www.mahfuz.arq.br
                                • E
                                  energywebb
                                  HI
                                  I am on a Mac, and Canvas is not working for me at all.. neither the 1.1.3 nor the v.1.1.0 which you uploaded on this forum. Neither in sketchup 2013 nor sketchup 8 ... a great shame!
                                  any help appreciated
                                  thanks
                                  • romboutR
                                    rombout
                                    Is there any news or updates on getting this to work on mac. Is it just the issue with canvas not running on mac, cause canvas is supported by chrome and safari. Isnt it cause the header of the html page states content"IE=10", i did try to set this to chrome=1 but didnt help
                                    edit
                                    i just noticed that version 1.1 does give me some feedback in the ruby console
                                    `onLButtonDown'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/RND_Canvas/RND_Canvas_loader.rb;390
                                    Error; #<NoMethodError; undefined method `material' for nil;NilClass>
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/RND_Canvas/RND_Canvas_loader.rb;390;in `onLButtonDown'
                                      driven
                                      @rombout said:
                                      Is it just the issue with canvas not running on mac,...
                                      the plugin dosen't use the <canvas> tag and the html works fine in safari, the problem lays elsewhere...
                                      look in the ruby for PC only calls...
                                      • soloS
                                        I cannot seem to get this to work with SU 2014 or 2015.
                                        All installs correct, dialogue box and toolbar appear yet cannot select anything.
                                        Anyone?
                                          dtrarch
                                          Solo
                                          1.1.3 works for me. πŸ‘ πŸ‘
                                          SU 2015 Pro latest upd.
                                          Win 7 pro
                                          ??? πŸ˜„
                                            Works fine for me on PC windows 2015 πŸ˜‰
                                            Have you IE > 8?
                                            Do you use Groups or Components?
                                            • 5 / 5
