    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 85.6k Views 31 Watching
      jpalm32
      Really clean polished work. Well done.
      • halroachH
        halroach
        Very nice Renderiza!
        1. It would be great to have the ability to choose a bunch/list of components to paint, that alternate randomly or in a cycle - kinda like with the "component spray" plugin.
        2. An idea to think about... Having the ability to set a point in space that all blue axis of newly inserted components will align to. Like a magnet point.
        3. The ability to rotate objects randomly in all axis. Not only in the XY. Not sure what it would be good for... but it could be nice.
        FlexTools - Super Quick Windows, Doors, Slats...
        • guanjinG
          guanjin
          Can not be opened, an error ๐Ÿ˜’
          • renderizaR
            renderiza
            Can you close SketchUp and try running the plugin again a second time?
            If I am not mistaken that error should go away...Please let me know.
            That error has to do with trying to load the previous data stored but since your loading the plugin for the very fist time there is no data to load. ๐Ÿ˜•
            I thought I solved this by adding a condition to skip that line of code if there was no data but it seems the problem persists.
            I will be very grateful if another person confirm this issue and if it went away the second time trying to load the plugin.
            Very good suggestions!
            Will try to integrate them for future updates. ๐Ÿ‘
            I appreciate your comment thank you! ๐Ÿ˜„
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            • renderizaR
              renderiza
              One more thing...
              Can you verify that your plugins folder permission are set to full?
              • guanjinG
                guanjin
                • renderizaR
                  renderiza
                  Don't see that error on my Ruby Console but I uploaded another file to Plugin Store to solve it so please install that to see if the error goes away.
                  Thanks and sorry for inconvenience.
                  NOTE: IMPORTANT! You need to install the latest Internet Explorer version. This plugin uses HTML5 & jQuery and if your browser doesn't support that it can cause problems.
                  • guanjinG
                    guanjin
                    Thank you,
                    • Z
                      Zacchia
                      Thank you for it!
                      • JQLJ
                        JQL
                        Hi Renderiza,
                        Excellent Plugin, beautifully excecuted, with a great visual appearence and a perfect video tutorial!
                        What more could one wish for?
                        Congratulations and thanks!
                        JQL
                        www.casca.pt
                        Visit us on facebook!
                        • renderizaR
                          renderiza
                          Very happy to see everyone is comments thank you! ๐Ÿ’š
                          • guanjinG
                            guanjin
                            Thank you for your hard work ๐Ÿ˜
                            • halroachH
                              halroach
                              Another suggestion. a toggle to be able to orient the component to the surface it is being dropped on, Or the ability to maintain it's "glueing" properties that were set upon the component's creation.
                              • O
                                orchard collie
                                Hi Renderiza
                                Have just installed Canvas 1.1.3 on MacBOok Pro and can't seem to make it work. It loads the Dialog Box but there are no parameters or any of the other features you talked about in your video. Am I doing something wrong, or is Canvas only for Windows. If so - Please make a Mac version it looks such a fantastic plugin.
                                Tried Component Spray and couldn't make it work either
                                Any ideas?
                                I would love to get it up and running as I have a tree covered island to vegetate with 1000 trees or more!
                                Cheers
                                Orchard from Darwin
                                • renderizaR
                                  renderiza
                                  That would be very good addition to the plugin indeed, it will eventually be on my to do list. ๐Ÿ‘
                                  @orchard collie said:
                                  Any ideas?
                                  Do you have internet explorer 9 or higher installed?
                                  • O
                                    orchard collie
                                    HI Renderiza
                                    There is no IE for Mac. Best I could do was change agent in Safari to IE9. downloaded plugin again - can get at all the settings, but it just doesn't copy anything. Selected object is a Component by the way.
                                    Cursor changes to a small hollow red square but nothing happens on mouse click
                                    Any more ideas?
                                    Orchard
                                    • renderizaR
                                      renderiza
                                      Any more ideas?
                                      Verify every option under 'Only Add On' menu is unchecked and see if it works.
                                      If not please open 'window>Ruby Console' and then try to run the plugin to check if any errors show up in Ruby Console. If you see something please let me know what it says.
                                      Can you put it to IE 10 instead?
                                      • O
                                        orchard collie
                                        Hi Renderiza
                                        Tried 'nothing selected' in Only Add On Menu - no difference still little red square
                                        Ran Ruby Console by typing "load 'plugins/RND_Canvas.rb'"
                                        Hit Return key and it wrote
                                        load 'plugins/RND_Canvas.rb" underneath on line 2
                                        Nothing else happened.
                                        PS never opened Ruby Console before so am a total newbie
                                        Regards
                                        Orchard
                                        • O
                                          orchard collie
                                          Hi Renderiza
                                          Me again
                                          Just noticed your comment on switching to IE 10
                                          The latest version of Safari doesn't go higher than IE9 I'm afraid
                                          Orchard
                                          • renderizaR
                                            renderiza
                                            Uploaded a modified Canvas plugin to PluginStore, please re-download it again to see if it solved the problem.
                                            What I changed was a line in html document...
                                            From
                                            <meta http-equiv="X-UA-Compatible" content="IE=10">
                                            To
                                            <meta http-equiv="X-UA-Compatible" content="IE=9">
                                            Hope this solves it. ๐Ÿ˜•
                                            Also what version of SketchUp are you using?
                                            • 4 / 5
