    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.8k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @dancho said:
      After opening a second, third etc. sketchup windows I'm receiving a script error message.
      IE 10, Sketchup 2013, Windows 7 Home Premium x64
      You mean when opening multiple instances of Sketchup ?
      • OxerO Offline
        Oxer
        Hi, I installed the plugin and it appears this error message when I run SU
        I work on Mac OSX 10.9 and SU 2013.
          If you read the download page it does say 'PC only' ๐Ÿ˜ž
          • OxerO Offline
            Oxer
            Bad lucky, waiting for mac version ๐Ÿ˜ž
              jiminy-billy-bob
              New version 0.6 beta !
              Changelog :
              • Fix scene auto-update (This is now an option)
              • Adds an options to hide the warning for outdated IE versions (This is intended for people with the warning appearing even though their IE is up to date)
              Download in the plugin store !
              • marcorigamonti74M Offline
                marcorigamonti74
                Hi! I have sketchup running on a MAC! When does this plug in will be ready for OS SISTEM?
                [mod=:ik2ekmon]Edited to remove unneeded quote[/mod:ik2ekmon]
                  monmonred
                  @jiminy-billy-bob said:
                  Is your IE version 9 ? If so, try updating to IE10.
                  I saw this bug on IE9, but could not find what's the issue...
                  does IE mean differently here in sketchucation? i understand IE as internet explorer. ๐Ÿ˜„ anyway, i would go for that. thanks!
                  +Greatness may be measured on how much we have lost for the betterment of mankind+
                    monmonred
                    1. Nope, that's not possible. Unfortunately.
                    2. Already working on it.
                      3&4. Added to my todo list. ๐Ÿ˜„
                    cool! we all will be waiting!
                    i'm always checking for your updates. this plugin is so helpful! thanks!
                      IE means the same thing here: Internet Explorer
                        jiminy-billy-bob
                        It will be avaiblable on mac when it's ready. I don't know when.
                          tomot
                          @jgb said:
                          Since IE and WIN OS share many DLL's that contain these calls, an update to an IE DLL will update an OS DLL, but not necessarily vice versa. The app developer WILL have the latest IE on his system, and may use an "updated" OS call, but if you have an older IE, that call may fail. ๐Ÿ˜ฎ
                          Your point is well taken! ๐Ÿ‘
                          Which is why I have always maintained the decision to use Web dialogs in the first place, was a bad idea.
                          Lets face it, a robust SU Ruby API should have been developed with its own graphical interface, not unlike the capability of Python. Its unfortunate Ruby was chosen over Python but that's a story for another day. Instead the SU API developers decided to hitch their horse to the I.E. cart which is about as popular as BING. and also alienates the OSX user.
                          Lets face it, its almost 2014, and we still have not been able integrate simple graphical information along with user input in a simple format, without a programmer learning 3 other languages to make this work, and also having to be I.E. compliant ..... its downright laughable!
                          my plugins
                          tomot
                          • tt_suT Offline
                            tt_su
                            How are you detecting the IE version and which versions are detected incorrectly?
                              jiminy-billy-bob
                              I display a warning with <!--[if IE 7]> <![endif]-->, etc.
                              But it seems to catch sometimes compatibility mode even when it's supposed to be disabled. Don't know why...
                              • tt_suT Offline
                                tt_su
                                Some times? Not consistently?
                                Do you use the META tag to force embedded IE to use the actual IE IE render engine? Embedded IE is more conservative and it uses an older render mode even if you have a standard doctype. See the Lost Manual for more details: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual/wiki/Doctype---Quirks-vs-Standard-vs-Superstandard
                                I also think that in one of the recent SU versions there was a registry setting set that would bump up this doc type one version (and that would affect older SU versions on the same machine.) So that might be the reason to why you get seemingly random reports of this. It might be they have versions that trigger the IE7 mode.
                                By the way, should you not be detecting older versions as well, not just IE7?
                                <!--[if lte IE 7]> <![endif]-->
                                  jiminy-billy-bob
                                  That's interesting.
                                  But how can we force the last version ? Let's say I put <meta http-equiv="X-UA-Compatible" content="IE=10"/>, how will IE8 behave with this ?
                                  Of course I do ๐Ÿ˜‰ , I just display different things depending on the version, so I have two of these.
                                  • tt_suT Offline
                                    tt_su
                                    That's interesting.
                                    It will use the newest it can - IE8.
                                    I'd recommend you set it to: <meta http-equiv="X-UA-Compatible" content="IE=edge"/> - it will then always pick the latest mode available. Like a normal browser would do. (See example in the SKUI project: https://github.com/thomthom/SKUI/blob/master/src/SKUI/html/window.html#L4)
                                      jiminy-billy-bob
                                      Ok thanks ! ๐Ÿ˜„
                                      • H Offline
                                        huckrorick
                                        any progress on not updating scenes and changing layers activated in a scene?
                                          monmonred
                                          just thank you. jiminy-billy-bob! are you working on the option to hide/show multiple layers at a time? can this also have a hotkey?
                                          brilliant work!
                                          • Bob JamesB Offline
                                            Bob James
                                            New version 0.7 beta !
                                            Changelog :
                                            • Added a dark bar at the top to minimize/maximize the dialog
                                            • Added CTRL+G : Group selected layers
                                            • Added CTRL+SHIFT+G : Ungroup layers
                                            • Added CTRL+A : Select all
                                            • Added CTRL+E : Merge selected layers
                                            • Added different color for groups
                                            • Layer0 is now selectable
                                            • Fix bug with sorted groups
                                            • Potential fix for IE version bug
                                            Super improvements - have made a donation
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 33
                                            • 34
                                            • 21 / 34
