    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
    • fredo6F Offline
      NEW RELEASE: FredoScale v2.5b - 15 Sep 13
      FredoScale 2.5b fixes a bug preventing language translations to load.
      FredoScale 2.5 requires LibFredo6 5.2 or higher.
        dedmin
        After the update:
        • fredo6F Offline
          @dedmin
          Thanks very much. I updated the post and Plugin Store today at 15h.
            dedmin
            BTW, did You see this:
            http://sketchucation.com/forums/viewtopic.php?f=323&t=46473&start=90
            http://sketchucation.com/forums/viewtopic.php?f=323&t=54176
            • fredo6F Offline
              @dedmin said:
              :thumb: 👍
              1. For Curvizard Edge Prop, I had found the bug actually but forgot to republish
              2. For BezierSpline, I have to investigate. This is old code and the tooltip may not reflect the correct alignment
              • guanjinG Offline
                guanjin
                Thank timely updates, thank you 😍
                • LanaL Offline
                  Lana
                  Thank you, thank you, thank you....is very good.
                  • enigmaticE Offline
                    enigmatic
                    Hi Fredo,
                    Is it normal dimensions differences in?
                    scale_01
                    scale_02
                    • dereiD Offline
                      derei
                      @enigmatic said:
                      Hi Fredo,
                      Maybe some rounding ... bug? I'm guessing it rounds in all situations, not considering the units used (and number of decimals) ?
                        samothrace41
                        Bonjour,
                        J'utilise régulièrement FredoScale et Curviloft et je viens de télécharger Joint Push/Pull. Je voudrais te faire une petite donation (symbolique) mais je ne veux pas passer par PayPal. Je voudrais t'envoyer un mail mais je n'ai pas ton adresse. Le mien est samothrace41 @ yahoo.fr
                        A+
                        Sylvie
                          jumpjack
                          I don't understand if this plugin can help me.
                          I have a non-planar surface close to a cylindrical surface; I want to extrude a region of the non-planar surface up to the cylinder to create a solid 3d joint between cylinder and the non-planar surface.
                          Can I use this plugin, or do I need another one?
                            If you want to project the bottom face of the cylinder down onto the surface then look at my ExtrudeEdgesByVector[ToObject] tool.
                            Edit the cylinder [group?] and copy the bottom face.
                            Exit the edit and use Edit>PlaceInPlace.
                            Select the face-copy [double-click].
                            Activate EEby..Object tool and pull a vertical [blue] vector down through your surface.
                            The face is extruded and stops on the surface...
                            With some finely divided surfaces the 'auto-trim' might fail, so in that case extrude through and manually intersect/delete parts.. With the simple 'toVector' version of the tool it extrudes through the surface - in that case then edit the grouped extrusion and Select its geometry and then use Intersect with Model: now Select [by fence] for the unwanted lower geometry and delete it.
                              sunchart
                              • hamedmemarH Offline
                                hamedmemar
                                excellent
                                your amazing tools are very useful
                                thank you very mach fredo
                                • fredo6F Offline
                                  NEW RELEASE: FredoScale v2.6a - 27 Nov 13
                                  FredoScale 2.6a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                  • utilerU Offline
                                    utiler
                                    I recall a while ago the question being asked how to rotate accurately say a cross brace in a fence [see below]
                                    I'm drawing a louvre window and want my blades to be angled in 3D to accept shadowing but only want to open the blades to the point where the top of the blade is in the same horizontal line as the bottom of the blade above. This way in elevation I achieve a clean horizontal section as well as seeing depth in shadow.
                                    For the life of me I have been trying to rotate the lourve blades using Fredoscale rotate but do not have the option to inference to the centre of the louvre blade overlap... [middle of the 12mm overlap]
                                    I've attached the skippy to let you see what I'm doing as well as a short video.
                                    I expect it is something really simple that will make me look like a goose [holidays will do that...
                                    Lourves.swf
                                    Window-Lourve X1.skp
                                    purpose/expression/purpose/....
                                      Andrew, try this:
                                      Draw a short line segment along that horizontal guideline in the vicinity of where the corner of the bottom louver should be. You can then use Rotation by Selection and Angle of Plane (the red rotate icon) to rotate and snap to the line.
                                      Short line shown in blue
                                      Select the bottom louver.
                                      Get the red Rotate tool from Fredoscale.
                                      Click on the center of rotation.
                                      Click on the top corner of the louver.
                                      Click on the top corner again.
                                      Move the cursor over toward the line bringing the louver corner with it.
                                      When the line turns orange, click again to set the corner on the line.
                                      Do not repeat for the other louvers. Delete them and copy the rotated one up and make a linear array.
                                      Delete the little short line when you've finished with it.
                                      • utilerU Offline
                                        utiler
                                        I can see what you've done here, Dave. THANKS!!!
                                        I was going into the component and trying to inference from within.....
                                        YOU DA MAN!!
                                          Thank you.
                                          I can see the reason for opening the component for editing because all of them would rotate at the same time. I expect you could still do that with the line but I think I'd leave the component as is and rotate the whole thing.
                                          • JQLJ Offline
                                            JQL
                                            Fredo,
                                            First of all thanks for this and all your wondeful plugins. There can't be thank enough for this contribution but I've came here bragging with an issue I've come across with Box Scaling to Target.
                                            It is a very useful and natural way of scaling things in Sketcbup and it replaced my S key long time ago. However, today, a very simple operation gave me an unexpected result and I never seen this before. Probably it's because I hadn't noticed it or because of some setting I have changed that I'm not finding right now.
                                            I don't know where an I failing but please take a look at this:
                                            The issue happens when scaling along the axis (in this case X and Y)
                                            There's an autosnap inference when scaling smaller to 75%, 50% or 25% as there is also if you want to make it scale bigger.
                                            However when you use a close enough distance in VCB to one of those factors, in this case 75%, it snaps to that factor and disregards the distance that was input in VCB. In this case moving 0.30m turned out a scale factor of 0.75 instead of a measurement of 0.30m, the final rectangle turns out to be of (0.75m, 0.75m) instead of (0.75m, 0.8m). This also happens when trying to snap to an existing geometry (like that guide there).
                                            If I try the same with an object not perpendicular/parallel to axis, there is also a snap...
                                            But giving a distance overrides it and in this case, a distance of .3m turns that square into a rectangle of (1m,0.8m).
                                            Is there anyway I can override the snapping factor and get on with only the distance on VCB?
                                            Thanks and best regards,
                                            JQL
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 56
                                            • 57
                                            • 38 / 57
