    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
      shumphreys
      Fantastic layering tool, I applaud your hard work.
      If you're up for more work I have some suggestions...
      1. Highlight layers for currently selected entity, this would save having to consult the entity info window. Could also include colour coding for sub layers used within the entity.
      2. Entity count on layer list. This would help to identify incorrectly assigned layers.
      3. Select all entities by layer. Could be a context menu item.
      4. Option to remove render feature.
      Thanks again
      • jiminy-billy-bobJ
        jiminy-billy-bob
        @shumphreys said:
        1. Option to remove render feature.
        Already did 😉 Look in "options" in the menu.
        Noted the other propositions.
        • O
          optimaforever
          Hello,
          The idea of this script is excellent, something I kept asking AtLAst developpers for a long time (in the famous wishlist), and the material list manager as well (by giving users the ability to group materials by components, for example).
          The thing is, the layer panel worked once, and the next time I launched SU8, it returned blank of layers, with the IE version is outdated message. I work with SU8, panel 0.5.2 on Vista 64 and IE9 (don't use IE anyway, but 9 is the last supported version by Vista).
          Any clue?
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Can you try with Sketchup Make 2013 ?
            • O
              optimaforever
              Hello,
              I will, once I get out of my stressing schedule. 😎
              • Bob JamesB
                Bob James
                It still says:
                Layers Panel
                Version beta 0.5.1
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Uploaded the proper update 0.5.3 beta ! (Which is what should have been 0.5.2)
                  Changelog :
                  • Fix bug where "old layers" (created before Layers Panel was installed) were not listed
                  • Fix bug where groups couldn't be renamed after being nested in another one.
                  Download in the plugin store !
                    DRDS-11
                    How about an OS X version!!!!! Otherwise its a waste of time!!!!
                    • T
                      tomot
                      Question?
                      Whats the significance of having IE installed? I use win7 64, I have never installed I.E. and don't intend to do so. I use Mozilla FireFox only. And I hate being reminded by a dialog box from the plugin if I want to switch. Can you make the use of I.E. optional?
                      Otherwise I like the plugin, very! very! much. 🎉
                      my plugins
                      tomot
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Ho but it is installed by default on windows. The webdialogs in SU use Ie, and we can't force using something else. So update your Ie version!
                          monmonred
                          1. can you integrate the layer colors to the panel?
                          2. can you make dragging support multiple-selected layers/groups?
                          3. can you make an option to set visibility for multiple-selected layers at once?
                          4. can you have support for keyboard shortcuts like in photoshop, just select a no. of layers then ctrl+g to group the layers? arrow keys to scroll through items then ctrl & space bar to select multiple layers, etc.?
                          thanks! you are so awesome!
                          +Greatness may be measured on how much we have lost for the betterment of mankind+
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            1. Nope, that's not possible. Unfortunately.
                            2. Already working on it.
                              3&4. Added to my todo list. 😄
                            • T
                              tomot
                              Sorry but this had nothing to do with updating I.E.
                              Windows 64 is already being updated automatically by Microsoft.
                              Also There are many Ruby Webdialogs, now in use. None of these cause errors when a .html is opened in Firefox.
                              Have a look at your Layers Panel.html and options.html , both files give the following errors when opened
                              "The address wasn't understood"
                              " Firefox doesn't know how to open this address, because the protocol (skp) isn't associated with any program."
                              my plugins
                              tomot
                                That is a red-herring.
                                You'll get the same error with many tools html that have a callback within them or their js...
                                IF you open them directly in IE, Firefox, Chrome etc...
                                SketchUp alqays uses a modified version of the installed IE on PCs and Safari on MACs.
                                When an author makes a webdialog in his rb and adds a callback etc, then this error does not occur if the html/js is written in a matching way.
                                But when you try and open the html file directly inside a browser, then you will get an error because the callback code is missing [simply because it has not been added by the Ruby script that usually creates the very similar looking webdialog] - giving the message like: "XXXX doesn't know how to open this address, because the protocol (skp) isn't associated with any program."
                                • T
                                  tomot
                                  I don't write Web dialogs, I'm simply reporting a Web Dialog Issue. As I stated in my last reply
                                  "There are many Ruby Web dialogs, now in use. None of which cause errors when an.html is opened in Firefox" particularly when the Ruby Web dialog has not even been installed yet.
                                  Its simply my observation that all Ruby Web dialogs I have collected Don't exhibit errors. while this particular script does.
                                  Why this is so, I don't know? Maybe this red-Herring has been contaminated from Fukushima. 😢
                                  my plugins
                                  tomot
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    Web dialogs use IE. Period.
                                    You'll never see a webdialog use Firefox or whatever, that's just not possible.
                                    From there, I made the choice to warn people using IE 6 and 7 that LP won't work well if they don't update IE. Otherwise I'm pretty sure this thread would be full of "meh not working" due to an outdated IE.
                                      @Tomot
                                      On a PC all webdialogs use a modified version of the current OS's IE installation.
                                      Not all webdialogs will include callbacks that are designed to be executed as soon as the page loads, therefore when you open them in a browser [rather than a webdialog] you will not get these errors - however, later on clicking on buttons etc that do activate a callback will then raise an error.
                                      The fact that your Firefox presents an error with this code loading is irrelevant, you'll get the equivalent error in IE or Chrome.
                                      There are several plugins that use webdialogs that run callbacks as they load, and these will all display errors when opened in a browser rather than a webdialog. However, they will open and run just fine when they open from within SketchUp, because the webdialog is constructed with the appropriate callback codes etc as it is initially created...
                                      • halroachH
                                        halroach
                                        1. I autoinstalled it through the the sketchucation plugin store 2.0.0 and sketchup immediately crashed. (I sent the crash report)
                                        2. It says my internet Explorer version is outdated when the Microsoft website says it's the latest... hmmmmmm
                                        (using sketchup 8.0.16846 on windows 7. have firefox installed and used as my default browser)
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                        • halroachH
                                          halroach
                                          I'm trying to figure what are the benefits of working with this layers system are over working without it. It looks nice... but not sure if it's good for me.
                                          In my workflow on a model with various versions of a building, I save various scenes. In each of the scenes I have a set of layers that are on and off accordingly.
                                          (Of course all geometry is on Layer0 while only groups and components are tagged with different layers).
                                          Now if I try to implement this Layers Panel plugin I am basically losing the ability to save scenes with different layer visibilities...? unless I am not understanding something.
                                          The groups are helpful in that I can turn on and off different groups of layers, but the Sketchup scenes do not save that information of what is on or off, right? So I have to manually select each layer or group of layers visibility for each of scene... It kind of defeats it's whole purpose in my opinion, unless again, I am not understanding something.
                                            @Hal
                                            I think you are correct... in the current version of this tool changing the layer states messes with the current scene-tab's layer settings, without you having any control over this... 😮
                                            This is not good.
                                            I know the author is striving to resolve this... so that once you have a set of layers setup as you want, then you choose which scene-tab[s] get[s] that current layer setup applied, as in an 'update', and not decided on by this tool !
                                            I do think that this is single biggest issue with this tool... but once the user regains control over the application of the tool's layer-sets to his scene-tabs, then it will become so much more powerful and useful 😉
                                            • 11
                                            • 12
                                            • 13
                                            • 33
                                            • 34
                                            • 11 / 34
