    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.5k Views 110 Watching
    • H Offline
      huckrorick
      @jiminy-billy-bob said:
      This is really weird. Can you open this link with Internet Explorer and tell me what the popup says ? (If you don't have a popup, this may be because of an ActiveX warning at the bottom or top of the IE window)
      I'm having a bit of a hard time following our conversation because it is intermixed with other questions, issues, comments, replies. I don't know if I missed any other response from you.
      Here's what I get at the link you provided (see attachment)
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Thanks for the feedback guys, very much helpfull πŸ˜‰
        I'll work on it.
          jiminy-billy-bob
          New version 0.5.2 beta !
          Changelog :
          • Fix bug where "old layers" (created before Layers Panel was installed) were not listed
          • Fix bug where groups couldn't be renamed after being nested in another one.
          Download in the plugin store !
          Looks like I uploaded 0.5.1 again, instead of 0.5.2...
          I'll upload the proper version at noon.
            shumphreys
            Fantastic layering tool, I applaud your hard work.
            If you're up for more work I have some suggestions...
            1. Highlight layers for currently selected entity, this would save having to consult the entity info window. Could also include colour coding for sub layers used within the entity.
            2. Entity count on layer list. This would help to identify incorrectly assigned layers.
            3. Select all entities by layer. Could be a context menu item.
            4. Option to remove render feature.
            Thanks again
              jiminy-billy-bob
              @shumphreys said:
              1. Option to remove render feature.
              Already did πŸ˜‰ Look in "options" in the menu.
              Noted the other propositions.
              • O Offline
                optimaforever
                Hello,
                The idea of this script is excellent, something I kept asking AtLAst developpers for a long time (in the famous wishlist), and the material list manager as well (by giving users the ability to group materials by components, for example).
                The thing is, the layer panel worked once, and the next time I launched SU8, it returned blank of layers, with the IE version is outdated message. I work with SU8, panel 0.5.2 on Vista 64 and IE9 (don't use IE anyway, but 9 is the last supported version by Vista).
                Any clue?
                  jiminy-billy-bob
                  Can you try with Sketchup Make 2013 ?
                  • O Offline
                    optimaforever
                    Hello,
                    I will, once I get out of my stressing schedule. 😎
                    • Bob JamesB Offline
                      Bob James
                      It still says:
                      Layers Panel
                      Version beta 0.5.1
                        jiminy-billy-bob
                        Uploaded the proper update 0.5.3 beta ! (Which is what should have been 0.5.2)
                        Changelog :
                          DRDS-11
                          How about an OS X version!!!!! Otherwise its a waste of time!!!!
                            tomot
                            Question?
                            Whats the significance of having IE installed? I use win7 64, I have never installed I.E. and don't intend to do so. I use Mozilla FireFox only. And I hate being reminded by a dialog box from the plugin if I want to switch. Can you make the use of I.E. optional?
                            Otherwise I like the plugin, very! very! much. πŸŽ‰
                            my plugins
                            tomot
                              jiminy-billy-bob
                              Ho but it is installed by default on windows. The webdialogs in SU use Ie, and we can't force using something else. So update your Ie version!
                                monmonred
                                1. can you integrate the layer colors to the panel?
                                2. can you make dragging support multiple-selected layers/groups?
                                3. can you make an option to set visibility for multiple-selected layers at once?
                                4. can you have support for keyboard shortcuts like in photoshop, just select a no. of layers then ctrl+g to group the layers? arrow keys to scroll through items then ctrl & space bar to select multiple layers, etc.?
                                thanks! you are so awesome!
                                +Greatness may be measured on how much we have lost for the betterment of mankind+
                                  jiminy-billy-bob
                                  1. Nope, that's not possible. Unfortunately.
                                  2. Already working on it.
                                    3&4. Added to my todo list. πŸ˜„
                                    tomot
                                    Sorry but this had nothing to do with updating I.E.
                                    Windows 64 is already being updated automatically by Microsoft.
                                    Also There are many Ruby Webdialogs, now in use. None of these cause errors when a .html is opened in Firefox.
                                    Have a look at your Layers Panel.html and options.html , both files give the following errors when opened
                                    "The address wasn't understood"
                                    " Firefox doesn't know how to open this address, because the protocol (skp) isn't associated with any program."
                                    my plugins
                                    tomot
                                      That is a red-herring.
                                      You'll get the same error with many tools html that have a callback within them or their js...
                                      IF you open them directly in IE, Firefox, Chrome etc...
                                      SketchUp alqays uses a modified version of the installed IE on PCs and Safari on MACs.
                                      When an author makes a webdialog in his rb and adds a callback etc, then this error does not occur if the html/js is written in a matching way.
                                      But when you try and open the html file directly inside a browser, then you will get an error because the callback code is missing [simply because it has not been added by the Ruby script that usually creates the very similar looking webdialog] - giving the message like: "XXXX doesn't know how to open this address, because the protocol (skp) isn't associated with any program."
                                        tomot
                                        I don't write Web dialogs, I'm simply reporting a Web Dialog Issue. As I stated in my last reply
                                        "There are many Ruby Web dialogs, now in use. None of which cause errors when an.html is opened in Firefox" particularly when the Ruby Web dialog has not even been installed yet.
                                        Its simply my observation that all Ruby Web dialogs I have collected Don't exhibit errors. while this particular script does.
                                        Why this is so, I don't know? Maybe this red-Herring has been contaminated from Fukushima. 😒
                                        my plugins
                                        tomot
                                          jiminy-billy-bob
                                          Web dialogs use IE. Period.
                                          You'll never see a webdialog use Firefox or whatever, that's just not possible.
                                          From there, I made the choice to warn people using IE 6 and 7 that LP won't work well if they don't update IE. Otherwise I'm pretty sure this thread would be full of "meh not working" due to an outdated IE.
                                            @Tomot
                                            On a PC all webdialogs use a modified version of the current OS's IE installation.
                                            Not all webdialogs will include callbacks that are designed to be executed as soon as the page loads, therefore when you open them in a browser [rather than a webdialog] you will not get these errors - however, later on clicking on buttons etc that do activate a callback will then raise an error.
                                            The fact that your Firefox presents an error with this code loading is irrelevant, you'll get the equivalent error in IE or Chrome.
                                            There are several plugins that use webdialogs that run callbacks as they load, and these will all display errors when opened in a browser rather than a webdialog. However, they will open and run just fine when they open from within SketchUp, because the webdialog is constructed with the appropriate callback codes etc as it is initially created...
                                            • 11
                                            • 12
                                            • 13
                                            • 33
                                            • 34
                                            • 11 / 34
