    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
      So XP Pro with IE 8 ?
      Any one with that config having similar issues ?
      • F
        frlic
        Excuse me, but I did not really understand the problem?
        Thank you for your patience.
        Kreso
        FRLIĆ
        http://www.frlic.hr
          It appears to be a css [cascading style sheet] issue.
          It IE is indeed purging properly then perhaps it's an issue with the OS and/or the version of IE.
          Could you consider an upgrade your version of IE ?
          • irwanwrI
            irwanwr
            I thought IE 8 is the highest WinXP could use.
              I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... πŸ˜„
              It'll be server-side fixes, so what you currently have installed should work, but then load the fixed html/css once it's sorted...
              • G
                g_wilson
                Same Problem - XP HOME - IE8.
                Internet Options: delete history on exit.
                CCcleaner checked to analyze=>Temp Internet Files/History/Cookies/Recently typed URLs/Index.dat files/Last Download Loc'n./Autocomplete Form History.
                Close Chrome - Close IE8 - Running SU8(last rev) + CCcleaner only.
                Run CCcleaner=> clean history => CCcleaner re-analyze = 0 bytes.
                Open Store => problem exists as per described => run CCcleaner (Store still open)=> IE - Temp files 126 KB 33 files and IE - Cookies 1 KB 1 files.
                (DO NOT clean)=>Close Store => run CCcleaner=> analyze => IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                Repeatedly opening store+closing store + CCcleaner analyze without cleaning = IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                Hope this gives a hint as to what is problem.
                • irwanwrI
                  irwanwr
                  Thank you very very much πŸ˜„
                    Problem possibly identified....
                    Fix will happen without needing to update tool
                      Someone on IE8 please test pluginstore 2 for me?
                      Clear cache beforehand to force new css update
                        More info please....
                        Clicking the toolbar? Clicking the menu entry? What caused the splat?
                        • irwanwrI
                          irwanwr
                          It produced "Bugsplat"
                          Sketchucation Tool 1.1.3 still works fine though.
                            When you're ready to tell us what you did prior to the splat let us know...
                            • irwanwrI
                              irwanwr
                              It just crashed SketchUp.
                              Ed: Restarted SketchUp 8 and it works just fine now πŸ˜„
                              • G
                                g_wilson
                                For me - a Eureka moment - works repeatedly open/close Store. Also works after opening IE8 again elsewhere. Also works after closing SU and restarting SU. Thank You for your efforts - This community never ceases to impress.
                                  Can either of your gents please take a screenshot of the PluginStore on your system?
                                  • irwanwrI
                                    irwanwr
                                    Restarted SketchUp 8, with IE 8; all three Sketchucation Tool buttons works just fine.
                                    Thank you very much, Rich πŸ‘ πŸ˜„
                                    Does it really have anything to do with the tool? Or, the html page?
                                    • G
                                      g_wilson
                                      Yor wish is my command.
                                        Ok, thank you. I see an issue with the icons. Wrongly postioned...
                                        Tomorrow. Thanks for taking the time to help
                                        • irwanwrI
                                          irwanwr
                                          • halroachH
                                            halroach
                                            I back button and a forward button would be nice to have -
                                            After doing a search, for instance, and then wanting to go back to the previous results...
                                            FlexTools - Super Quick Windows, Doors, Slats...
                                            • 19
                                            • 20
                                            • 1 / 20
