    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
    • F
      frlic
      @tig said:
      SketchUp uses IE on PC and Safari on MAC - so you don't have to worry about Chrome, Firefox etc...
      Are your sure you have completely emptied the cache?
      What version of Windows and IE do you have running ?
      I once deleted a complete history in Internet Explorer, but without result. On the pictures you can see versions of Explorer and Windows.
      Kresimir
      IE
      IE_1
      FRLIĆ
      http://www.frlic.hr
        So XP Pro with IE 8 ?
        Any one with that config having similar issues ?
        • F
          frlic
          Excuse me, but I did not really understand the problem?
          Thank you for your patience.
          Kreso
          FRLIĆ
          http://www.frlic.hr
            It appears to be a css [cascading style sheet] issue.
            It IE is indeed purging properly then perhaps it's an issue with the OS and/or the version of IE.
            Could you consider an upgrade your version of IE ?
            • irwanwrI
              irwanwr
              I thought IE 8 is the highest WinXP could use.
                I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... πŸ˜„
                It'll be server-side fixes, so what you currently have installed should work, but then load the fixed html/css once it's sorted...
                • G
                  g_wilson
                  Same Problem - XP HOME - IE8.
                  Internet Options: delete history on exit.
                  CCcleaner checked to analyze=>Temp Internet Files/History/Cookies/Recently typed URLs/Index.dat files/Last Download Loc'n./Autocomplete Form History.
                  Close Chrome - Close IE8 - Running SU8(last rev) + CCcleaner only.
                  Run CCcleaner=> clean history => CCcleaner re-analyze = 0 bytes.
                  Open Store => problem exists as per described => run CCcleaner (Store still open)=> IE - Temp files 126 KB 33 files and IE - Cookies 1 KB 1 files.
                  (DO NOT clean)=>Close Store => run CCcleaner=> analyze => IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                  Repeatedly opening store+closing store + CCcleaner analyze without cleaning = IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                  Hope this gives a hint as to what is problem.
                  • irwanwrI
                    irwanwr
                    Thank you very very much πŸ˜„
                      Problem possibly identified....
                      Fix will happen without needing to update tool
                        Someone on IE8 please test pluginstore 2 for me?
                        Clear cache beforehand to force new css update
                          More info please....
                          Clicking the toolbar? Clicking the menu entry? What caused the splat?
                          • irwanwrI
                            irwanwr
                            It produced "Bugsplat"
                            Sketchucation Tool 1.1.3 still works fine though.
                              When you're ready to tell us what you did prior to the splat let us know...
                              • irwanwrI
                                irwanwr
                                It just crashed SketchUp.
                                Ed: Restarted SketchUp 8 and it works just fine now πŸ˜„
                                • G
                                  g_wilson
                                  For me - a Eureka moment - works repeatedly open/close Store. Also works after opening IE8 again elsewhere. Also works after closing SU and restarting SU. Thank You for your efforts - This community never ceases to impress.
                                    Can either of your gents please take a screenshot of the PluginStore on your system?
                                    • irwanwrI
                                      irwanwr
                                      Restarted SketchUp 8, with IE 8; all three Sketchucation Tool buttons works just fine.
                                      Thank you very much, Rich πŸ‘ πŸ˜„
                                      Does it really have anything to do with the tool? Or, the html page?
                                      • G
                                        g_wilson
                                        Yor wish is my command.
                                          Ok, thank you. I see an issue with the icons. Wrongly postioned...
                                          Tomorrow. Thanks for taking the time to help
                                          • irwanwrI
                                            irwanwr
                                            • 19
                                            • 20
                                            • 1 / 20
