    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 264.1k Views 84 Watching
      Mucho gracias
      • jiminy-billy-bobJ
        jiminy-billy-bob
        ๐Ÿ‘
          Anton_S
          Thank you Rich!
          This tool is essential ๐Ÿ‘
          • F
            frlic
            Dear Mr. Rich O'Brien,
            I installed [Plugin] SketchUcation Tools 2.0. I have the SU2013 Pro, Windows XP,
            The problem occurs on the card SketchUcation Plugin v.2.0.0 Store.
            Rows with the letters overlap. Please see attached picture.
            The same error occurs and the SketchUp 8 Pro. In versions SketchUcation Tools 1.2.0 everything was fine.
            Sorry for the bad English, I can communicate with google translator.
            Nice greetings from Croatian
            Kresimir
            overlapping rows
            FRLIฤ†
            http://www.frlic.hr
              Please empty your 'Internet Explorer' cache and restart the tool...
              In Internet Options set IE NOT to remember your history and clear the cache as it closes.
              You are seeing older css files etc clashing with the newest versions...
              • F
                frlic
                I deleted the complete history in internet explorer, and Chrome. The result is the same as before.The other two cards, you can see well.
                Kreso
                overlapping rows
                FRLIฤ†
                http://www.frlic.hr
                  SketchUp uses IE on PC and Safari on MAC - so you don't have to worry about Chrome, Firefox etc...
                  Are your sure you have completely emptied the cache?
                  What version of Windows and IE do you have running ?
                  • F
                    frlic
                    I once deleted a complete history in Internet Explorer, but without result. On the pictures you can see versions of Explorer and Windows.
                    Kresimir
                    IE
                    IE_1
                    FRLIฤ†
                    http://www.frlic.hr
                      So XP Pro with IE 8 ?
                      Any one with that config having similar issues ?
                      • F
                        frlic
                        Excuse me, but I did not really understand the problem?
                        Thank you for your patience.
                        Kreso
                        FRLIฤ†
                        http://www.frlic.hr
                          It appears to be a css [cascading style sheet] issue.
                          It IE is indeed purging properly then perhaps it's an issue with the OS and/or the version of IE.
                          Could you consider an upgrade your version of IE ?
                          • irwanwrI
                            irwanwr
                            I thought IE 8 is the highest WinXP could use.
                              I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... ๐Ÿ˜„
                              It'll be server-side fixes, so what you currently have installed should work, but then load the fixed html/css once it's sorted...
                              • G
                                g_wilson
                                Same Problem - XP HOME - IE8.
                                Internet Options: delete history on exit.
                                CCcleaner checked to analyze=>Temp Internet Files/History/Cookies/Recently typed URLs/Index.dat files/Last Download Loc'n./Autocomplete Form History.
                                Close Chrome - Close IE8 - Running SU8(last rev) + CCcleaner only.
                                Run CCcleaner=> clean history => CCcleaner re-analyze = 0 bytes.
                                Open Store => problem exists as per described => run CCcleaner (Store still open)=> IE - Temp files 126 KB 33 files and IE - Cookies 1 KB 1 files.
                                (DO NOT clean)=>Close Store => run CCcleaner=> analyze => IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                                Repeatedly opening store+closing store + CCcleaner analyze without cleaning = IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                                Hope this gives a hint as to what is problem.
                                • irwanwrI
                                  irwanwr
                                  Thank you very very much ๐Ÿ˜„
                                    Problem possibly identified....
                                    Fix will happen without needing to update tool
                                      Someone on IE8 please test pluginstore 2 for me?
                                      Clear cache beforehand to force new css update
                                        More info please....
                                        Clicking the toolbar? Clicking the menu entry? What caused the splat?
                                        • irwanwrI
                                          irwanwr
                                          It produced "Bugsplat"
                                          โ“
                                          Sketchucation Tool 1.1.3 still works fine though.
                                            When you're ready to tell us what you did prior to the splat let us know...
                                            • 19
                                            • 20
                                            • 1 / 20
