    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 144.8k Views 84 Watching
      New look, new tools, social sharing and more...
      If you don't have it already grab the .rbz file here
      If you are using version 1.2 just update by Autoinstalling 2.0, and restart SketchUp to effect all of the changes...
      How to install the SketchUcation toolset....
      Installing Plugins and updating Plugins....
      Using Sets....
      • tt_suT Offline
        tt_su
        Shiny! πŸ˜„
          Mucho gracias
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            πŸ‘
              Anton_S
              Thank you Rich!
              This tool is essential πŸ‘
              • F Offline
                frlic
                Dear Mr. Rich O'Brien,
                I installed [Plugin] SketchUcation Tools 2.0. I have the SU2013 Pro, Windows XP,
                The problem occurs on the card SketchUcation Plugin v.2.0.0 Store.
                Rows with the letters overlap. Please see attached picture.
                The same error occurs and the SketchUp 8 Pro. In versions SketchUcation Tools 1.2.0 everything was fine.
                Sorry for the bad English, I can communicate with google translator.
                Nice greetings from Croatian
                Kresimir
                overlapping rows
                FRLIĆ
                http://www.frlic.hr
                  Please empty your 'Internet Explorer' cache and restart the tool...
                  In Internet Options set IE NOT to remember your history and clear the cache as it closes.
                  You are seeing older css files etc clashing with the newest versions...
                  • F Offline
                    frlic
                    I deleted the complete history in internet explorer, and Chrome. The result is the same as before.The other two cards, you can see well.
                    Kreso
                    overlapping rows
                    FRLIĆ
                    http://www.frlic.hr
                      SketchUp uses IE on PC and Safari on MAC - so you don't have to worry about Chrome, Firefox etc...
                      Are your sure you have completely emptied the cache?
                      What version of Windows and IE do you have running ?
                      • F Offline
                        frlic
                        I once deleted a complete history in Internet Explorer, but without result. On the pictures you can see versions of Explorer and Windows.
                        Kresimir
                        IE
                        IE_1
                        FRLIĆ
                        http://www.frlic.hr
                          So XP Pro with IE 8 ?
                          Any one with that config having similar issues ?
                          • F Offline
                            frlic
                            Excuse me, but I did not really understand the problem?
                            Thank you for your patience.
                            Kreso
                            FRLIĆ
                            http://www.frlic.hr
                              It appears to be a css [cascading style sheet] issue.
                              It IE is indeed purging properly then perhaps it's an issue with the OS and/or the version of IE.
                              Could you consider an upgrade your version of IE ?
                              • irwanwrI Offline
                                irwanwr
                                I thought IE 8 is the highest WinXP could use.
                                  I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... πŸ˜„
                                  It'll be server-side fixes, so what you currently have installed should work, but then load the fixed html/css once it's sorted...
                                    g_wilson
                                    Same Problem - XP HOME - IE8.
                                    Internet Options: delete history on exit.
                                    CCcleaner checked to analyze=>Temp Internet Files/History/Cookies/Recently typed URLs/Index.dat files/Last Download Loc'n./Autocomplete Form History.
                                    Close Chrome - Close IE8 - Running SU8(last rev) + CCcleaner only.
                                    Run CCcleaner=> clean history => CCcleaner re-analyze = 0 bytes.
                                    Open Store => problem exists as per described => run CCcleaner (Store still open)=> IE - Temp files 126 KB 33 files and IE - Cookies 1 KB 1 files.
                                    (DO NOT clean)=>Close Store => run CCcleaner=> analyze => IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                                    Repeatedly opening store+closing store + CCcleaner analyze without cleaning = IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                                    Hope this gives a hint as to what is problem.
                                    • irwanwrI Offline
                                      irwanwr
                                      Thank you very very much πŸ˜„
                                        Problem possibly identified....
                                        Fix will happen without needing to update tool
                                          Someone on IE8 please test pluginstore 2 for me?
                                          Clear cache beforehand to force new css update
                                            More info please....
                                            Clicking the toolbar? Clicking the menu entry? What caused the splat?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
