    [Plugin] Gradient Tools
    24 Posts 11 Posters 47.9k Views 11 Watching
    • H
      hebeijianke
      @tig said:
      I understand! Any face that is facing 'down' returns VERTICAL too...
      It was intended for roof/land-form slopes which are not usually upside down...
      BUT it's an easy fix... I'll post an update asap...
      THX
      Your are so Warm-hearted
        Here's v1.2 20100813 Downward pointing faces will now report the correct slope.
        http://forums.sketchucation.com/viewtopic.php?p=264130#p264130
        • C
          chloesdad
          Thank you TIG for your continuing wonderful contributions.
          • PixeroP
            Pixero
            For a moment I thought you had found a way of making gradient materials...
              It simply reports the gradients of edges and faces and tags them - all edge/facetags can be relinked to an edge/face ob a menu click. They are put on their own layers for ease of management.
              The use it's intended for is reporting and controlling the gradients of landforms and paths - as you make adjustments you can relink and see if the falls are still acceptable - i.e. not too flat or too steep.
              You can also use it on roofs - checking that 'flat' roofs have adequate falls, tiled/slated/shingle roofs have suitable slopes and valleys etc are steep enough.
              The tool tags edges or faces as I found that sometimes you need edges like valley centerlines but it's possible to have a face with no edges directly up/down the gradient, then you need to tag the face gradient... 🤓
              [You can make Gradient Materials using a suitably graded Texture Image - see http://forums.sketchucation.com/viewtopic.php?p=149747#p149747 ]
                Here's v1.3 20100814 A 'Relink ALL Tags' menu option has been added.
                  Would it be possible to make this, TIG?
                  See the link - it's already been done ? Or am I missing something ??
                  • PixeroP
                    Pixero
                    Sorry if I used the wrong word, but I was thinking of a procedural ramp texture.
                    Something like this: http://www.pixero.com/tutorials_ramp.html
                    • F
                      frekky12
                      Hello Tig,
                      I'm new to this plugin and have just downloaded it and am trying to understand how the ratio is representing the gradient.
                      Is there a way to represent this ratio in degrees?
                        @frekky12 said:
                        Hello Tig,
                        It's a rise over run thing. 1:1 would be one unit of rise and one unit of run or 45°.
                        You can get the angle using the yellow Protractor tool.
                          My Roof tool also has a function to report the angle of a picked roof slope in degrees, A:12 and A:B format...
                            rv1974
                            TIG, many thanks for your efforts!
                            Could there be support for slopes in percent?
                            • gullfoG
                              gullfo
                              optionally http://www.blocklayer.com/PitchAngle.aspx
                              Glenn
                              http://www.runnel.com
                              • H
                                huajiet
                                Thanks TIG for this very handy plugin!
                                I'm barely Ruby-conversant but I'm trying to apply some modifications to your plugin. I have a few questions. Do refer to the attached image.
                                1. I've been able to make the tags report the angle in degrees. How do I limit the tag to 1 decimal point?
                                2. As you might be able to tell from the image, the plugin is reporting the complementary angle (39.6.. degrees) instead of the actual angle of the pitch (50.3 deg, shown in the measurement box at the lower right). how do we rectify this in the script?
                                Thanks and regards,
                                HJ
                                  1. You can fix the number of decimal points in any float [into a string] thus:
                                    ` num = 1.23456
                                    dum = sprintf("%.1f", num)
                                  >> "1.2"`
                                  Here the .1f says 1dp and .3f would do 3dp...
                                  To convert that string back into a float:
                                  dum = sprintf("%.1f", num).to_f
                                  There are many options to this Ruby method...
                                  1. You seem to have it reporting the angle of the face's normal, you could just subtract it from 90 degrees ?
                                    angle = 90.degrees - angle
                                    then convert the angle from radians to degrees before fixing its dp's...
                                    angle = angle.radians
                                  • H
                                    huajiet
                                    1. it works!
                                    2. the problem seems to have righted itself. will keep your solution for reference in case it acts up again.
                                      #EDIT: it seems the problems crops up when the slope's material is in back face.
                                    Thanks TIG. You're a legend!
                                      The fix for that is to model properly !
                                      Alternatively check norm=face.normal, then norm.z if it's <0 then norm.reverse!
