    [Plugin] Gradient Tools
    24 Posts 11 Posters 47.5k Views 11 Watching
    • PixeroP
      Pixero
      Sorry if I used the wrong word, but I was thinking of a procedural ramp texture.
      Something like this: http://www.pixero.com/tutorials_ramp.html
      • F
        frekky12
        Hello Tig,
        I'm new to this plugin and have just downloaded it and am trying to understand how the ratio is representing the gradient.
        Is there a way to represent this ratio in degrees?
          @frekky12 said:
          Hello Tig,
          It's a rise over run thing. 1:1 would be one unit of rise and one unit of run or 45°.
          You can get the angle using the yellow Protractor tool.
            My Roof tool also has a function to report the angle of a picked roof slope in degrees, A:12 and A:B format...
              rv1974
              TIG, many thanks for your efforts!
              Could there be support for slopes in percent?
              • gullfoG
                gullfo
                optionally http://www.blocklayer.com/PitchAngle.aspx
                Glenn
                http://www.runnel.com
                • H
                  huajiet
                  Thanks TIG for this very handy plugin!
                  I'm barely Ruby-conversant but I'm trying to apply some modifications to your plugin. I have a few questions. Do refer to the attached image.
                  1. I've been able to make the tags report the angle in degrees. How do I limit the tag to 1 decimal point?
                  2. As you might be able to tell from the image, the plugin is reporting the complementary angle (39.6.. degrees) instead of the actual angle of the pitch (50.3 deg, shown in the measurement box at the lower right). how do we rectify this in the script?
                  Thanks and regards,
                  HJ
                    1. You can fix the number of decimal points in any float [into a string] thus:
                      ` num = 1.23456
                      dum = sprintf("%.1f", num)
                    >> "1.2"`
                    Here the .1f says 1dp and .3f would do 3dp...
                    To convert that string back into a float:
                    dum = sprintf("%.1f", num).to_f
                    There are many options to this Ruby method...
                    1. You seem to have it reporting the angle of the face's normal, you could just subtract it from 90 degrees ?
                      angle = 90.degrees - angle
                      then convert the angle from radians to degrees before fixing its dp's...
                      angle = angle.radians
                    • H
                      huajiet
                      1. it works!
                      2. the problem seems to have righted itself. will keep your solution for reference in case it acts up again.
                        #EDIT: it seems the problems crops up when the slope's material is in back face.
                      Thanks TIG. You're a legend!
                        The fix for that is to model properly !
                        Alternatively check norm=face.normal, then norm.z if it's <0 then norm.reverse!
                        • 2 / 2
