    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.3k Views 109 Watching
    • Bob JamesB Offline
      Bob James
      This is so incredibly useful it takes my breath away.
      There isn't a smilie that comes close to expressing how great this plugin is even in a beta state.
      • Rich O BrienR Online
        @JBB
        I added it but for future updates you can familiarize yourself with the links below
        (sketchucation.com)
        http://sketchucation.com/forums/viewforum.php?f=382
        http://sketchucation.com/forums/viewtopic.php?f=382&t=52516
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Thanks a lot for your kind words, guys. I'm glad you like it.
          Great, thanks ! πŸ˜‰
          • kenK Offline
            ken
            Installed your plugin. Hope this is the type of feedback you wish to have.
            Image 1 - Error received after trying to open layer panel menu.
            Image 2 - Error received after trying to save the file as template.
            Hope this helps.
            Sketchup V13 pro
            Window 7
            Thanks for this plugin. Hope you get it working.
            Ken
            • O Offline
              onkravets
              Very nice and useful plugin.
              Thank you!
                tald311
                Awesome. Another very needed plugin to help sort and organize. This will get a ton of use.
                THANK YOU
                Daniel
                  jiminy-billy-bob
                  Ken > Your first bug was coming from layers created before the plugin installation, this new version 0.2 should fix it : http://sketchucation.com/resources/pluginstore?pln=Layers_Panel
                  Not sure about the second... Do you have this problem with every file you're trying to save as template, even a brand new one ?
                  • kenK Offline
                    ken
                    I can save a template files OK. No problems.
                    And yes the layers were created before installing your plugin. They are layers I had on my template. Will remove all my layers and try again.
                    Thanks for the quick response.
                    Ken
                      jiminy-billy-bob
                      The new version should work ok with old layers. No need to remove them.
                        greatoe
                        It should with some addition/modification of the code. The main problem is that I don't have a mac, so I'll need a mac user to help me testing.
                        I am very much willing to help testing.
                          jiminy-billy-bob
                          That's kind of you, but do you have any knowledge in ruby/javascript development ?
                          • bobpineoB Offline
                            bobpineo
                            Hey this looks promising,thank you!
                            Quick question, can I use the same layer in multiple groups I create?
                            For Instance lets say i wanted group Called "Foundation Plan" and one of the layers in that group was called "CMU Wall"..
                            Could I create another group called "Typical Section" that also had the same "CMU Wall" inside that new group?
                            Also, could this plugin be used to open an existing drawing with Layers, and the layers already created automatically show up in the dialogue box you have created?
                            The Previously created layer names don't show up
                            Best.
                            BP
                            Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                              jiminy-billy-bob
                              Nope. And even if I tried to mkde the plugin to allow that, I already see a number of problems...
                              Best.
                              BP
                              Weird, it should work. Are you using version 0.2 ? What is your windows version, and internet explorer version ? Can you send me the file ?
                              • utilerU Offline
                                utiler
                                Gee I hope a 'trimbler' is lurking here.... so much can be learnt from a user driven solution!!!! And soooo needed for sooo long.....!!!!!!!
                                I've posted here previously about combining Outliner and Layer functionality and here it is!
                                Plugin of the year for sure! Well done mate! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                Just Curious...
                                • utilerU Offline
                                  utiler
                                  Hey JBB, one question before I try it out: when you add a layer is that layers' visibility only visible in the current scene? If not can it be???? So tedious when adding a layer to then have to go through all other scenes to turn it off it you only want it visible in one scene.
                                  Just Curious...
                                    jiminy-billy-bob
                                    Not yet, this option is on my todo list πŸ˜‰
                                    In the meantime, you can use another plugin to do that, Layers Panel should work with anything adding layers.
                                    • utilerU Offline
                                      utiler
                                      Thanks mate, look forward to your updates!! πŸ‘
                                      Just Curious...
                                        jiminy-billy-bob
                                        In my stats, I see some users on Mac OSX using Layers Panel several days in a row. So I'm guessing it's kind of working on OSX. Can someone tell me exactly what's working and what's not ? Thanks πŸ˜„
                                          glro
                                          Vismap does what you are asking for
                                          http://sketchucation.com/forums/viewtopic.php?t=23029
                                          • EdsonE Offline
                                            Edson
                                            this looks to be a great plugin. I would not want to miss out on it! however, I am a mac user. 😞 any chance of it working on mac os in the near future? πŸ˜„
                                            http://www.mahfuz.arq.br
                                            • 33
                                            • 34
                                            • 3 / 34
