    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 321.9k Views 110 Watching
      db11
      I've been waiting for this forever...
      It does not work on OSX !
      I tested it on windows 7 and 8, with Sketchup 8 and 2013, and Internet Explorer 10.
      Does that mean I'll just have to wait longer β€” i.e. it doesn't work YET on OSX, but should with additional testing / debugging β€” or is it that it CAN'T work on OSX?
      Really hoping that a future release will include OSX compatibility. Great work in any case!
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        It should with some addition/modification of the code. The main problem is that I don't have a mac, so I'll need a mac user to help me testing.
        • Bob JamesB Offline
          Bob James
          This is so incredibly useful it takes my breath away.
          There isn't a smilie that comes close to expressing how great this plugin is even in a beta state.
            @JBB
            I added it but for future updates you can familiarize yourself with the links below
            404 Not Found
            (sketchucation.com)
            404 Not Found
            (sketchucation.com)
            404 Not Found
            (sketchucation.com)
            404 Not Found
            (sketchucation.com)
              jiminy-billy-bob
              Thanks a lot for your kind words, guys. I'm glad you like it.
              Great, thanks ! πŸ˜‰
              • kenK Offline
                ken
                Installed your plugin. Hope this is the type of feedback you wish to have.
                Image 1 - Error received after trying to open layer panel menu.
                Image 2 - Error received after trying to save the file as template.
                Hope this helps.
                Sketchup V13 pro
                Window 7
                Thanks for this plugin. Hope you get it working.
                Ken
                • O Offline
                  onkravets
                  Very nice and useful plugin.
                  Thank you!
                    tald311
                    Awesome. Another very needed plugin to help sort and organize. This will get a ton of use.
                    THANK YOU
                    Daniel
                      jiminy-billy-bob
                      Ken > Your first bug was coming from layers created before the plugin installation, this new version 0.2 should fix it : http://sketchucation.com/resources/pluginstore?pln=Layers_Panel
                      Not sure about the second... Do you have this problem with every file you're trying to save as template, even a brand new one ?
                      • kenK Offline
                        ken
                        I can save a template files OK. No problems.
                        And yes the layers were created before installing your plugin. They are layers I had on my template. Will remove all my layers and try again.
                        Thanks for the quick response.
                        Ken
                          jiminy-billy-bob
                          The new version should work ok with old layers. No need to remove them.
                            greatoe
                            I am very much willing to help testing.
                              jiminy-billy-bob
                              That's kind of you, but do you have any knowledge in ruby/javascript development ?
                              • bobpineoB Offline
                                bobpineo
                                Hey this looks promising,thank you!
                                Quick question, can I use the same layer in multiple groups I create?
                                For Instance lets say i wanted group Called "Foundation Plan" and one of the layers in that group was called "CMU Wall"..
                                Could I create another group called "Typical Section" that also had the same "CMU Wall" inside that new group?
                                Also, could this plugin be used to open an existing drawing with Layers, and the layers already created automatically show up in the dialogue box you have created?
                                The Previously created layer names don't show up
                                Best.
                                BP
                                Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                  jiminy-billy-bob
                                  Nope. And even if I tried to mkde the plugin to allow that, I already see a number of problems...
                                  Best.
                                  BP
                                  Weird, it should work. Are you using version 0.2 ? What is your windows version, and internet explorer version ? Can you send me the file ?
                                  • utilerU Offline
                                    utiler
                                    Gee I hope a 'trimbler' is lurking here.... so much can be learnt from a user driven solution!!!! And soooo needed for sooo long.....!!!!!!!
                                    I've posted here previously about combining Outliner and Layer functionality and here it is!
                                    Plugin of the year for sure! Well done mate! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                    Just Curious...
                                    • utilerU Offline
                                      utiler
                                      Hey JBB, one question before I try it out: when you add a layer is that layers' visibility only visible in the current scene? If not can it be???? So tedious when adding a layer to then have to go through all other scenes to turn it off it you only want it visible in one scene.
                                      Just Curious...
                                        jiminy-billy-bob
                                        Not yet, this option is on my todo list πŸ˜‰
                                        In the meantime, you can use another plugin to do that, Layers Panel should work with anything adding layers.
                                        • utilerU Offline
                                          utiler
                                          Thanks mate, look forward to your updates!! πŸ‘
                                          Just Curious...
                                            jiminy-billy-bob
                                            In my stats, I see some users on Mac OSX using Layers Panel several days in a row. So I'm guessing it's kind of working on OSX. Can someone tell me exactly what's working and what's not ? Thanks πŸ˜„
                                            • 33
                                            • 34
                                            • 1 / 34
