    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 155.2k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @renderiza said:
      Do you think selecting multiple layers to drag them all at once inside a folder possible in the future?
      It would indeed be usefull. I already tried, but I use a jquery plugin for sorting/nesting, I didn't write the feature. I guess I'll have to dig into this πŸ˜„
      • jolranJ Offline
        jolran
        Exellent! I'll give this a go later..
        I suspect you are using Jquery draggable, droppable and sortable, right?
        I'm working on similar things for my "node-editor". So far I get the impression (from all over the place) implementing "multiselect" is a bit funky. At least if you would like to do some kind of rectangle-select-multi-thingy and use thoose 3 UI features mentioned. I hope I'm wrong, cause it would be great if it could be done easily and stable.
        Anyhooo... Here's a snippet that at least let you select multiple and drag them..
        Now, sorting/dropping them is another thing..
        Multi Drag Demo - ThreeDubMedia - JSFiddle - Code Playground
        JSFiddle - Test your JavaScript, CSS, HTML or CoffeeScript online with JSFiddle.
        (jsfiddle.net)
        (hint use ctrl to select 1 instance)
        edit: Sorry posted wrong fiddle:
        (jsfiddle.net)
          jiminy-billy-bob
          Nope, I'm using NestedSortable, and jQueryUI's "Selectable" feature. I'll have to combine the two.
          • jolranJ Offline
            jolran
            Ahh, I see. That's a different matter then..
              db11
              I've been waiting for this forever...
              It does not work on OSX !
              I tested it on windows 7 and 8, with Sketchup 8 and 2013, and Internet Explorer 10.
              Does that mean I'll just have to wait longer β€” i.e. it doesn't work YET on OSX, but should with additional testing / debugging β€” or is it that it CAN'T work on OSX?
              Really hoping that a future release will include OSX compatibility. Great work in any case!
                jiminy-billy-bob
                It should with some addition/modification of the code. The main problem is that I don't have a mac, so I'll need a mac user to help me testing.
                • Bob JamesB Offline
                  Bob James
                  This is so incredibly useful it takes my breath away.
                  There isn't a smilie that comes close to expressing how great this plugin is even in a beta state.
                    @JBB
                    I added it but for future updates you can familiarize yourself with the links below
                    (sketchucation.com)
                    http://sketchucation.com/forums/viewforum.php?f=382
                    http://sketchucation.com/forums/viewtopic.php?f=382&t=52516
                    SketchUp Plugins | PluginStore | SketchUcation
                    SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                    (sketchucation.com)
                      jiminy-billy-bob
                      Thanks a lot for your kind words, guys. I'm glad you like it.
                      Great, thanks ! πŸ˜‰
                      • kenK Offline
                        ken
                        Installed your plugin. Hope this is the type of feedback you wish to have.
                        Image 1 - Error received after trying to open layer panel menu.
                        Image 2 - Error received after trying to save the file as template.
                        Hope this helps.
                        Sketchup V13 pro
                        Window 7
                        Thanks for this plugin. Hope you get it working.
                        Ken
                        • O Offline
                          onkravets
                          Very nice and useful plugin.
                          Thank you!
                            tald311
                            Awesome. Another very needed plugin to help sort and organize. This will get a ton of use.
                            THANK YOU
                            Daniel
                              jiminy-billy-bob
                              Ken > Your first bug was coming from layers created before the plugin installation, this new version 0.2 should fix it : http://sketchucation.com/resources/pluginstore?pln=Layers_Panel
                              Not sure about the second... Do you have this problem with every file you're trying to save as template, even a brand new one ?
                              • kenK Offline
                                ken
                                I can save a template files OK. No problems.
                                And yes the layers were created before installing your plugin. They are layers I had on my template. Will remove all my layers and try again.
                                Thanks for the quick response.
                                Ken
                                  jiminy-billy-bob
                                  The new version should work ok with old layers. No need to remove them.
                                    greatoe
                                    I am very much willing to help testing.
                                      jiminy-billy-bob
                                      That's kind of you, but do you have any knowledge in ruby/javascript development ?
                                      • bobpineoB Offline
                                        bobpineo
                                        Hey this looks promising,thank you!
                                        Quick question, can I use the same layer in multiple groups I create?
                                        For Instance lets say i wanted group Called "Foundation Plan" and one of the layers in that group was called "CMU Wall"..
                                        Could I create another group called "Typical Section" that also had the same "CMU Wall" inside that new group?
                                        Also, could this plugin be used to open an existing drawing with Layers, and the layers already created automatically show up in the dialogue box you have created?
                                        The Previously created layer names don't show up
                                        Best.
                                        BP
                                        Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                          jiminy-billy-bob
                                          Nope. And even if I tried to mkde the plugin to allow that, I already see a number of problems...
                                          Best.
                                          BP
                                          Weird, it should work. Are you using version 0.2 ? What is your windows version, and internet explorer version ? Can you send me the file ?
                                          • utilerU Offline
                                            utiler
                                            Gee I hope a 'trimbler' is lurking here.... so much can be learnt from a user driven solution!!!! And soooo needed for sooo long.....!!!!!!!
                                            I've posted here previously about combining Outliner and Layer functionality and here it is!
                                            Plugin of the year for sure! Well done mate! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                            purpose/expression/purpose/....
                                            • 33
                                            • 34
                                            • 4 / 34
