    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • fredo6F
      @JQL
      It is NOT recommended to have LibFredo6 and the other plugins like RoundCorner in different directories.
      It's even not guaranteed it works (for now, but also for the future)
      So please put them together in a single directory.
      • JQLJ
        JQL
        Fredo,
        Thanks for the info.
        Even if I'm used to have additional folders for plugins, now and then I still have to put some plugin into the main folder. So I'll move the plugin to be in the same folder as library.
        Besides that I would like to know if your recommendation is relative to your plugins only, or your advice is that ALL plugins from every developer should be in main folder for plugins?
        If so I'll leave only the plugins being tested in an alternate folder.
        Thanks again and best regards,
        JQL
        www.casca.pt
        Visit us on facebook!
        • fredo6F
          All my plugins are compatible with an alternate Plugins directory but can of course be put in the SU Standard plugin directory as well. Simply LibFredo6 and the plugins should be in the same folder.
          In your case, if you set up an alternate plugin directory, feel free to put LibFredo6 and my plugins there.
          Some plugins hard-code the location of the Plugin and must be instlled in the standard SU Plugin directory. But there are less and less. However, it is good to check.
          • JQLJ
            JQL
            Thanks Fredo, will do!
            www.casca.pt
            • K
              kyel808
              hey hello i try to use "round corner" in sketch up 8 on mac everything works fine apart from the plugin window beeing stuck on either the side or top bottom of the sketchup window which would be okay but its so small i cant really see anything of whats going on. is there a way to un attach it so i can freely move it around or just make it a bit bigger so i can see on where to klick? thanks a lot in advance
              added a screenshot so you guys can see what i mean by small 😄 http://s22.postimg.org/gtchosoo1/Bildschirmfoto_2013_08_07_um_00_28_54.png
                anushma
                @kubusipit said:
                I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
                Jeem
                Hello, I seem to have the same problem, my SU 8 crashe... I use Win7 Core2 32 bit with 4 GB RAM. I've tried uninstalling and reinstalling bit to no effect. How can I solve this problem.
                thnks
                  Perhaps it's because you haven't set permissions for the Plugins folder correctly. This is probably the most common reason Win7 users have difficulty making plugins work. This has been covered repeatedly in this thread as well as others.
                    jamalutlo
                    hello
                    MR fredo6
                    when Updated RoundCorner I got problem with my SU is crashing I don't know what is problem
                    sometimes it crushed when it starting to computing but all time when after finish from computing and I want to making it to Group component crush crush SU 😒
                    http://s24.postimg.org/ava5v52dx/image.png
                    http://s22.postimg.org/j1byygyzl/image.png
                      @jamal
                      Have you installed the latest version of the tool AND LibFredo ?
                      Both are needed...
                      Also if you have Vray beta loading it can cause issues with several legit tools...
                      Stop it loading and see it if that was the culprit...
                      • carnereroC
                        carnerero
                        I'm a SketchUp 2013 user I've already installed the RoundCorner plugin and since then when I start using the SketchUp this message appears ....Error Loading File Utilities/utilitiesTools.rb
                        Could not find included file 'Utilities/utilitiesTools.rb'
                        Anybody knows the solutions to avoid this annoying start window?
                          Both are needed...
                          • carnereroC
                            carnerero
                            Yes I do,....but I have the Podium V2 beta, do you think this program may produce the error?, it will be better to uninstall the Podium V2?
                            Many thanks for your quick answer!
                              Yes, some beta renderers like Vray & Podium might mess with legit tools...
                                rayc
                                Hi---
                                I recently found the round corner plugin which works beautifully for the 3d filleting that I needed. Thank you so much for this amazing tool. One think I am wondering is how to enlarge the size of the editing palette. I am running a macbook w/ retina and the palette is hard to read. Let me know. Thanks again.
                                Cheers!
                                _
                                R A Y
                                • fredo6F
                                  The palette is based on 'pixels' of the Sketchup 2D drawing methods. So it is not easy to change that.
                                  What is the definition of your screen?
                                    MaxiOli
                                    I have run into a problem.
                                    I use SketchUp Make 13.0 and after installing both "LIBFREDO6.37" and "RoundCorner 2.4"
                                    I have the following error message:
                                    "Module RoundCorner requires Sketchup version grater than 5.0.160.
                                    Current version is 13.0.4812"
                                    I could not figure out what could be the problem.
                                    Please help!
                                    Thanks in advance!
                                    Olivér
                                      @Olivér
                                      Why have you not installed that Lib?
                                      The correct for v2013 is Lib 5.0c or newer, like it says on the download page... [5.1c IS newer!]...
                                      http://sketchucation.com/forums/viewtopic.php?p=171721#p171721
                                      The updated tool needs a newer Lib to work properly in v2013 !
                                      Please reread the instructions carefully... 😕
                                      • fredo6F
                                        @maxioli said:
                                        Please help!
                                        Thanks in advance!
                                        Olivér
                                        You need to install LibFredo6 5.1. See this post.
                                          rayc
                                          Hi Fredo---
                                          My screen definition is 1440 x 900.
                                          • fredo6F
                                            NEW RELEASE: RoundCorner v2.5a - 30 Aug 13
                                            RoundCorner 2.5 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.2.
                                            RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
                                            There is no functional changes in RoundCorner 2.5. However, this new version circumvents some problems of security restrictions that were often met with version 2.3.
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 74
                                            • 75
                                            • 39 / 75
