    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • fredo6F
      NEW RELEASE: RoundCorner v2.4c - 06 Jul 13
      RoundCorner 2.4 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.0.
      RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
      There is no functional changes in RoundCorner 2.4. However, this new version because circumvents some problems of security restrictions that were often met with version 2.3.
      • fredo6F
        @juanv.soler said:
        thanks for your work
        Did it work OK for you?
          JuanV.Soler
            JuanV.Soler
            yes 👍
            its working OK with the new release located as you told
            • T
              tawny
              Really nice plugin, thanks
              • fredo6F
                @artchi said:
                The opportunity to do offset is not uniform, and is different for each person?
                http://f3.s.qip.ru/17QY0OfBP.png
                Unfortunately, RoundCorner only supports symetrical rounding, in particular because its primary objective is to round corners with 3 or more edges.
                For custom rounding of single edges, I would suggest you have a look at ProfileBuilder by Whaat.
                • ARTchiA
                  ARTchi
                  The opportunity to do offset is not uniform, and is different for each face?
                  • JQLJ
                    JQL
                    Fredo,
                    Thanks for all your hard and useful work.
                    Recently I installed latest version of roundcorner and also installed Libfredo. I'm using additional folders and Roundcorner is installed in an additional folder even if Libfredo is in Sketchup 2013 Pro plugins folder. The plugin works fine so far. However I get this message when I open SU:
                    "You must install Libfredo5.0 or higher to run Fredo6_RoundCorner"
                    As I said Libfredo is installed and the plugin is working, but the folders of the plugin and library are different...
                    Of course I can live with the problem and I can even move the files to be together... but I like to keep all plugins I can, on a shared folder.
                    Thanks and best regards,
                    JQL
                    www.casca.pt
                    Visit us on facebook!
                    • fredo6F
                      @JQL
                      It is NOT recommended to have LibFredo6 and the other plugins like RoundCorner in different directories.
                      It's even not guaranteed it works (for now, but also for the future)
                      So please put them together in a single directory.
                      • JQLJ
                        JQL
                        Fredo,
                        Thanks for the info.
                        Even if I'm used to have additional folders for plugins, now and then I still have to put some plugin into the main folder. So I'll move the plugin to be in the same folder as library.
                        Besides that I would like to know if your recommendation is relative to your plugins only, or your advice is that ALL plugins from every developer should be in main folder for plugins?
                        If so I'll leave only the plugins being tested in an alternate folder.
                        Thanks again and best regards,
                        JQL
                        www.casca.pt
                        • fredo6F
                          All my plugins are compatible with an alternate Plugins directory but can of course be put in the SU Standard plugin directory as well. Simply LibFredo6 and the plugins should be in the same folder.
                          In your case, if you set up an alternate plugin directory, feel free to put LibFredo6 and my plugins there.
                          Some plugins hard-code the location of the Plugin and must be instlled in the standard SU Plugin directory. But there are less and less. However, it is good to check.
                          • JQLJ
                            JQL
                            Thanks Fredo, will do!
                            www.casca.pt
                            • K
                              kyel808
                              hey hello i try to use "round corner" in sketch up 8 on mac everything works fine apart from the plugin window beeing stuck on either the side or top bottom of the sketchup window which would be okay but its so small i cant really see anything of whats going on. is there a way to un attach it so i can freely move it around or just make it a bit bigger so i can see on where to klick? thanks a lot in advance
                              added a screenshot so you guys can see what i mean by small 😄 http://s22.postimg.org/gtchosoo1/Bildschirmfoto_2013_08_07_um_00_28_54.png
                                anushma
                                @kubusipit said:
                                I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
                                Jeem
                                Hello, I seem to have the same problem, my SU 8 crashe... I use Win7 Core2 32 bit with 4 GB RAM. I've tried uninstalling and reinstalling bit to no effect. How can I solve this problem.
                                thnks
                                  Perhaps it's because you haven't set permissions for the Plugins folder correctly. This is probably the most common reason Win7 users have difficulty making plugins work. This has been covered repeatedly in this thread as well as others.
                                    jamalutlo
                                    hello
                                    MR fredo6
                                    when Updated RoundCorner I got problem with my SU is crashing I don't know what is problem
                                    sometimes it crushed when it starting to computing but all time when after finish from computing and I want to making it to Group component crush crush SU 😒
                                    http://s24.postimg.org/ava5v52dx/image.png
                                    http://s22.postimg.org/j1byygyzl/image.png
                                      @jamal
                                      Have you installed the latest version of the tool AND LibFredo ?
                                      Both are needed...
                                      Also if you have Vray beta loading it can cause issues with several legit tools...
                                      Stop it loading and see it if that was the culprit...
                                      • carnereroC
                                        carnerero
                                        I'm a SketchUp 2013 user I've already installed the RoundCorner plugin and since then when I start using the SketchUp this message appears ....Error Loading File Utilities/utilitiesTools.rb
                                        Could not find included file 'Utilities/utilitiesTools.rb'
                                        Anybody knows the solutions to avoid this annoying start window?
                                          Both are needed...
                                          • carnereroC
                                            carnerero
                                            Yes I do,....but I have the Podium V2 beta, do you think this program may produce the error?, it will be better to uninstall the Podium V2?
                                            Many thanks for your quick answer!
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 74
                                            • 75
                                            • 39 / 75
