    1.5k Posts 477 Posters 4.3m Views 477 Watching
      JuanV.Soler
      yes 👍
      its working OK with the new release located as you told
      • T
        tawny
        Really nice plugin, thanks
        • fredo6F
          @artchi said:
          The opportunity to do offset is not uniform, and is different for each person?
          http://f3.s.qip.ru/17QY0OfBP.png
          Unfortunately, RoundCorner only supports symetrical rounding, in particular because its primary objective is to round corners with 3 or more edges.
          For custom rounding of single edges, I would suggest you have a look at ProfileBuilder by Whaat.
          • ARTchiA
            ARTchi
            The opportunity to do offset is not uniform, and is different for each face?
            • JQLJ
              JQL
              Fredo,
              Thanks for all your hard and useful work.
              Recently I installed latest version of roundcorner and also installed Libfredo. I'm using additional folders and Roundcorner is installed in an additional folder even if Libfredo is in Sketchup 2013 Pro plugins folder. The plugin works fine so far. However I get this message when I open SU:
              "You must install Libfredo5.0 or higher to run Fredo6_RoundCorner"
              As I said Libfredo is installed and the plugin is working, but the folders of the plugin and library are different...
              Of course I can live with the problem and I can even move the files to be together... but I like to keep all plugins I can, on a shared folder.
              Thanks and best regards,
              JQL
              www.casca.pt
              Visit us on facebook!
              • fredo6F
                @JQL
                It is NOT recommended to have LibFredo6 and the other plugins like RoundCorner in different directories.
                It's even not guaranteed it works (for now, but also for the future)
                So please put them together in a single directory.
                • JQLJ
                  JQL
                  Fredo,
                  Thanks for the info.
                  Even if I'm used to have additional folders for plugins, now and then I still have to put some plugin into the main folder. So I'll move the plugin to be in the same folder as library.
                  Besides that I would like to know if your recommendation is relative to your plugins only, or your advice is that ALL plugins from every developer should be in main folder for plugins?
                  If so I'll leave only the plugins being tested in an alternate folder.
                  Thanks again and best regards,
                  JQL
                  www.casca.pt
                  • fredo6F
                    All my plugins are compatible with an alternate Plugins directory but can of course be put in the SU Standard plugin directory as well. Simply LibFredo6 and the plugins should be in the same folder.
                    In your case, if you set up an alternate plugin directory, feel free to put LibFredo6 and my plugins there.
                    Some plugins hard-code the location of the Plugin and must be instlled in the standard SU Plugin directory. But there are less and less. However, it is good to check.
                    • JQLJ
                      JQL
                      Thanks Fredo, will do!
                      www.casca.pt
                      • K
                        kyel808
                        hey hello i try to use "round corner" in sketch up 8 on mac everything works fine apart from the plugin window beeing stuck on either the side or top bottom of the sketchup window which would be okay but its so small i cant really see anything of whats going on. is there a way to un attach it so i can freely move it around or just make it a bit bigger so i can see on where to klick? thanks a lot in advance
                        added a screenshot so you guys can see what i mean by small 😄 http://s22.postimg.org/gtchosoo1/Bildschirmfoto_2013_08_07_um_00_28_54.png
                          anushma
                          @kubusipit said:
                          I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
                          Jeem
                          Hello, I seem to have the same problem, my SU 8 crashe... I use Win7 Core2 32 bit with 4 GB RAM. I've tried uninstalling and reinstalling bit to no effect. How can I solve this problem.
                          thnks
                            Perhaps it's because you haven't set permissions for the Plugins folder correctly. This is probably the most common reason Win7 users have difficulty making plugins work. This has been covered repeatedly in this thread as well as others.
                              jamalutlo
                              hello
                              MR fredo6
                              when Updated RoundCorner I got problem with my SU is crashing I don't know what is problem
                              sometimes it crushed when it starting to computing but all time when after finish from computing and I want to making it to Group component crush crush SU 😒
                              http://s24.postimg.org/ava5v52dx/image.png
                              http://s22.postimg.org/j1byygyzl/image.png
                                @jamal
                                Have you installed the latest version of the tool AND LibFredo ?
                                Both are needed...
                                Also if you have Vray beta loading it can cause issues with several legit tools...
                                Stop it loading and see it if that was the culprit...
                                • carnereroC
                                  carnerero
                                  I'm a SketchUp 2013 user I've already installed the RoundCorner plugin and since then when I start using the SketchUp this message appears ....Error Loading File Utilities/utilitiesTools.rb
                                  Could not find included file 'Utilities/utilitiesTools.rb'
                                  Anybody knows the solutions to avoid this annoying start window?
                                    Both are needed...
                                    • carnereroC
                                      carnerero
                                      Yes I do,....but I have the Podium V2 beta, do you think this program may produce the error?, it will be better to uninstall the Podium V2?
                                      Many thanks for your quick answer!
                                        Yes, some beta renderers like Vray & Podium might mess with legit tools...
                                          rayc
                                          Hi---
                                          I recently found the round corner plugin which works beautifully for the 3d filleting that I needed. Thank you so much for this amazing tool. One think I am wondering is how to enlarge the size of the editing palette. I am running a macbook w/ retina and the palette is hard to read. Let me know. Thanks again.
                                          Cheers!
                                          _
                                          R A Y
                                          • fredo6F
                                            The palette is based on 'pixels' of the Sketchup 2D drawing methods. So it is not easy to change that.
                                            What is the definition of your screen?
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 74
                                            • 75
                                            • 39 / 75
