    [Plugin] On Screen Rolling Reel v1.1
    16 Posts 11 Posters 12.9k Views 11 Watching
    • massimoM Offline
      massimo Moderator
      So Rich I see that your pupil TIG is learning fast... πŸ‘
        I can be very persuasive πŸ˜’
        • HumpmetwiceH Offline
          Humpmetwice
          Thanks! Been waiting for this since I seen it used in one of your videos.
          • FletchF Offline
            Fletch
            Very nice, Thank you, TIG and Rich! πŸ‘
            Fletch
              Panga
              [flash=800,600:15898dhh]http://www.youtube.com/v/4cE8X2FM3eQ[/flash:15898dhh]
              It places a piece of screen-text in the top left corner of the screen.
              It lists the last 5 Tools used and their short-cut keys [if any]
              e.g. Select 'Space' , Line 'L' , Move 'M'
              [You can alter the length of the list by changing the '5' in Line#52 below]
              The most recent Tool is the last in the list.
              Plugins etc get listed as 'Plugin...'
              If you erase the screen-text it reappears when you next use another Tool.
              It is 'off' at the startup - you can toggle it on/off with the Plugins menu item 'On Screen Rolling Reel Toggle'...
              Donations:
              by PayPal to info @ revitrev.org
              Version:
              1.0 20110419 First Release.
              1.1 20110420 On/Off Plugins menu toggle added
              [attachment=0:15898dhh]<!-- ia0 -->OnScreenRollingReel.rbz<!-- ia0 -->[/attachment:15898dhh]
              Thanks a lot for this plugin Rich ! I have a little question about the video you post, at some times in the videos, we can see the three axes appears on the mouse position, how do you make that happen ? Is that a script or something else ? I'm interested by this one.
              Regards.
                Windows > Preferences > Drawing > Display Crosshairs πŸ‘
                  Panga
                  Damn...so much time spend on SU and I completely forgot this one 😲 !! Thanks
                    d12dozr
                    Just downloaded this -- thanks Rich and TIG!
                    http://goo.gl/f7ooYh
                    • cottyC Offline
                      cotty
                      Thank you for this nice plugin. The mentioned display of the respective short-cuts doesn't work for me, is there a known reason for this behaviour?
                      my SketchUp gallery
                        barsaglini
                        does not work on new versions?
                        There is another plugin for video lessons?
                          It works just fine in SU2013. How did you install it?
                            barsaglini
                            I do again, and now works fine =D thks
