    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • thkian92T Offline
      thkian92
      Nope, no error message was shown when starting sketchup 2013. The Toolbar doesn't show and I can't find the plugin anywhere. But the older version of your plugin works perfectly in sketchup 2013.
      How did you install version 2.0.6 in order to get it to work?
        DavorP
        Hi Takuji,
        Love the new Fur. Works great for populating grass. Here are a few images populated with Fur using Podium Browser grass instances and rendered with Podium.
        There is one thing I noticed though. Fur paints component instances with currently selected SU material when using Make by Component.
          kashkasha
          @mdm said:
          man this plugin is awesome 😍 🎉 🎉 🎉 🎉 🎉 🎉
          for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🤣 will be available
          great stuff I love it, and it's so much fun 😄
          where can i download it also? its seems everyone is "make-furing" except me... 😕
          • TIGT Online
            Go to the start of the tools thread OR... please learn to use the SCF PluginStore... which can be accessed from the Resources menu above... 😒
              tak2hata
              Hi,Walt.
              I create the test_dialog.html
              test_dialog.html.zip
              please copy this file to fur_en folder.
              test_dialog copy to there
              And open the html file on browser.
              I will modify fur_en to create html file if the html file show sliders
              Hi,Davor.
              Nicely rendered image! 😍
              Architecture need the beautiful grass like this.
              Hi,kashkasha.
              Please get install files on the top of this thread.
              And Enjoy fur_en!
              Hi,TIG.
              Thank you very much for your advice.
              Thanks All.
              by TAK2HATA
                leaosenzala
                @thkian92 said:
                Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                what i did was change the extension rbz to zip then extract to plugin folder
                • TIGT Online
                  Are they really in the folder?
                  Do you have full security access rights to your Plugins folder?
                  Were all files left in the same relationship [subfolders etc] as in the RBZ [ZIP]?
                  Because you didn't bother to complete your User-Info we don't know your OS [although we can guess 64bit PC] or your SUp Version.
                  If you have SUp v8 or v2013 you could far more easily install RBZ files etc in several ways... avoiding any of the complications you outlined...
                  This kind of issue has been discussed many times, in many threads...
                    ChEBaNaNa
                    This Plugin is probably the best Plugin i've ever seen....
                    Big Thanks from Switzerland!!!!! 😃
                    • plot-parisP Offline
                      plot-paris
                      Hey tak2hata,
                      excellent plugin! It is fun to use and a great enhancement for SketchUp.
                      However, sometimes I find it a bit difficult to master. Therefore I have two ideas:
                      1. Some of the settings use units that are not very intuitive. The stiffness for example is measured in a undefined number. Or while the jitter options use percent, the direction and force options use meters (which can be difficult, so that one has to test a lot before achieving the right result).
                        I think it might be better to have those as a percentage as well (0% no effect, 100% full effect). Like that one can see a linear increase of the effect, which makes it easier to understand.
                      2. Some of the settings are not self-explanatory. Do you think it would be possible to add tooltips that show up, when you hover over the setting with your cursor for some time? You know, with a short description of what the setting does...
                      Would be great to hear your opinion on this...
                        bb6
                        谢谢!hebeijianke
                          Sharkyzero
                          I don't seem to be getting the results everybody else is. I make a grass square and make it a component, then I try to use the crowd maker and it puts the grass everywhere else other than what I have selected. Anybody else have this problem? Also, how do you get so much grass? My comp is no slouch and it virtually crashes whenever I try to get more than a little bit in view.
                            tak2hata
                            Hi,Sharkyzero.
                            I need to know your detail to help the problems.
                            Please upload screenshot of your model and crownd maker dialog.
                            crowdmaker
                            Thanks.
                            by TAK2HATA
                              Sharkyzero
                              I just realized something, Tak. I think the fact that I'm not using instances of the grass components is screwing with everything. Let me fiddle around with it some more and I'll see if I can't get it working the way I think it should.
                                tak2hata
                                Hi,Sharkyzero.
                                Good luck for fiddle around with it.
                                Please ask me when you didn't get it working fine.
                                Thanks.
                                by TAK2HATA
                                  chillotti
                                  Hi everybody, I have a problem, I can’t install the plugin Fur Maker, I put the file http://sketchucation.com/resources/pluginstore?pln=fur_en
                                  And also the new icons
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=28092&start=480
                                  in the
                                  Can you help me? Please
                                  Carlo
                                    tak2hata
                                    in the
                                    Carlo
                                    Hi,chillotti.
                                    I guess you didn't use autoinstall from sketchupucation store tool.
                                    You must unzip the rbz file when you manually install it.
                                    Change the extenstion name "rbz" to "zip".and unzip it.
                                    "fur_en.rb" and "fur_en" folder will be shown.
                                    Copy both to plugin folder.
                                    And New Icon file "fur_en.rar" must unzip ,also.
                                    Copy the created png file to "fur_en" folder in plugins folder.
                                    Thanks.
                                    by TAK2HATA
                                      SuperJesus
                                      This was working previously for me but there are certain components that dont seem to want to constrain the surface I select. The preview shows everything in the right place but then they appear randomly spread out in mid air over a huge area when I do it. Its only certain components with the same settings so I don't get it. Has anybody had this issue before?
                                        tak2hata
                                        Hi,SuperJesus.
                                        I guess your problem of fur.
                                        watch video
                                        Please Check the axis origin of the component.
                                        Thanks.
                                        by TAK2HATA
                                        • bulbaB Offline
                                          bulba
                                          thanks tak2hata..
                                          this plugin is very useful
                                          • Y Offline
                                            Yoshi Ikeda
                                            Hy,
                                            The fur plug in work for sketch up 8 Pro BUT it doesnot work in sketch up 2013 Pro,
                                            Any advice?
                                            Regards,
                                            Yoshi Ikeda
                                            • 32
                                            • 33
                                            • 7 / 33
