    SketchUp 2014 Wishlist
    125 Posts 54 Posters 61.1k Views 54 Watching
    • jeff hammondJ
      @mwm5053 said:
      @ Chris thanks for the reply From this it seems they know about it with a work around
      Error 404 (Not Found)!!1
      (support.google.com)
      that's not a workaround. you have your system prefs set up weird (well, not necessarily 'weird'.. just something other than the default OSX behavior.. and I've yet to find an app which benefits from the behavior but there must be some reason for that functionality)
        mwm5053
        I guess I don't understand what your saying my system prefs? I haven't changed from OSX standard pref and I didn't mention this but it's not a all the time thing only occasionally that the space bar opens model info most often when paint bucket is used, also SU pref shortcut key for Tools/select is spacebar.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • jeff hammondJ
          hey walt.. the preferences is :
          System Preferences -> Keyboard -> Keyboard Shortcuts
          at the bottom, you'll see 'full keyboard access'.. the default is to use the tab key for 'text boxes and lists only'
          you may have inadvertently pressed control-f7 which changes the behavior to allow the tab key to cycle through icons etc.. when it's set this way, the geo-location icon at the bottom left of the sketchup window is highlighted then the spacebar activates it.
            mwm5053
            Thanks Jeff it was on all controls I'll change it should work now 👍
            2011 iMac
            V2 Twilight
            • mariochaM
              mariocha
              @arcad-uk said:
              My top two:
              SU - Real arcs/circles.
              Layout - Entity creation tools that retain their layer setting.
              +1
              %(#008000)[Mario C.
                rizkylp
                More Cloud capability, like Plugins in 2013.
                User can store component, material, style, template (SU/LO), scrapbooks, on the cloud.. without having to leave SketchUp. When user use SketchUp elsewhere on another machine, they just sign in with their google account, and they will get all their cloud stuff on all interface. "Cloud button" could be add on Component browser, material properties, style window, etc... that will list all their cloud stuff.
                Cloud Component could be linked to 3dwarehouse stuff.
                SU team should think their own sign in system, such as SUID (Sketch Up ID) to handle all of this, and to identify whether they are Make or Pro user (SU team can control their cloud feature from this identification). Because google is not part of SketchUp anymore, and this will be huge on the future.
                On Pro feature, this SUID can be used as collaboration. Pro user can start Collaboration project, setting security (open public or private), invite other SUID, and they can coordinate each other through chat system inside SketchUp while working through cloud. SU only need to update geometry, material, layer, and user can monitor every progress through log screen (such as "SUID just added layer named ....", "SUID just created component named .... ", etc).
                I believe with this kind of development, SketchUp users will be increasing significantly, especially on country which has fast internet connection.
                Thank you.
                Rizky LP
                SketchUp Pro Indonesia
                • jo-keJ
                  jo-ke
                  To handle all my components on different places, I'm using dropbox. It works perfect.
                  http://www.zz7.de
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    • Undo (or at least cancel) Match Photo modifications.
                      Aerilius
                      Undo scene changes/creations (especially to make plugin actions fully undoable).
                        DOD3R
                        my wish would be layout version of autocad sheets sets hopefully better solution of that sort
                        • bsintzelB
                          bsintzel
                          Basic constraints in order to build moving parts and jointed assemblies.
                          I've taken obfuscating to a whole new level!
                            jedicharles
                            • Allow Welcome box to be hidden at start up.
                            • Unlock Solid Tools for SketchUp Make.
                            • Unlock Dynamic Components for SketchUp Make.
                            http://sketchup3dchallenge.blogspot.com/
                              DOD3R
                              Some easy native way to check commutative volume of nested component with solid parts in it.
                                Do you mean cumulative?
                                • Chris FullmerC
                                  If you do mean cumulative, that would be a fairly simple and fun ruby plugin to write 😄
                                    DOD3R
                                    yes i did meant cumulative.
                                    I would like to see cumulative volume in entity info panel, that is the reason why i am posting it in sketch up 2014 wishes. But Chris if you can do that by some ruby script that would be cool. Maybe the information doesn't have to by in entity info tab it also can be in measurements box or information line next to it.
                                      I would like to be able to input a length and angle for a line and have THAT as the result rather than a loose aproximation. Is it too much to ask for? Is it too much that making a group or component should be a result of intersecting lines and arcs or are we stuck with a system that would have been innacurate when making cart wheels with an adze and by eye measurement?
                                        Deleted, not a good day. I will start again monday after a day to reflect on what I am using this tool for.
                                          Hi Dave, I made the mirror copy by copy and paste in place then flip along axes. Nothing wildly technical about it. I have noticed a problem in the placement of markers and drawing lines or moving lines to an angle. Sometimes the line or angle looks right but problems are emphasised when mirroed objects are placed in the group or component. The number of times I have found this is beyond my count. Essentially put, when you put the double doors into the frame the discrepency is writ large and while it may be my little bit of autism, I cannot abide a model I spent hours on at times being out of true.
                                            Me neither... :s
                                            Got a sample model?
                                            • 4 / 7
