    SketchUp 2014 Wishlist
    125 Posts 54 Posters 50.3k Views 54 Watching
    • jo-keJ Offline
      jo-ke
      @dukejazz said:
      In 2014 sketchup I want is see an animated gif as a texture, so essentially it will be a aanimated movie texture. just like we apply normal textures.
      This would give much more action to skectup
      Hmm. I can remember an older post, that there is a plugin, that makes it possible.
      http://www.zz7.de
        http://sketchucation.com/forums/viewtopic.php?p=293677#p293677
        TIG's Image Animator
          mwm5053
          I'd be happy if they fixed this bug that they have known for the longest time on Mac maybe windows too when you press the space bar (shortcut for select) it opens model info window very annoying.
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • Chris FullmerC Offline
            Hi Walt, I don't see that on my Mac. It sounds like it might be a plugin you have or something that does that? Though, I'm not even sure if a plugin could make that happen.
            Are any other Mac users seeing this?
              mwm5053
              @ Chris thanks for the reply From this it seems they know about it with a work around
              http://support.google.com/sketchup/bin/answer.py?hl=en&answer=166485
              2011 iMac
              V2 Twilight
              • jeff hammondJ Offline
                that's not a workaround. you have your system prefs set up weird (well, not necessarily 'weird'.. just something other than the default OSX behavior.. and I've yet to find an app which benefits from the behavior but there must be some reason for that functionality)
                  mwm5053
                  I guess I don't understand what your saying my system prefs? I haven't changed from OSX standard pref and I didn't mention this but it's not a all the time thing only occasionally that the space bar opens model info most often when paint bucket is used, also SU pref shortcut key for Tools/select is spacebar.
                  2011 iMac
                  V2 Twilight
                    hey walt.. the preferences is :
                    System Preferences -> Keyboard -> Keyboard Shortcuts
                    at the bottom, you'll see 'full keyboard access'.. the default is to use the tab key for 'text boxes and lists only'
                    you may have inadvertently pressed control-f7 which changes the behavior to allow the tab key to cycle through icons etc.. when it's set this way, the geo-location icon at the bottom left of the sketchup window is highlighted then the spacebar activates it.
                      mwm5053
                      Thanks Jeff it was on all controls I'll change it should work now 👍
                      2011 iMac
                      V2 Twilight
                      • mariochaM Offline
                        mariocha
                        @arcad-uk said:
                        My top two:
                        SU - Real arcs/circles.
                        Layout - Entity creation tools that retain their layer setting.
                        +1
                        %(#008000)[Mario C.
                          rizkylp
                          More Cloud capability, like Plugins in 2013.
                          User can store component, material, style, template (SU/LO), scrapbooks, on the cloud.. without having to leave SketchUp. When user use SketchUp elsewhere on another machine, they just sign in with their google account, and they will get all their cloud stuff on all interface. "Cloud button" could be add on Component browser, material properties, style window, etc... that will list all their cloud stuff.
                          Cloud Component could be linked to 3dwarehouse stuff.
                          SU team should think their own sign in system, such as SUID (Sketch Up ID) to handle all of this, and to identify whether they are Make or Pro user (SU team can control their cloud feature from this identification). Because google is not part of SketchUp anymore, and this will be huge on the future.
                          On Pro feature, this SUID can be used as collaboration. Pro user can start Collaboration project, setting security (open public or private), invite other SUID, and they can coordinate each other through chat system inside SketchUp while working through cloud. SU only need to update geometry, material, layer, and user can monitor every progress through log screen (such as "SUID just added layer named ....", "SUID just created component named .... ", etc).
                          I believe with this kind of development, SketchUp users will be increasing significantly, especially on country which has fast internet connection.
                          Thank you.
                          Rizky LP
                          SketchUp Pro Indonesia
                          • jo-keJ Offline
                            jo-ke
                            To handle all my components on different places, I'm using dropbox. It works perfect.
                            http://www.zz7.de
                            • jiminy-billy-bobJ Offline
                              jiminy-billy-bob
                              • Undo (or at least cancel) Match Photo modifications.
                                Aerilius
                                Undo scene changes/creations (especially to make plugin actions fully undoable).
                                  DOD3R
                                  my wish would be layout version of autocad sheets sets hopefully better solution of that sort
                                  • bsintzelB Offline
                                    bsintzel
                                    Basic constraints in order to build moving parts and jointed assemblies.
                                    I've taken obfuscating to a whole new level!
                                      jedicharles
                                      • Allow Welcome box to be hidden at start up.
                                      • Unlock Solid Tools for SketchUp Make.
                                      • Unlock Dynamic Components for SketchUp Make.
                                      http://sketchup3dchallenge.blogspot.com/
                                        DOD3R
                                        Some easy native way to check commutative volume of nested component with solid parts in it.
                                          Do you mean cumulative?
                                            If you do mean cumulative, that would be a fairly simple and fun ruby plugin to write 😄
                                            • 3 / 7
