    [Plugin] SketchUV - now free
    176 Posts 62 Posters 160.7k Views 62 Watching
    • iichiversiiI Offline
      iichiversii
      @rich o brien said:
      There is not a plugin which exports all mapped textures in a model to one texture file.
      Ultimate Unwrap 3D can do this with imported .skp files but I haven't tried it yet. It's also about $50 so more expensive than this plugin.
      Is this feature similar to a Texture generator atlas ❓
      Bring on the Rain...
        blaar75
        Thanks. I will most def buy this once I can get the hang of Roadkill. I was wondering, any future plans on having a add on that will pack the shells on a 2D surface so that the UV map can be exported to be painted in Gimp etc ?
        • W Offline
          Whaat
          Sorry, nothing like that planned right now. Thanks for the suggestion.
            kaas
            I tried using SketchUV to map the trunk of a tree made with the plugin 3dArcStudioTree. I hoped cylindrical mapping would work. Do I have to go the 'roadkill' way or are there any other options to try?
            Greetings, Max
            • cottyC Offline
              cotty
              It should work. Can you share that model so that we can search for the problem?
              my SketchUp gallery
                smicha
                Tube cannot be triangulated before uv-mapping. Otherwise remove triangulation.
                I suggest trying thrupaint for such triangulated tubes - it works great.
                  kaas
                  Here you go...
                  3darcStudioTree_SketchUv.skp
                    smicha
                    1. clean your model (bottom especially)
                    2. use thrupaint
                    the file is attached
                    3darcStudioTree_SketchUv2.skp
                    • W Offline
                      Whaat
                      Price drop - now just $5. Get it here:
                      http://www.smustard.com/script/SketchUV
                        smicha
                        Do you plan to add the function to normalize different sizes of textures - I asked about it in previous posts?
                        • W Offline
                          Whaat
                          Yes, but I can't give you any accurate estimate of when that would be. It could be anywhere from two months to several years away.
                            stpauljason
                            I just bought the plugin, and am very happy with it. I read the user manual as well, and have a question using the path select tool. Is it possible to weld a piece back after it has been cut, like in most UV mapping software. I sometimes accidentally double click on the wrong line, and I hate to have to start the whole line cut again on a large model.
                            I tried holding the Alt, Shift, and Ctrl Keys separately hoping they would activate the opposite of cut, but they did not.
                            Jason
                            • W Offline
                              Whaat
                              Jason
                              Hi Jason,
                              If I understand you correctly, all you have to do is select the edges you want to 'weld' and then right-click on them and select 'soften'. You can also use the soften edges dialog in SketchUp by going to Window->Soften Edges
                              When you 'cut' all you are doing is unsoftening the edge.
                              Hope this helps.
                                Pherim
                                This completes my Sketchup. Have not tried every function but it seems the cylindrical mapping is exactly what I was looking for! Thank you so much this is worth paying for!
                                • ely862meE Offline
                                  ely862me
                                  Hi, Dale
                                  I am using SketchUV mostly for it's selecting features, and I was wondering if you could add a new function to the Path Select Tool. What I need and I think it would be welcome is to be able to select more than one path by pressing the CTRL key as in the native Select tool.
                                  For example I have two exploded circles(or two random contours) and I want to connect those, I use the Path select on one contour, then I press CTRL key and select the next one, then I use Curviloft and "Voila!".
                                  In the actual case we are not able to select more than one path.Or there is a way that I am not aware of ?
                                  Thanks !
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                  • W Offline
                                    Whaat
                                    @ely862me said:
                                    Hi, Dale
                                    Thanks !
                                    Maybe if you weld the paths with the Weld plugin, you might be able to do this. I have not used Curviloft so I am not sure...
                                    Someday, I would like to release the Path Select Tool as a standalone plugin. Maybe then, I could add that feature, too.
                                    Thanks.
                                    • ely862meE Offline
                                      ely862me
                                      I am sorry I have not explained myself better .
                                      By connecting the paths I meant to create a surface between them.
                                      The impediment is that after you select one path you can't select another one. In this case I select one path with the Path Select tool then I hold CTRL and take the Select tool from Sketchup and select the segments one by one(which is very hard and time consuming).
                                      Long story short : Take Path Select Tool and select a path then hold CTRL and select as many paths as you want !(This is what I think it will be very useful!)
                                      Thank you!
                                      • charly2008C Offline
                                        charly2008
                                        Hello,
                                        Is there a way to correct the distortion shown below tool with a UV tool or is the error in the map projection?
                                        Thanks for any help.
                                        Untitled.skp
                                        • FrederikF Offline
                                          Frederik
                                          It looks like it's the map, which isn't good enough... 😐
                                          Here's my attempt with a map from JHT's Planetary Pixel Emporium...
                                          Earth-model.skp
                                          Cheers
                                          Kim Frederik
                                            charly2008
                                            Hi Kim,
                                            thank you for your help and your effort. Also thanks for this link.
                                            Charly
                                            • 6 / 9
