    [Plugin] SketchUV - now free
    176 Posts 62 Posters 162.6k Views 62 Watching
      kaas
      I tried using SketchUV to map the trunk of a tree made with the plugin 3dArcStudioTree. I hoped cylindrical mapping would work. Do I have to go the 'roadkill' way or are there any other options to try?
      Greetings, Max
      • cottyC Offline
        cotty
        It should work. Can you share that model so that we can search for the problem?
        my SketchUp gallery
          smicha
          Tube cannot be triangulated before uv-mapping. Otherwise remove triangulation.
          I suggest trying thrupaint for such triangulated tubes - it works great.
            kaas
            Here you go...
            3darcStudioTree_SketchUv.skp
              smicha
              1. clean your model (bottom especially)
              2. use thrupaint
              the file is attached
              3darcStudioTree_SketchUv2.skp
              • W Offline
                Whaat
                Price drop - now just $5. Get it here:
                http://www.smustard.com/script/SketchUV
                  smicha
                  Do you plan to add the function to normalize different sizes of textures - I asked about it in previous posts?
                  • W Offline
                    Whaat
                    Yes, but I can't give you any accurate estimate of when that would be. It could be anywhere from two months to several years away.
                      stpauljason
                      I just bought the plugin, and am very happy with it. I read the user manual as well, and have a question using the path select tool. Is it possible to weld a piece back after it has been cut, like in most UV mapping software. I sometimes accidentally double click on the wrong line, and I hate to have to start the whole line cut again on a large model.
                      I tried holding the Alt, Shift, and Ctrl Keys separately hoping they would activate the opposite of cut, but they did not.
                      Jason
                      • W Offline
                        Whaat
                        Jason
                        Hi Jason,
                        If I understand you correctly, all you have to do is select the edges you want to 'weld' and then right-click on them and select 'soften'. You can also use the soften edges dialog in SketchUp by going to Window->Soften Edges
                        When you 'cut' all you are doing is unsoftening the edge.
                        Hope this helps.
                          Pherim
                          This completes my Sketchup. Have not tried every function but it seems the cylindrical mapping is exactly what I was looking for! Thank you so much this is worth paying for!
                          • ely862meE Offline
                            ely862me
                            Hi, Dale
                            I am using SketchUV mostly for it's selecting features, and I was wondering if you could add a new function to the Path Select Tool. What I need and I think it would be welcome is to be able to select more than one path by pressing the CTRL key as in the native Select tool.
                            For example I have two exploded circles(or two random contours) and I want to connect those, I use the Path select on one contour, then I press CTRL key and select the next one, then I use Curviloft and "Voila!".
                            In the actual case we are not able to select more than one path.Or there is a way that I am not aware of ?
                            Thanks !
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • W Offline
                              Whaat
                              @ely862me said:
                              Hi, Dale
                              Thanks !
                              Maybe if you weld the paths with the Weld plugin, you might be able to do this. I have not used Curviloft so I am not sure...
                              Someday, I would like to release the Path Select Tool as a standalone plugin. Maybe then, I could add that feature, too.
                              Thanks.
                              • ely862meE Offline
                                ely862me
                                I am sorry I have not explained myself better .
                                By connecting the paths I meant to create a surface between them.
                                The impediment is that after you select one path you can't select another one. In this case I select one path with the Path Select tool then I hold CTRL and take the Select tool from Sketchup and select the segments one by one(which is very hard and time consuming).
                                Long story short : Take Path Select Tool and select a path then hold CTRL and select as many paths as you want !(This is what I think it will be very useful!)
                                Thank you!
                                • charly2008C Offline
                                  charly2008
                                  Hello,
                                  Is there a way to correct the distortion shown below tool with a UV tool or is the error in the map projection?
                                  Thanks for any help.
                                  Untitled.skp
                                  • FrederikF Offline
                                    Frederik
                                    It looks like it's the map, which isn't good enough... 😐
                                    Here's my attempt with a map from JHT's Planetary Pixel Emporium...
                                    Earth-model.skp
                                    Cheers
                                    Kim Frederik
                                      charly2008
                                      Hi Kim,
                                      thank you for your help and your effort. Also thanks for this link.
                                      Charly
                                      • SwissmountainS Offline
                                        Swissmountain
                                        Hello and thank you for this much needed plugin.
                                        I am rendering in Modo and need to export my models.
                                        I notice that each polygon gets assigned its own material, creating hundreds of materials and making the export near impossible.
                                        Is this how the plugin is intended to work?
                                        Cogito ergo dum-di-dum
                                        • W Offline
                                          Whaat
                                          Sorry for the late reply.
                                          You need to use the Triangulate feature in SketchUV prior to exporting in order to reduce the number of exported materials. This is explained in the SketchUV tutorials.
                                          Dale
                                          • cottyC Offline
                                            cotty
                                            Does anyone have problems with this plugin and SU14?
                                            my SketchUp gallery
                                            • 6 / 9
