    Your Ideas for SketchUp 2014
    66 Posts 40 Posters 11.6k Views 40 Watching
    • gillesG
      gilles
      Just have a real look at what developers made to improve the basic tools and it would be a great release (just dreaming).
      And for myself, why TSU 13 does not run with Snow Leopard?
        Dynamic Components free for all versions for superboost them! ☀
        They are massively under-employed! 😒
          marcdurant
          Hi Rich-
          Thanks for posting this link.
          We do have a database of existing issues and feature requests, and we're already working on some of these items for 2014. John's thread is your opportunity to bring up new requests, and to help us set priorities on existing items.
          I wanted to clear up a misconception that I've seen a few times: LayOut issues do not directly compete with SketchUp issues for resources. LayOut has its own dedicated team! So, don't hesitate to submit LayOut requests.
          thanks,
          Marc
            DOD3R
            from top of my head.
            better UI obviously (toolpalets, docking stuff, two monitors friendlyness, in my opinion ribbon wouldby great too)
            field in layout and sketchup. I actually dont know why LO can not autonumber pages, insert name of the viev as a field ...
            foldering layers is nice koncept i miss in SU and LO
            If LO should become more serious i would like to see layout things warohouse (hatches, blocks, linestyles . ..)
            cloud data sounds like a must.
              DOD3R
              some time ago i was thinking about visibility control in su.
              and now we have three different systems. Scenes, layers, hidden/unhidden geometry. We have three tools to control that. Layers, scenes and outliner. I think its possible to combine them into one tool. Scenes are used to remember layer states and geometry isolations and do it as their secondary feature. the are scenes after all so i wouldnt change them, but i thing outliner and layers can be combined into one tool. something like corel draw has, but better. This is just addition to my previous suggestion.
              • soloS
                Just dawned on me watching both threads that maybe it is me, I want stuff that most folk do not, like better UV tools, more poly's, quads, etc.
                Gonna have to give Blender a real go.
                • genma saotomeG
                  genma saotome
                  Here are a couple of small improvements that could be added to the user interface:
                  1. The texture menu is over long. For example, if someone clicks on a face they're going to do 1 of a very short list of functions; doing something with the texture is one but there is nothing about textures in the right mouse click list of applicable functions. There should be and what there is should be shorter (get rid of "Done")... so it's more like any other command in SU. It should also have a defined shortcut(s).
                  2. Occupying a small slice of the 2d cad world is a product named Visual Cadd. It's very good for what it does. It has two drawing functions you should consider: filet and Chamfer. Both operate on the idea the user selects two intersecting lines with left mouse clicks and then w/ a right mouse click selects one of the above functions, each of which asks the user to enter the necessary data to complete the task. I have always been surprised that SU never had these basic operations as part of the command set.
                  3. Select by material should operate on "No / Default material". It does not do that now and that too is another big surprise to me.
                  Hopefully not too difficult: I could make good use of Layer Sets; This set is about material types, that set relates to construction, etc. etc. Allow primitives be assigned multiple layers so long as each is part of a different set.
                  Last but not least, use a newer version of Ruby please.
                  • HieruH
                    Hieru
                    I'm in the same boat.
                    I could draw up a long list of things I would like to see, but prioritising and thinking about improvements that would really help on a day to day basis, then it really only comes down to UV tools, more polys and quads.*
                    The death of plane clipping is a given that would also really help - as would much faster group explode for complex meshes (essential for certain types of exporting). Obviously we have a workaround for dealing with vanishing faces at a small scale, but it would be very handy to not have to worry about that.
                    It would be fairly useful to see UI changes like Photoshop style SU layers, docking menus, or even a simple shortcut to toggle tool visibility. I wouldn't regard these changes as high priority though and even suspect that such a UI may render SU more difficult to use for some people.
                    *To be clear I'm not merely talking about navigating high poly models. Obviously a good use of components and layers means that it is already possible to handle fairly large models (improvements in this area would of course be appreciated). I'm thinking more in terms of how SU plugins and native menus and tools tend to hang or take forever to work/appear when the poly count gets high.
                    www.davidhier.co.uk
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      Small question about the clipping plane issue :
                      If it's resolved and we can zoom in forever on details, how can we zoom in through a face ? Like you zoom out and get stuck inside au volume, curently you zoom in to get to the other side of the face. It wouldn't be possible any more.
                        d12dozr
                        @genma saotome said:
                        3. Select by material should operate on "No / Default material". It does not do that now and that too is another big surprise to me...
                        👍 Yes, I wish this worked too.
                        http://goo.gl/f7ooYh
                        • jeff hammondJ
                          not sure exactly but I do use two other applications which are lion and up so it seems more on the apple side of things as to why this is happening
                          • HieruH
                            Hieru
                            That's a good point - I hadn't thought of that. Maybe we need a camera collision option that can be turned on or off depending on whether you need clipping.
                            www.davidhier.co.uk
                              Aerilius
                              While I think that is a great idea (and resolves the UX problem of zooming in vs. jumping through a face), I believe someone would weigh in that then people would start pushing the "small details frontier" (as already the polycount frontier).
                                Are people posting their suggestions in this thread also posting in the thread of the link in the original post?
                                • yorik1984Y
                                  yorik1984
                                  1. Make Linux-version.
                                  2. Support x64 and multi-core processors.
                                  • arail1A
                                    arail1
                                    Or MODO
                                    • U
                                      unearthed
                                      Implementing true arcs and circles would be a real game-changer,
                                      but would it be possible?
                                      Enable Excel to read SU directly (and OpenOffice etc.) - autocad can do this but it's a pita. Few other CADs have this.
                                      OR put an integrated worksheet into SU to enable .excel-like analysis. Oh and make sure it can handle real job-size projects - a large planting plan can easily involve 500,000 plants.
                                      AND/OR better support for component export to enable analysis in other programs, for instance counting plants - this IS possible, but lacking true-circles even the simplest symbol becomes a multitude of triangles (within a symbol) and needs cleaning up.
                                      Seconding an option to have LO integrated into SU or at least open the api (as noted above) - maybe there could be two versions? or a way to completely switch LO off to free up resources for SU.
                                      Also I do not know if 2013 LO has implemented this, but in SU8 LO it was not possible to have a symbol at different rotations on different LO pages, e.g. The North arrow.
                                      Fix the thousands of toolbars in registry issue that we all have to deal with.
                                      Fix plane clipping! - a bit of a passion-killer when you're doing a live present!
                                      The ability to parse a feed from surveying equipment - from total stations to hand-held laser distance meters - to enable real-time site drawings. This could/would also enable SU to show dynamic info such as sensor data as a 3D field.
                                      At the moment SU works well for me, but Rhino and Formz are improving all the time and when they have my point 2 above and improved their LO equivalents I will probably switch.
                                      Growplan - People ∩ Plants ∩ Place
                                      windows 7 64b, 4GB RAM, SU 8.0.16846
                                      Gimp, QGIS, Vectorworks 12, Bricscad 11
                                      • N
                                        numerobis
                                        Why do we have a second 2014 wishlist thread now?!?
                                        (even the first one is too much, when i see how many requests of the SU9 thread made it into the 2013 release... relabel the SU9 thread to 2014 and we're done!)
                                        btw. how can i post a request in the google thread? By clicking on "Click here to Reply" below JB's post or "Me, too!" or "Post a question"? Very unclear system over there...
                                          This isn't a wishlist
                                          The SU9 wishlist was for 2013 so why are you looking for that?
                                          • N
                                            numerobis
                                            yes, i know... but it looks like it's becoming a wishlist now
                                            i meant you can just rename it, because the content, the requests in the new thread will be almost the same... 99,9% of the wishes in the SU9/2013 thread haven't been fulfilled in the 2013 release so i think the "new" wishes will be the old ones...
                                            • 2 / 4
