[Plugin] 2D Tools
Get the latest version from the SketchUcation PluginStore
http://sketchucation.com/resources/pluginstore?pln=2Dtools
or why not use the AutoInstall feature of the 'SketchUcation Plugin Store' toolset's dialog... -
the disappointment of the forgotten attachment strikes a crushing blow.
Awesome update TIG! Thanks! You've brought line weight and styles to SU!!!!! Setting the Z plane and toggling to construction lines were things I asked for initially....thanks for implementing them!!!
Does the Z-Plane set the elevation the lines are drawn on, or is it also possible to define a plane that's different than the standard axis?
Only on a flat Z-plane - these are 2D Tools...
Although some like Fillet work in '3D' too... -
2D, yes - just wondered if you could specify the 2D work-plane arbitrary - not just top-down from the world axis.
Already updated with some minor fixes ! http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
Hi TIG, how difficult would a double click to fillet all the corners be? (or something similar)
also: is text tag now redundant?
Couldn't get the 2d line style tool to work?
can't get the line styles to work either. Would it have to do with the styles?
Fillet tool is a nice addition. Thank you TIG!
P.S.I have 2 sets of the same icons on one tollbar. How to solve it? -
TextTag works similarly but sticks onto on 3D Faces and has a few more options like 'face_camera'...
The fillet tool works by picking two edges so your idea might be difficult ? -
P.S.I have 2 sets of the same icons on one tollbar. How to solve it?Please ensure that earlier folders and 2D .rbs have been removed - perhaps (re)do a 'clean' install ?
There's aglitch on the layer creation... I'll issue an update to fix it asap...
v2.3 now available here http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
Tweaks to LineStyle Tools [layer visibility glitch etc] and now CafFather's alternative icon set included [as zip], if desired... -
Line styles still don't work - I can see layers are visible, but lines don't chance.
Check you have materials to show mode is set 'on' - i.e. face materials show up... Check View/Hidden-Geometry is 'off'.
Start the linestyle tool, right-click in empty space, in the dialog that opens set the style to a line-width you know will show up at the size of model (default=1, if the edges are very long than perhaps =6, very small =.25 ???) and then style='Dashed' and color='Red' - so it'll be clearly distinguishable from the original edge. Pick an edge - that edge should get moved onto the ...HIDN layer [and disappear as it's switched 'off'] and a new dashed styled-line 'group' should be made and appear on the ...STYL layer ? Open the Outliner to see what groups you have... Get Entity Info on the edge and new group to check what happens...
Run the tool with the Windows/Ruby Console open and copy/paste us any error messages that you get, if it persists...
Consider posting a small [purged] model with the problem if it's not fixed ?
