    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] CADup
    64 Posts 28 Posters 85.8k Views 28 Watching
      jim w
      Great Plugin !!!
      Thank you so much !!!
      The AXO's are great but I do a lot of "Isometeric Drawings" in CAD that have the base angles (x,y) at 30 degrees instead of the AXO's 45. Would it be possible somehow to get such an Iso at 30 degrees?
      Thanks again for you great work!!!
      Regards
        @jim w said:
        Great Plugin !!!
        Regards
        Iso's are MUCH harder to make than Axo's... that's why you don't get them ๐Ÿ˜‰
        I have a made a separate IsoAxo toolset to set a view to Iso or Axo [with model Z-scaling as needed] - search for that on the forums here...
        I have an upgrade in the pipeline [currently 'blocked'] but that's not on the list ๐Ÿ˜’
          lapx
          Hello Tig,
          Will this be similar to the old ADO autimatic drawings export of pages in dwg or image format. Do you recall this ruby script. It was very easy to use. I think Didier B was the original author. It as also very useful.
          Thanks,
            Not quite like ADO as it assembles actual 2d hidden line 'component's' as flat 2d objects based on the standard views...
            • O Offline
              oscartung
              omg!!! this is so great!
              thank you very much TIG
                MartinK
                Thanks TIG. I will be trying this out to create 2D furniture and fixtures from 3D files. This should make that a pretty simple task.
                  Scaifewang
                  Hi Tig
                  Im way off center here but did you do any further owrk on this superb plugin?
                  Works great getting 2d into DoubleCAD...
                  Regards Scooby
                    It's stalled at this stage - but it still has some useful features ๐Ÿ˜„
                      khancyrus
                      Brilliant Tig!
                      • yorik1984Y Offline
                        yorik1984
                        Thank you for work!
                        Can the script do this tipe of projection of detail?
                        http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
                        And, optionaly, if it posible, user can choose what projection they need.
                          Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
                          It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
                          • V Offline
                            vfz
                            Hey TIG,
                            seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
                            When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
                            the ruby console says
                            "skad
                            Error: #<TypeError: reference to deleted ComponentInstance>
                            <main>:in <main>' -e:1:in eval'
                            nil"
                            what do i do wrong?
                              Unsure.
                              It's an old plugin, but should still work in v2014...
                              Do you always get the error?
                              Can you post of PM a SKP containing the problem component...
                              ๐Ÿ˜•
                              • V Offline
                                vfz
                                Thanks for the fast answer.
                                I tried some different models, in different versions of su (7,8,2013,2014) and I always get the same results.
                                I really feel like an idiot now, but I don't see where can I send pm.
                                  I now have your PM and SKP.
                                  Unfortunately I'm away very shortly but I can look at it in the middle of next week...
                                  • V Offline
                                    vfz
                                    Thanks TIG for the help. I've found my mistake. There were components inside the component.
                                    I exploded everything and made one group/component and your plugin worked like a charm!
                                      Thanks, saves me having to fix it ๐Ÿ˜‰
                                        tombyrne
                                        Ive Recently installed the CADup extension, I tried both ways, through the software and dropping it in the plugins folder, but I cant find it anywhere within the software, it tells me that its installed and ready for use but no sign of it, I looked under plugins and also toolbars,
                                        Any tips?
                                          So, select your Component-Instance OR Group [and nothing else].
                                          Pick 'CADup' off the 'Tools' menu [or type 'cadup' or 'skad' in the
                                          Ruby Console]
                                          Nothing of this works for you?
                                            Ruby Console]
                                            As Pilou says - it appears under the 'Tools' menu as 'CADup'.
                                            It works in all versions of SketchUp from v2015 downwards - at least down to v8, but I suspect Pilou uses it in an even earlier versions. ๐Ÿ˜‰
                                            It is not without its foibles... some text on 'right-hand elevations/sections can get offset somewhat to the right - edit the container and relocate it manually; also the Axo views can sometimes over lap the last Ortho view nearest to them, but they can also be relocated easily...
                                            Sometimes a few edges are missed off...
                                            Its function is really to create a set of 2d Ortho/Axo views from a 3d component.
                                            For DXF/DWG export for use to CAD - the CADup layering allows you to differentiate between hidden lines etc in the CAD display...
                                            • 4 / 4
