    [Plugin] CADup
    64 Posts 28 Posters 97.0k Views 28 Watching
    • srxS Offline
      srx
      THANK YOU SO MUCH FOR THIS VERY USEFUL PLUGIN! ๐Ÿ˜„
      www.saurus.rs
      • TIGT Online
        It's still at an early stage... next will be an interface to let you choose which views to export and several other options.. and perhaps auto-export to CAD format... Watch out for developments...
          mizar
          wonderful
          • TIGT Online
            Update:
            Nothing new yet - I was somewhat bogged down by other issues this week... Designing door ironmongery and Revit stuff ๐Ÿคข et al... I'll try and get this restarted next week ๐Ÿ˜„
            • gullfoG Offline
              gullfo
              a complete awesome plugin TIG! i did find one peculiar behavior with groups created with housebuilder - the xplode function seems to think the entities are deleted. here's the ruby console message:
              Error: #<TypeError: reference to deleted Group>
              C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in explode' C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in xplode'
              ...snip...numerous other lines...
              attached is the SU file which has the housebuilder group.
              test cadup with housebuilder script generated group
              Glenn
              http://www.runnel.com
              • TIGT Online
                It's still 'work in progress' as I finish other paid stuff... I'll look and get back to you...
                • gullfoG Offline
                  gullfo
                  no worries. thanks!
                  Glenn
                    jim w
                    Great Plugin !!!
                    Thank you so much !!!
                    The AXO's are great but I do a lot of "Isometeric Drawings" in CAD that have the base angles (x,y) at 30 degrees instead of the AXO's 45. Would it be possible somehow to get such an Iso at 30 degrees?
                    Thanks again for you great work!!!
                    Regards
                    • TIGT Online
                      @jim w said:
                      Great Plugin !!!
                      Regards
                      Iso's are MUCH harder to make than Axo's... that's why you don't get them ๐Ÿ˜‰
                      I have a made a separate IsoAxo toolset to set a view to Iso or Axo [with model Z-scaling as needed] - search for that on the forums here...
                      I have an upgrade in the pipeline [currently 'blocked'] but that's not on the list ๐Ÿ˜’
                        lapx
                        Hello Tig,
                        Will this be similar to the old ADO autimatic drawings export of pages in dwg or image format. Do you recall this ruby script. It was very easy to use. I think Didier B was the original author. It as also very useful.
                        Thanks,
                        • TIGT Online
                          Not quite like ADO as it assembles actual 2d hidden line 'component's' as flat 2d objects based on the standard views...
                          • O Offline
                            oscartung
                            omg!!! this is so great!
                            thank you very much TIG
                              MartinK
                              Thanks TIG. I will be trying this out to create 2D furniture and fixtures from 3D files. This should make that a pretty simple task.
                                Scaifewang
                                Hi Tig
                                Im way off center here but did you do any further owrk on this superb plugin?
                                Works great getting 2d into DoubleCAD...
                                Regards Scooby
                                • TIGT Online
                                  It's stalled at this stage - but it still has some useful features ๐Ÿ˜„
                                    khancyrus
                                    Brilliant Tig!
                                    • yorik1984Y Offline
                                      yorik1984
                                      Thank you for work!
                                      Can the script do this tipe of projection of detail?
                                      http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
                                      And, optionaly, if it posible, user can choose what projection they need.
                                      • TIGT Online
                                        Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
                                        It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
                                        • V Offline
                                          vfz
                                          Hey TIG,
                                          seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
                                          When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
                                          the ruby console says
                                          "skad
                                          Error: #<TypeError: reference to deleted ComponentInstance>
                                          <main>:in <main>' -e:1:in eval'
                                          nil"
                                          what do i do wrong?
                                          • TIGT Online
                                            Unsure.
                                            It's an old plugin, but should still work in v2014...
                                            Do you always get the error?
                                            Can you post of PM a SKP containing the problem component...
                                            ๐Ÿ˜•
                                            • 2 / 4
