    [Plugin] CADup
    64 Posts 28 Posters 97.0k Views 28 Watching
      philippequimper
      When exporting to .DWG, all the lines are exported in the "0" layer without any sorting.. So I can't re-use efficiently this file in Autocad. Do I miss something?
        Exporting a 2D file makes everything on one layer and ignores arcs etc.
        Do it as 3D and it should export properly.
        When in your CAD app set up 2D views of it... done ๐Ÿ˜„
        • srxS Offline
          srx
          THANK YOU SO MUCH FOR THIS VERY USEFUL PLUGIN! ๐Ÿ˜„
          www.saurus.rs
            It's still at an early stage... next will be an interface to let you choose which views to export and several other options.. and perhaps auto-export to CAD format... Watch out for developments...
              mizar
              wonderful
                Update:
                Nothing new yet - I was somewhat bogged down by other issues this week... Designing door ironmongery and Revit stuff ๐Ÿคข et al... I'll try and get this restarted next week ๐Ÿ˜„
                • gullfoG Offline
                  gullfo
                  a complete awesome plugin TIG! i did find one peculiar behavior with groups created with housebuilder - the xplode function seems to think the entities are deleted. here's the ruby console message:
                  Error: #<TypeError: reference to deleted Group>
                  C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in explode' C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in xplode'
                  ...snip...numerous other lines...
                  attached is the SU file which has the housebuilder group.
                  test cadup with housebuilder script generated group
                  Glenn
                  http://www.runnel.com
                    It's still 'work in progress' as I finish other paid stuff... I'll look and get back to you...
                    • gullfoG Offline
                      gullfo
                      no worries. thanks!
                      Glenn
                        jim w
                        Great Plugin !!!
                        Thank you so much !!!
                        The AXO's are great but I do a lot of "Isometeric Drawings" in CAD that have the base angles (x,y) at 30 degrees instead of the AXO's 45. Would it be possible somehow to get such an Iso at 30 degrees?
                        Thanks again for you great work!!!
                        Regards
                          @jim w said:
                          Great Plugin !!!
                          Regards
                          Iso's are MUCH harder to make than Axo's... that's why you don't get them ๐Ÿ˜‰
                          I have a made a separate IsoAxo toolset to set a view to Iso or Axo [with model Z-scaling as needed] - search for that on the forums here...
                          I have an upgrade in the pipeline [currently 'blocked'] but that's not on the list ๐Ÿ˜’
                            lapx
                            Hello Tig,
                            Will this be similar to the old ADO autimatic drawings export of pages in dwg or image format. Do you recall this ruby script. It was very easy to use. I think Didier B was the original author. It as also very useful.
                            Thanks,
                              Not quite like ADO as it assembles actual 2d hidden line 'component's' as flat 2d objects based on the standard views...
                              • O Offline
                                oscartung
                                omg!!! this is so great!
                                thank you very much TIG
                                  MartinK
                                  Thanks TIG. I will be trying this out to create 2D furniture and fixtures from 3D files. This should make that a pretty simple task.
                                    Scaifewang
                                    Hi Tig
                                    Im way off center here but did you do any further owrk on this superb plugin?
                                    Works great getting 2d into DoubleCAD...
                                    Regards Scooby
                                      It's stalled at this stage - but it still has some useful features ๐Ÿ˜„
                                        khancyrus
                                        Brilliant Tig!
                                        • yorik1984Y Offline
                                          yorik1984
                                          Thank you for work!
                                          Can the script do this tipe of projection of detail?
                                          http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
                                          And, optionaly, if it posible, user can choose what projection they need.
                                            Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
                                            It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
                                            • 2 / 4
