    SketchUp 2014 Wishlist
    125 Posts 54 Posters 58.0k Views 54 Watching
      not happening here Kris
      • Chris FullmerC Offline
        Ahh, the screenshot helps explain kasais question better. I do see the keybaord keys working consistently in SU8 in the Layers Toolbar. I only check the entitity info and the layer dialog window, I did not test the Layer toolbar.
        I can see that it used to work in SU8, but no longer does in SU 2013.
        @Kris, I can't get it to do that on my system. Does anyone else see it act like that?
          huh, still not working for me.
            nada....
            • KrisidiousK Offline
              Krisidious
              to recreate.
              select unnamed group.
              rename in entity info
              hit return don't hit return. this seems to be the issue.
              go to layer drop down, hit down arrow.
              By: Kristoff Rand
                Krisidious
                seems it only happens if I write in entity info and then fail to hit return afterwards and then try to select a layer.
                I'm not sure now... sometimes it happens every time and sometimes not. If it persists I'll make a thread or a report.
                By: Kristoff Rand
                  Yeah, any more info you can find on it would be great. Thanks Kris,
                  • jo-keJ Offline
                    jo-ke
                    handling of more complex models please....
                    http://www.zz7.de
                    • JClementsJ Offline
                      JClements
                      Better/smoother camera animation.
                      Object animation.
                      Better camera tools. Ie., Panning, rotating, and zooming via keyboard.
                      "Repair" of polylines back into circles and arcs which had been altered when executing, for example, follow-me and intersections and ruby scripts. Implement via context menu of a selection or as an option when saving model.
                      A means to size the drawing window to a specific aspect ratio or display temporary vertical and horizontal pixel rulers to use a guide when re-sizing the drawing window.
                      • olisheaO Offline
                        olishea
                        +1
                        Getting sick of sticky "complex" models. You can only switch to wireframe mode so many times before your brain explodes. Will SU ever deal with complex models? I don't see how/why other apps can crunch complex scenes but SU fails, I'm no programmer but I just don't see things progressing in this regard.
                        oli
                          jaceguay
                          Id like to apply diferent styles to earch group or component, or by layer. Could it be only inside Layout.
                          Also something I think a ruby can handle, to toggle a certain group or component to wire-frame mode or shaded mode, could it be by hiding all faces and not the edges or the other way and hiding all the edges and showing only the faces, also a reset button to show all.
                          Could it work like this: it displays in wireframe until double click to edit, then it show all elements, and go back to wireframe when finished editing.
                            kasias
                            It would be nice if Sketchup had views like other 3d modeling programs that can be tiled and enlarged when required + would be nice if it was possible to dock the floating windows with materials, components etc.
                            http://kasia-portfolio.com/SketchUp-Views.jpg
                            And of course the camera could work better when zooming in to detail while working on large model.
                            http://kasia-portfolio.com/SketchUp-Camera-Problem.jpg
                            • dereiD Offline
                              derei
                              What I wish NOT to happen... Despite the fact now it's no sign that it could happen... one cannot know what goes trough Trimble's mind...
                              So, what I wish to stay as it is, is the Simplicity of Sketchup, only basics, no complicated features by default... and everything to remain provided as plugins... so everyone should customize its SketchUp according to particular needs. There are several 3d programs on the market that tried to incorporate EVERYTHING ... and ended being clogged and slow...
                              DESIGNER AND ARTIST DEREI.UK
                                +1
                                  ArCAD-UK
                                  Been there and have absolutely no wish to return. +1 Evolution not revolution.
                                  • Bob JamesB Offline
                                    Bob James
                                      I'll +1 as well πŸ˜„
                                      • jeff hammondJ Offline
                                        ...aside from the fact that someone/some group may have 5+ computers running sketchup and you have to make sure they all get the plugins etc in order to do something crazy like, say, weld a polyline..
                                        sure.. +1 πŸ˜‰
                                        • dereiD Offline
                                          derei
                                          sure.. +1 πŸ˜‰
                                          Well, let's also assume that all 5+ workers KNOW HOW to use sketchup, how to install a plugin, how to search for one if needed... or just hire better workers πŸ’š
                                          • N Offline
                                            numerobis
                                            More than one viewport is complicated? Really?!?
                                            They could keep the one-screen-setting as default to avoid scaring people with so many views...
                                            Or release a plugin that has to be activated in the prefs... this way 90% of the users will never know that multiview is supported.
                                            This simplicity thing is really a joke. You have to install a massive amount of plugins to make sketchup really usable. I have met many people who thought a bit push-pull is all what can be done in SU and dropped it...
                                            But besides this... why couldn't it be an option to select more than one viewport? You don't have to use it, but you can if you need it!
                                            • 2 / 7
