    SketchUp 2014 Wishlist
    125 Posts 54 Posters 59.8k Views 54 Watching
    • K
      kasias
      Xrefs
      And PLEASE bring back they way how the layers used to work!
      I used to be able to change the layer of an element by typing the first letter of the layer name.
      Now it's so clunky - the layers list only displays about 7 names and you need to use the scroll to find the layer you're after. That's so annoying! Step backwards...
      • Chris FullmerC
        @kasias said:
        Xrefs
        Hi Kasias, Is that working very reliably on SU 8? I just tried it out and it looks it conflicts with shortcut keys. And then it also looks like quite a few other keys w/o shortcuts assigned to them also don't work. Is it working better than that for you?
        Either way, it could be a nice feature. I'll make a comment about it. Thanks!
        • KrisidiousK
          Krisidious
          @chris fullmer said:
          @kasias said:
          Xrefs
          Also Chris... when you do use the down arrow on the layers drop down menu, it pushes all toolbars down those 7 spaces... at least in Win 7
          By: Kristoff Rand
            not happening here Kris
            • Chris FullmerC
              Ahh, the screenshot helps explain kasais question better. I do see the keybaord keys working consistently in SU8 in the Layers Toolbar. I only check the entitity info and the layer dialog window, I did not test the Layer toolbar.
              I can see that it used to work in SU8, but no longer does in SU 2013.
              @Kris, I can't get it to do that on my system. Does anyone else see it act like that?
              • Chris FullmerC
                huh, still not working for me.
                  nada....
                  • KrisidiousK
                    Krisidious
                    to recreate.
                    select unnamed group.
                    rename in entity info
                    hit return don't hit return. this seems to be the issue.
                    go to layer drop down, hit down arrow.
                    By: Kristoff Rand
                    • KrisidiousK
                      Krisidious
                      seems it only happens if I write in entity info and then fail to hit return afterwards and then try to select a layer.
                      I'm not sure now... sometimes it happens every time and sometimes not. If it persists I'll make a thread or a report.
                      By: Kristoff Rand
                      • Chris FullmerC
                        Yeah, any more info you can find on it would be great. Thanks Kris,
                        • jo-keJ
                          jo-ke
                          handling of more complex models please....
                          http://www.zz7.de
                          • JClementsJ
                            JClements
                            Better/smoother camera animation.
                            Object animation.
                            Better camera tools. Ie., Panning, rotating, and zooming via keyboard.
                            "Repair" of polylines back into circles and arcs which had been altered when executing, for example, follow-me and intersections and ruby scripts. Implement via context menu of a selection or as an option when saving model.
                            A means to size the drawing window to a specific aspect ratio or display temporary vertical and horizontal pixel rulers to use a guide when re-sizing the drawing window.
                            • olisheaO
                              olishea
                              +1
                              Getting sick of sticky "complex" models. You can only switch to wireframe mode so many times before your brain explodes. Will SU ever deal with complex models? I don't see how/why other apps can crunch complex scenes but SU fails, I'm no programmer but I just don't see things progressing in this regard.
                              oli
                                jaceguay
                                Id like to apply diferent styles to earch group or component, or by layer. Could it be only inside Layout.
                                Also something I think a ruby can handle, to toggle a certain group or component to wire-frame mode or shaded mode, could it be by hiding all faces and not the edges or the other way and hiding all the edges and showing only the faces, also a reset button to show all.
                                Could it work like this: it displays in wireframe until double click to edit, then it show all elements, and go back to wireframe when finished editing.
                                • K
                                  kasias
                                  It would be nice if Sketchup had views like other 3d modeling programs that can be tiled and enlarged when required + would be nice if it was possible to dock the floating windows with materials, components etc.
                                  http://kasia-portfolio.com/SketchUp-Views.jpg
                                  And of course the camera could work better when zooming in to detail while working on large model.
                                  http://kasia-portfolio.com/SketchUp-Camera-Problem.jpg
                                  • dereiD
                                    derei
                                    What I wish NOT to happen... Despite the fact now it's no sign that it could happen... one cannot know what goes trough Trimble's mind...
                                    So, what I wish to stay as it is, is the Simplicity of Sketchup, only basics, no complicated features by default... and everything to remain provided as plugins... so everyone should customize its SketchUp according to particular needs. There are several 3d programs on the market that tried to incorporate EVERYTHING ... and ended being clogged and slow...
                                    DESIGNER AND ARTIST DEREI.UK
                                      +1
                                        ArCAD-UK
                                        Been there and have absolutely no wish to return. +1 Evolution not revolution.
                                        • Bob JamesB
                                          Bob James
                                          • Chris FullmerC
                                            I'll +1 as well πŸ˜„
                                            • 2 / 7
