    Sketchup 2013 issues
    208 Posts 53 Posters 59.1k Views 53 Watching
      archheni
      @jastar123 said:
      On mac there is no plugins folder so I can't manually load Maxwell render 😠 . any advice?
      the plugin folder is now located in: ..user/library/ application support/sketchup2013/sketchup/plugins
        archheni
        @tig said:
        The number of entities added into a context affect SketchUp's processing time of all calls manual and API.
        Each has to be assessed for intersection, merge etc.
        As the numbers increase the time rises almost exponentially as more and more entities are involved...
        Also if the refresh of the graphics is not switch d off that has an effect too...
        Using a
        model.start_operation('xxx', true)
        is the fastest way of processing - especially in v2013...
        I need to check that LatticeMaker has those all set right... 😕
        Edit: bum!
        Although it does because 13 is taken to be < 7 [alphanumerics!] it skips it.
        I'll PM you a test updated version - can you retry and see if the time improves...
        It's now updated to v1.3 in the main thread...
        Thanks for the quick fix TIG! The good news - it's faster than before now on SU13. But I'm still puzzled because every time I run the script I get a different result now - 13min14s; 8min; 9min30s; 9min20s..and 4min58s.
        I did also crash SU13 when I did copy/ paste the geometry into a new file and started the script for a second consecutive time.
        Not sure why it behaves like this..? I will send you the file, maybe you can reproduce the results.
        Thanks for all the efforts!!
        • Tyler MillerT
          Tyler Miller
          @charly2008 said:
          If we are to trust the tool, "Test time display". Then would be "Sketchup 2013," a bit faster. Whether this also has an impact on the plugins I can not judge.
          I see someone has been playing around with their registry settings... 😄
          -Tyler
          • Tyler MillerT
            Tyler Miller
            @penguin2 said:
            Toolbars for Plugins missing.
            Loaded the following from EW:-
            'Selection Toys'
            'Edge Tools2'
            Tried un-checking then re-checking in Toolbar list. Still not visible.
            We're working on a fix for this now. It was a last minute regression that slipped into the release. Sigh. Sorry about that.
            -Tyler
              rv1974
              Shadows- very unpleasant surprise. In v8 it was only the viewport artefact, now the output also get affected ! 😡
              And this clipping issue... 👊
              • jeff hammondJ
                this isn't an 'issue' so much as it's a new behavior (one that i've seen requested a few times here as well as for a certain other drawing app.
                on mac, when you launch sketchup, a sketchup window will be created.. once you close that window, the only way to get a new one is to cmmdN (file->new)
                previously, you'd get a new window by clicking on the dock icon or upon switching back to the app..
                kind of hard to explain without doing the comparison yourself.. i guess i can see why some people might prefer the new behavior but i can also see why someone might prefer the previous behavior.. i'm on the fence and i haven't used 2013 for actual work yet so i don't really know.
                • pbacotP
                  I prefer it. I usually have to close that new window--and it always asks to save (v.8). No other apps I have act the old way, opening an empty file every time you choose the app in the dock.
                  It is more common to want to open an existing file.
                  • jeff hammondJ
                    @pbacot said:
                    I usually have to close that new window--and it always asks to save (v.8)..
                    that's a ruby which is causing the "would you like to save?" behavior when trying to close a fresh window..
                    one of the su9 wishlist items i presented was to have the sketchup app itself preventing this from happening regardless of any 'bad' coding by the ruby author.. i haven't put all of my plugins in 2013 yet to see if it's now being prevented.. i'll try out one of the rogue plugins in a little while to check.
                    • jeff hammondJ
                      ^ yeah, that's still happening in su 2013
                      i used to track down the ruby authors to get them to fix the behavior (as many of them aren't aware of it since they don't have macs to test on) but.. one would get fixed then a new one would pop up so i sort of gave up..
                      there's only one of these plugins that i actually need (rendering) and i just keep it turned off as an extension until i need to use it.. the other ones, i just don't install them..
                      • charly2008C
                        charly2008
                        Can anyone help me? In Sketchup 2013 my sandbox tool is missing. I have checked everything including the Resources folder.
                        • BoxB
                          I notice you have Sketchucation plugin, have you perhaps disabled it in the plugin manager?
                          • BoxB
                            What about the Extensions manager? The last button of the three.
                            • charly2008C
                              charly2008
                              Hi Box,
                              There is no sandbox! On my laptop it is available under su_sandbox.
                              Charly
                              • charly2008C
                                charly2008
                                There it looks like
                                • BoxB
                                  And you have checked, Windows/Preferences/extensions
                                  • KrisidiousK
                                    Krisidious
                                    do you have any extra sandbox.rb, extensions.rb, sketchup.rb files in your plugins folder?
                                    By: Kristoff Rand
                                    • charly2008C
                                      charly2008
                                      Hi Kristoff,
                                      No I did none of this rb's in my plugins folder.
                                        You might have to install it from the Extension Warehouse?
                                        • charly2008C
                                          charly2008
                                          On my laptop was the "sandbox.rb" available. I now have it copied into the plugin folder on my desktop PC. Now I get this error message.
                                          • KrisidiousK
                                            Krisidious
                                            The new sandbox has both a su_sandbox.rb and an su_sandbox folder.
                                            By: Kristoff Rand
                                            • 11
                                            • 9 / 11
