    Sketchup 2013 issues
    208 Posts 53 Posters 45.7k Views 53 Watching
    • jeff hammondJ Offline
      @pbacot said:
      I usually have to close that new window--and it always asks to save (v.8)..
      that's a ruby which is causing the "would you like to save?" behavior when trying to close a fresh window..
      one of the su9 wishlist items i presented was to have the sketchup app itself preventing this from happening regardless of any 'bad' coding by the ruby author.. i haven't put all of my plugins in 2013 yet to see if it's now being prevented.. i'll try out one of the rogue plugins in a little while to check.
        ^ yeah, that's still happening in su 2013
        i used to track down the ruby authors to get them to fix the behavior (as many of them aren't aware of it since they don't have macs to test on) but.. one would get fixed then a new one would pop up so i sort of gave up..
        there's only one of these plugins that i actually need (rendering) and i just keep it turned off as an extension until i need to use it.. the other ones, i just don't install them..
        • charly2008C Offline
          charly2008
          Can anyone help me? In Sketchup 2013 my sandbox tool is missing. I have checked everything including the Resources folder.
          • BoxB Offline
            I notice you have Sketchucation plugin, have you perhaps disabled it in the plugin manager?
            • BoxB Offline
              What about the Extensions manager? The last button of the three.
                charly2008
                Hi Box,
                There is no sandbox! On my laptop it is available under su_sandbox.
                Charly
                  charly2008
                  There it looks like
                  • BoxB Offline
                    And you have checked, Windows/Preferences/extensions
                    • KrisidiousK Offline
                      Krisidious
                      do you have any extra sandbox.rb, extensions.rb, sketchup.rb files in your plugins folder?
                      By: Kristoff Rand
                        charly2008
                        Hi Kristoff,
                        No I did none of this rb's in my plugins folder.
                          You might have to install it from the Extension Warehouse?
                            charly2008
                            On my laptop was the "sandbox.rb" available. I now have it copied into the plugin folder on my desktop PC. Now I get this error message.
                              Krisidious
                              The new sandbox has both a su_sandbox.rb and an su_sandbox folder.
                              By: Kristoff Rand
                                charly2008
                                Hi Thomas,
                                thank you very much. It worked.
                                Also my thanks to box and Kristoff for your effort.
                                Charly
                                  kasias
                                  'Round corners' plugin doesn't work on my Sketchup 2013!!! 😞
                                    Have you ensured you've updated your plugins?
                                    • BoxB Offline
                                      A member three years and you haven't worked out that just saying something doesn't work doesn't help. Nothing in your profile either to give any clues.
                                      Have you installed it properly, have you installed the latest one have you installed the latest lib for it do you have full permissions are you holding your mouth the right way.......my car doesn't work today can you tell me why
                                      • FrederikF Offline
                                        Frederik
                                        Cars are like humans...
                                        Some days are good, some days are bad, where you just don't want to do much...
                                        Think of your car like you think of your loved ones...
                                        Finally make sure to check power and gas supply... 😆
                                        Cheers
                                        Kim Frederik
                                        • utilerU Offline
                                          utiler
                                          @arail1 said:
                                          Interesting to note that I got my first sales pitch from Trimble (for a laser level) - 1/2 day after giving up my info to purchase an upgrade.
                                          So did you buy it? Trimble make the best laser gear around...
                                          Just Curious...
                                            RPahlavan
                                            I just upgraded to SU 2013 but cannot figure out how to install all the plugins from before (especially Curviloft).
                                            I am running a MBP OSX 10.8.4
                                            Trimble online support tells me to copy plugins from SU 8 plugins folder and to:
                                            "Navigate through to Application Support/SketchUp/SketchUp 2013/Plugins. If there is no "Plugins" folder, you will need to create one.
                                            Well, my question is then how to just 'create one'? That bit of advice is not given...
                                            • 11
                                            • 10 / 11
