    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • massimoM Offline
      massimo Moderator
      This is after running cleanup.
        leminilab
        @olishea said:
        @massimo said:
        Only purged (and not tried yet with cleanup), 3,5Mb.
        how many faces? this is the important thing. leaves should be substituted for quad face PNGs.
        Sorry for the following dumb question but I didn't take the time to read all the post or even try the plug-in yet...
        😕 All the leaves are components?
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
        • CadFatherC Offline
          CadFather
          yes
            leminilab
            @cadfather said:
            yes
            Thanks! 😄
            • ppoublanP Offline
              ppoublan
              Dear all,
              I’m really impressed by the number of interesting comments and feedbacks received on this plugin. And I really like the olive tree variations of Massimo. (Encourage everyone to publish their preferred trees made with the plugin).
              Thanks to all of you. I will do my best to improve it in future releases, but as the plugin is free and not my job please be patient. I will need to learn more on dev.
              Here are few bug corrections that include :
              • Reversed faces for the trunk and branches in order for face normals to point outward
              • Changed the scaling function of flowers to be correctly handled by Thea (and other renders)
              • Removed the ruby console
                Version available on http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
                I carefully read all other comments and I’m looking how to integrate them in other devs.
                Yours
                Pascal
              PS: script will be published into the Sketchucation Store, but not ready yet.
              • KrisidiousK Offline
                Krisidious
                Don't feel rushed Pascal... This is an incredible contribution to the community. Very exciting.
                By: Kristoff Rand
                • massimoM Offline
                  massimo Moderator
                  Thanks for the very quick fix Pascal. 👍
                    archigrafix
                    Doesnt seem to work with sketchup 7???
                    Agir comme un homme de pensée, et penser comme un homme d'action...
                      Krisidious
                      What's happening Arch? error? nothing at all?
                      By: Kristoff Rand
                        archigrafix
                        Yes Kris nothing happens at all...just frustration 😲
                        • ppoublanP Offline
                          ppoublan
                          Hi Kris,
                          Sorry for that but I only tested it on SU8 as dev started after SU8 was available. Do not know what functions are not correctly supported by previous versions.
                          Do you get at least the menu in plugins ?
                          I you activate the Ruby console, do you get some messages in the console ?
                          Yours
                          Pascal
                          • V Offline
                            versus
                            I found the problem, perhaps due to a misspelling between lines = begin and = end, this is due only to a point out of place, just before = end, in my case, I have many plugins installed and thought it was due to one that caused the conflict, I tried an installation of SU 8 without additional plugins and charge well, it might be the WXP vs windows vista, in windows vista remove the point of the last sentence of the load file header specifically as follows:
                            original
                            AND FITNESS FOR A PARTICULAR PURPOSE.
                            = end
                            new
                            = end
                            in windows vista files are not loaded when I was at the end point of the line before = end, but in windows xp there was no problem loading the plugin
                            another thing I did was copy the contents of the folder directly in the plugins folder of SU 8
                              archigrafix
                              @ppoublan said:
                              Hi Kris,
                              Yours
                              Pascal
                              Yes the menu is there...When I choice "Make tree" it returns:
                              Error: #<RuntimeError: Can't insert empty component.>
                              (eval):1050:in load' (eval):1050:in initialize'
                              (eval):1042:in each' (eval):1042:in initialize'
                              (eval):1217:in new' (eval):1217:in initialize'
                              (eval):653:in new' (eval):653:in f3das_loadconfiguration'
                              (eval):651:in each' (eval):651:in f3das_loadconfiguration'
                              (eval):4443:in require' (eval):4443:in call'
                              Hope you can help
                                @archgrafix
                                Are you sure that the specified component SKP exists in the tool's subfolder?
                                If so can you open it in SketchUp?
                                If it is getting found, then the 'empty component' error suggest that is either 'empty' [i.e. it contains no entities] or most likely it's been saved as a SketchUp version newer that the version that your current Model is opened in ??
                                So for example, if the SKPs are v2013 and you try to use them in v8 it'll fail, or
                                if the SKPs are v8 and you try to use them in v7 it'll fail and so on... Older version SKPs can be used with newer versions of SketchUp, but not vice versa...
                                The tool's SKPs seem to ship as v8.
                                Have you edited them in v2013, or trying to use them in SketchUp v7 ?
                                So, if you open/edit any component SKP - like those in the tool's subfolder - then be sure to use 'Save_as' on it to put it back as being for an earlier version of SketchUp: so that it is then compatible when inserted as a component in earlier versions that it has just been edited in...
                                PS: Please update your User-Profile to show your OS, Version etc...
                                It helps us to help you...
                                • Alan FraserA Offline
                                  Alan Fraser
                                  Brilliant plugin, Pascal...and very configurable...both during and post production. 👍 👍 👍
                                  The tree on the left is a default Olive...but with simplified leaf geometry (down to 3 faces per leaf). It is now down to only 21,000 faces.
                                  The tree on the right is another default Olive, but with even simpler leaves (1 face) but double the number of leaves; and minus all the small twigs. This is down to only 12,000 faces. It was only 7000 before I doubled the leaf count (by simply selecting the foliage group, duplicating and rotating it.)
                                  3D Figures
                                    Krisidious
                                    You might want to just add that to you signature and save some time.
                                    By: Kristoff Rand
                                    • ppoublanP Offline
                                      ppoublan
                                      @archigrafix said:
                                      @ppoublan said:
                                      Hi Kris,
                                      Yours
                                      Pascal
                                      Hope you can help
                                      This part of code is loading skp files as components. It seems that these files are not read by SU7. The solution may be to load them wiht SU8 and save them as SU7 skp format.
                                        archigrafix
                                        Thanx to help TIG
                                        I have saved all leaves components in version 7 and now I get it to start...
                                        Anyway it creates the trunk but no leaves and I get this error message from ruby console:
                                        Error: #<NoMethodError: undefined method hue2rgb' for #<SketchupExtension::M3darcstudiotree::Cf3das_Colorset:0xf8a1cf0>> (eval):1774:in hsltorgb'
                                        (eval):1648:in initialize' (eval):1628:in each'
                                        (eval):1628:in initialize' (eval):2559:in new'
                                        (eval):2559:in drawstems' (eval):2394:in draw'
                                        (eval):667:in f3das_loadconfiguration' (eval):4443:in require'
                                        (eval):4443:in `call'
                                        • ppoublanP Offline
                                          ppoublan
                                          @archigrafix said:
                                          Thanx to help TIG
                                          I need to debug with SU7. Seems SU7 interprets differently the ruby code. hue2rgb is a local definition within another one (hsltorgb). Should not be a method of the class. (is not with SU8).
                                          Here is the code that is working for SU8 and not SU7 if someone has an idea
                                          def hsltorgb(h, s, l)
                                          		if h<0.0
                                          			h=h+1.0
                                          		if h>1.0
                                          			h=h-1.0
                                          		if s<0.01
                                          			s=0.01
                                          		if s>0.99
                                          			s=0.99
                                          		if l<0.01
                                          			l=0.01
                                          		if l>0.99
                                          			l=0.99
                                          		if(s == 0)
                                          			r = g = b = l
                                          		else
                                          			def hue2rgb(p, q, t)
                                          				if(t < 0)
                                          					t = t + 1.0
                                          				if(t > 1)
                                          					t = t - 1.0
                                          				if(t < 1.0/6.0)
                                          					return p + (q - p) * 6.0 * t
                                          				if(t < 1.0/2.0)
                                          					return q
                                          				if(t < 2.0/3.0)
                                          					return p + (q - p) * (2.0/3.0 - t) * 6.0
                                          				return p
                                          			q = l < 0.5 ? l * (1.0 + s) ; l + s - l * s
                                          			p = 2.0 * l - q
                                          			r = hue2rgb(p, q, h + 1.0/3.0)
                                          			g = hue2rgb(p, q, h)
                                          			b = hue2rgb(p, q, h - 1.0/3.0)
                                          		return [r * 255, g * 255, b * 255]
                                          • ppoublanP Offline
                                            ppoublan
                                            ok I got it.
                                            Need to publish new version.
                                            Really strange that ruby code (without SU calls) not interpreted the same way.
                                            Will fix this today.
                                            Yours
                                            Pascal
                                            • 16
                                            • 17
                                            • 4 / 17
