    SketchUp 2013 ;)
    433 Posts 101 Posters 95.3k Views 101 Watching
      @archheni said:
      Yes, this used to be the workaround. However now it doesn't work anymore. To quote ThomThom: "It only works on native toolbars. Doesn't work on Ruby Toolbars unfortunately."
      I was referring to the new toolbar system on Windows. Didn't realize that OSX ha toolbar problems as well. Though it was just us peecee guys...
        @ilay7k said:
        i see severals from sketchup team, they lost in corners like cowards
        Mind your language - keep it polite.
          @adamb said:
          Just to lighten the mood a tad, don't make the mistake I did and google for "Rhino Extensions" .
          Definitely NSFW!
            john.warburton
            First impressions are that SU 2013 is a seriously underwhelming upgrade, and the new licencing restrictions make it a major step backwards in many ways. I've yet to try it out with a large model, so I'll tentatively reserve judgement, but if the updates continue at the same rate that they have done in the past there seems little obvious advantage to be gained from making the switch from SU 8 unless you make much use of Layout.
            Life's a reach, and then you gybe.
              I've not noticed much change in terms of handling more geometry. But there's indication that some plugins perform faster. I'm still trying to run some profiling.
                tomasz
                @alan fraser said:
                @tomasz said:
                My impression is that SU2013 have been released earlier then expected, because the new feature of "extension warehouse" have had to start competing with SCF "Plugin store" as soon as possible.
                There is no 'competition' the extension warehouse is built right into the program. Sketchucation always has been a great resource and community, but the plain fact remains that most SU users are unaware of its existence...or if they are, they don't visit.
                Right. The "extension warehouse" will reach much broader audience... but it doesn't work in SU8 ((free) for commercial use) 😄
                Now when I think about it, there can be more reasons for this: financial, summer holidays coming in the northern hemisphere... I know well that a middle of a summer is not the best time for a release. 😄
                • jeff hammondJ Offline
                  nah.. i think archeni's testing went astray somewhere along the lines..
                  as far as i can tell, the toolbars on osx are functioning exactly the same in 2013 as 8 and prior.
                    archheni
                    Yes, have edited the previous post already. The customized toolbar can get restored again with the known workaround on Mac - Close File after restart and do a File->New.
                      Aerilius
                      Shouldn't SCF buy them?
                      (Or at least infiltrate, which comes out cheaper)
                        kwistenbiebel
                        Ooooh, what an amusing thread lol 😄.
                        Don't you miss the @Last era ? When all was fresh with a fragrance of pioneering ?
                        Each new version of @Last was a new breath of fresh air.
                        You could actually feel the passion in the work of the developers.
                        Good times 😄
                          My two pence worth. They COULD have built some bridges here and just released the 'upgrade' free. Not exactly something bean counters would like but coming from the viewpoint of a user, the problems in the program that have been ignored for so long could have been smoothed over with a bit of confidence inspiring publicity.
                          I think they missed a seriously good opportunity to start fresh without the prior bad blood being part of the mix, that and a little more information.
                          Sketchup has good points as well as bad and having looked around I will acknowledge this. Why some problems have survived as long as they have confuses me but, bean counters industry wide STILL have too much influence over the fix bugs or bring in shiny new features arguement. My prime premise still stands, why point out the simplicity of sketchup and then struggle to fit new applications within it? Why when there are basic items that require fixing? The change to the extentions is worthwhile imho, I know that independent ruby scripters kept things rolling for some time but frankly this might be a mechanism for proper control, removing scripts that are not worth the download time and ease stability problems.
                          If you want me to list all the issues you obviously missed the last few years here at sketchucation, we all know the things that could and should be simply done to improve the program. My two pence worth.
                          • Alan FraserA Offline
                            Alan Fraser
                            The Extension Warehouse wiindow in SU is just a web dialog box. It works anywhere. You can get to it by merely typing the URL into any browser address bar.
                            3D Figures
                              tomasz
                              @alan fraser said:
                              Do you expect it being added to SU8? I doubt Trimble will release a new revision of the old version.
                                kwistenbiebel
                                Am I reading this right and does Trimble actually consider Sketchucation as a competitor?
                                If so.....OMG ! Lol 😄
                                • FrederikF Offline
                                  Frederik
                                  Good times 😄
                                  I remember similar debates and discussions over the past years... 😆
                                  Cheers
                                  Kim Frederik
                                  • KrisidiousK Offline
                                    Krisidious
                                    Really? Wow... That's a mistake.
                                    By: Kristoff Rand
                                    • jason_marantoJ Offline
                                      jason_maranto
                                      For the record form.z is (and always was) an architectural modeler first and foremost -- however due to it's fine modelling tools it can do almost anything... however it would not be my first choice for figure work. It is also currently 64-bit... I do wish people would check facts before posting false statements just to try to prop up SketchUp.
                                      As I said before, it(form.z) has it's faults... and it's not even my likely replacement for SketchUp. For my needs Modo is likely the software I will move to, however I acknowledge that Modo is a bit more powerful and complex than the average SketchUp user would want or need.
                                      I was asked what software I though could easily replace SketchUp for architectural work, and form.z (or bonzai3d) would be my pick if coming from that POV.
                                      Obviously, if you are very tied into SketchUp via paid plugins then it will be hard to move. However if you are one of the many former free-version users who are now looking to pay $595 for a software that really isn't worth it, and want an alternate option I would recommend checking bonzai3d (and form.z). At $100 less it has more power and the company is growing the tool at a much faster rate than Trimble is growing SketchUp. The workflow is very similar, and the modeling tools are much more powerful... so I think that is a valid recommendation.
                                      If you are really open to new options I would also recommend checking Rhino, MoI3D and Blender. Each have great strengths and all are more worthwhile to invest your time and money into if you are now looking at a $595 (+ $95 each year) bill just to use the same SketchUp you were using for free.
                                      If you are really tied to keeping your workflow free then you should absolutely make the switch to Blender and never look back.
                                      Best,
                                      Jason.
                                        jpalm32
                                        @notareal said:
                                        @bbrown said:
                                        http://www.sketchup.com/products/sketchup-pro/new-in-2013
                                        Sounds like "Zoom In More" is the thing for me... cannot remember how often I have been frustrated with the broken zoom. But if trimble will now release a new version yearly (as paid upgrade), maybe I'll wait the next one that actually offers more than some bug fixes. Sure, LayOut did get a proper update (or so it sounds), but I never use it... and with sketchucation plugin store, I hardly find Extension Warehouse interesting.
                                        Not much here for free users, user that don't use layout or improvements. IMO
                                        Think this is a new platform to start separating free & pro.
                                          Krisidious
                                          I think the new toolbar system and the overall program development in the background of the software are all you get with Make and you can't use it for Professional use, a huge mistake in my opinion.
                                          By: Kristoff Rand
                                            Alan Fraser
                                            How could you possibly infer that from anything I’ve written…especially when I stated earlier that there is no ‘competition’. The SU userbase is orders of magnitude greater than Sketchucation’s.
                                            I’m quite sure the dev team look upon Sketchucation as they have always done…a useful point of contact between a good many of their most avid users and talented 3rd party developers…very useful for almost instant feedback and a source of ideas for future development.
                                            As for the complaint by Tomasz that the Extension Warehouse doesn't work in V8, which software company has EVER rolled out a new version of its software with new features that could be used in earlier versions...especially a version that was released under different ownership, with perhaps all manner of conflicting revenue and royalty implications. That's plain crazy. Isn't that what a new version is all about? And as I said earlier, it does actually work anywhere...just not in the program itself.
                                            While I'm not personally convinced of the advisability of actually charging for this release, it does mark a new direction after the wilderness years with Google. Overdosing on negativity isn't particularly helpful.
                                            3D Figures
                                            • 11
                                            • 12
                                            • 13
                                            • 21
                                            • 22
                                            • 11 / 22
