    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 346 Posters 2.9m Views 344 Watching
    • cottyC Offline
      cotty
      I've tried some scaling and everything works as expected. Can you desribe your goal more detailed?
      my SketchUp gallery
        jdkarg1989
        Hi. I have a question. When I twist an object and conferm my sketchup crashes. What could this be?
        • fredo6F Offline
          Are you working on a Group which has been freshly copied?
            Or is the object very tiny ?
            Or very large ??
              What are the dimensions of the original before bending?
                giorgio1979
                Lovely plugin. πŸ˜„ Another issue: Sometimes when I do a "radial bending by selection of plane" I get some missing faces on the bending side.
                PS: I restarted sketchup, and I cannot reproduce this anymore. Perhaps I set something in Fredolib somewhere during an operation.
                See image:
                http://s11.postimg.org/5vqbc093n/radial_bending_by_selection_of_plane.png
                  giorgio1979
                  Very small, 2mm * 5 mm rectangle, extruded to 5mm.
                  I just tried to reproduce it after a restart but couldn't. Will post back when I have a consistent way to reproduce this. Same dimensions work fine on a clean slate.
                    Typically SketchUp won't fill in tiny faces such as the ones being generated in your bending operation. For that reason it isn't much of a surprise that it didn't work. Perhaps the second time you tried it you weren't making such tiny faces?
                      Got a sample model?
                        Macker
                        Whilst I am almost certain this issue has been raised in this thread, I can't go through 27 pages of reading right now.
                        Does anyone else have sketchup crash completely when using the scale/stretch tool on groups that contain groups? I always use extensive grouping so that I can take my models into 3ds max, and this tool would undoubtedly speed up my workflow - but keeps crashing sketchup.
                        Also, the snaps don't seem to work properly all of the time?
                        Anybody else, or am I doing it wrong?
                        Check out my blog @ http://macviz.blogspot.co.uk
                          Macker
                          Never mind, I found a work-around.
                          To stop the crashes I have to work within the group I'm trying to scale, and select all of the items within the group (provided there are no other sub-groups, otherwise it will crash).
                          This then stops the snaps working properly; it wont let me snap (correctly) to things outside of the group that I am working in - so I have to draw a line within the group to create a snap point, then delete it once I am done.
                            Be interesting to test - to see if it's just on your system. Maybe a plugin conflict...
                            • fredo6F Offline
                              This may be related to the big issues of "freshly copied groups".
                              In your case, was one of the group a copy of another one (you should see "2 instances" in the Entity Info Window.
                              If this is the case, then FredoScale needs some evolutions. I have done it on Curvizard.
                              As a workaround for complex hirearchy of groups and components, try to perform a Make Unique before (Make Unique is also part of FredoScale).
                                timurglobal
                                God bless you, Fredo
                                  jeffery08
                                  ? i just started to use fredo scale and i'm running into a bit of a problem. when i scalle a component for example a cabinet it renames the parts which it should but even if the parts are the same size. so when i run a cut list program it seperates those peices instead of having them on the same line. is there anyway of changeing this?
                                    That's the wrong way to resize a cabinet for the way you want to use the model.
                                    Resize the cabinet the correct way and you won't have this problem. Components that remain the same such as base cabinet sides for face frame stiles don't need to be made unique and won't if you resize the way I show.
                                    • X Offline
                                      xandras_t
                                      Thank you for your great plugings.
                                      I just have a Huge problem. I cant get them to run. I have sketchup pro 7. in the windows tab i have libfredo6 settings. its 4.7c. However, I dont have any fredo collection in tools. i tried copying and pasting many times i just cant get this to work, the same problem with the joint push and pull. this was just a normal copy paste or am I wrong? Please help me out a bit, I kinda have to extrude like 1500 blocks here lol. a whole city!!
                                      Thank you
                                        Have you tried updating your Fredo-plugins?
                                          Jpeters
                                          Not sure if I installed this correct I am using 2013 and well I followed all the steps and everything and it still didnt work what am I doing wrong here is the picture on windows 7 seems people are having a hard time with these scripts. Got a better Idea maybe everyone will enjoy this one also but why not put it automaticaly on the sketchup Plugin Extention for Sketchup 2013 that way it automaticaly installs it and also makes it so we can use it instead of going threw the hassle of it, think that was the reason why teh sketchup team decided to do that so non techi's liek myself dont haev to go threw this hassle
                                            There is the 'SketchUcation Plugin Store' toolset that allows you to AutoInstall it [and hundreds of other plugins/helperstoo]; if you don't have permissions to write to your Plugins folder it should tell you...
                                            There are several reasons that you might have issues with manually installing plugins.
                                            It might be a user doesn't understand how a ZIP or a RBZ archive works, and so they mis-installs that file instead of its contents.
                                            Or the archives contents are manually extracted without keeping the subfolders of files intact.
                                            Or they don't use the built-in installer button for RBZ archives available in Preferences > Extensions.
                                            OR even when they get it right they do not have sufficient security permissions to write folders/files into their Plugins folder [it might look like you have installed the files but Windows can secretly move them into a VirtualStore folder to save-you-from-yourself! Having a link/button named something like 'Compatibility Files...' showing in any folder's window in Windows-Explorer is a sign of this having happened] - if you have recently installed v2013 and have not changed your permissions for the Plugins folder that would be my 'suspect number one' ! By default any folders made in the Windows 'Program Files' tree have limited security permissions to ALL users, even if you are an admin, it doesn't help as ALL users are limited. To fix this - with admin powers [IF you are not one give yourself those powers under the 'Users' Control Panel before continuing...] select the ../SketchUp../Plugins folder's icon and right-click > context-menu > Properties > Security > Edit... and give everyone in the list FULL permissions [tick their top check-boxes] and apply/ok to complete the changes [While you are at it do the same for the Components, Materials and Styles folders as you might want to write to those from time to time too...]. Now you should be able to add subfolders and files to the Plugins folder manually, or much much easier use the readily available AutoInstall features too...
                                            404 Not Found
                                            (sketchucation.com)
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 57
                                            • 58
                                            • 40 / 58
