    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      FredoScale, and more generally Ruby scripts, have problems to deal with fresh copies of group. Under the hood, these groups share a common definition until they are edited.
      So in your case, I would suggest that you
      • either use Make Unique feature of FredoScale
      • Just double click of the Group A and B instances to make them unique
      • T
        Taniouska111
        πŸ˜„
        • B
          bucksbedrooms
          Bug [pretty sure anyway].
          Hi I love this Fredoscale plugin and was going to make a donation but I am getting some buggy results which I hope there is a solution for. Please see attachments.
          Some whole components move or don't move instead of scale.
          Top drawer irratic scaling
          • cottyC
            cotty
            I've tried some scaling and everything works as expected. Can you desribe your goal more detailed?
            my SketchUp gallery
              jdkarg1989
              Hi. I have a question. When I twist an object and conferm my sketchup crashes. What could this be?
              • fredo6F
                Are you working on a Group which has been freshly copied?
                  Or is the object very tiny ?
                  Or very large ??
                    What are the dimensions of the original before bending?
                    • G
                      giorgio1979
                      Lovely plugin. πŸ˜„ Another issue: Sometimes when I do a "radial bending by selection of plane" I get some missing faces on the bending side.
                      PS: I restarted sketchup, and I cannot reproduce this anymore. Perhaps I set something in Fredolib somewhere during an operation.
                      See image:
                      http://s11.postimg.org/5vqbc093n/radial_bending_by_selection_of_plane.png
                      • G
                        giorgio1979
                        Very small, 2mm * 5 mm rectangle, extruded to 5mm.
                        I just tried to reproduce it after a restart but couldn't. Will post back when I have a consistent way to reproduce this. Same dimensions work fine on a clean slate.
                          Typically SketchUp won't fill in tiny faces such as the ones being generated in your bending operation. For that reason it isn't much of a surprise that it didn't work. Perhaps the second time you tried it you weren't making such tiny faces?
                            Got a sample model?
                              Macker
                              Whilst I am almost certain this issue has been raised in this thread, I can't go through 27 pages of reading right now.
                              Does anyone else have sketchup crash completely when using the scale/stretch tool on groups that contain groups? I always use extensive grouping so that I can take my models into 3ds max, and this tool would undoubtedly speed up my workflow - but keeps crashing sketchup.
                              Also, the snaps don't seem to work properly all of the time?
                              Anybody else, or am I doing it wrong?
                              Check out my blog @ http://macviz.blogspot.co.uk
                                Macker
                                Never mind, I found a work-around.
                                To stop the crashes I have to work within the group I'm trying to scale, and select all of the items within the group (provided there are no other sub-groups, otherwise it will crash).
                                This then stops the snaps working properly; it wont let me snap (correctly) to things outside of the group that I am working in - so I have to draw a line within the group to create a snap point, then delete it once I am done.
                                  Be interesting to test - to see if it's just on your system. Maybe a plugin conflict...
                                  • fredo6F
                                    This may be related to the big issues of "freshly copied groups".
                                    In your case, was one of the group a copy of another one (you should see "2 instances" in the Entity Info Window.
                                    If this is the case, then FredoScale needs some evolutions. I have done it on Curvizard.
                                    As a workaround for complex hirearchy of groups and components, try to perform a Make Unique before (Make Unique is also part of FredoScale).
                                    • T
                                      timurglobal
                                      God bless you, Fredo
                                        jeffery08
                                        ? i just started to use fredo scale and i'm running into a bit of a problem. when i scalle a component for example a cabinet it renames the parts which it should but even if the parts are the same size. so when i run a cut list program it seperates those peices instead of having them on the same line. is there anyway of changeing this?
                                          That's the wrong way to resize a cabinet for the way you want to use the model.
                                          Resize the cabinet the correct way and you won't have this problem. Components that remain the same such as base cabinet sides for face frame stiles don't need to be made unique and won't if you resize the way I show.
                                          • X
                                            xandras_t
                                            Thank you for your great plugings.
                                            I just have a Huge problem. I cant get them to run. I have sketchup pro 7. in the windows tab i have libfredo6 settings. its 4.7c. However, I dont have any fredo collection in tools. i tried copying and pasting many times i just cant get this to work, the same problem with the joint push and pull. this was just a normal copy paste or am I wrong? Please help me out a bit, I kinda have to extrude like 1500 blocks here lol. a whole city!!
                                            Thank you
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 58
                                            • 59
                                            • 40 / 59
