    Vray 1.6 open beta
    renderpluginsextensions
    94 Posts 28 Posters 23.0k Views 28 Watching
    • dkendigD Offline
      dkendig
      anteolic - I believe another user has submitted a bug report that sounds similar. Could you please send us a bug report at vfswip@chaosgroup.com? We would like to hear details about your experience with this issue, to ensure that we rectify this for everyone's workflow.
      Devin Kendig
      Developer
      • Gus RG Offline
        Gus R
        Update. Misread an email and apparently I was approved for beta testing. So far so good and it loads up better than the previous version.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • andybotA Offline
          andybot
          @anteolic said:
          I really dont know where to ask this question than i ask here.
          Does vrayforsu 1.6 beta has some limitation or what cause i cant get more prepass in IRRADIANCE MAP than just one.
          There's an option for "multi-pass" (under "advanced options") If it's unchecked, you will only see one pass even though it is doing all the calculations. See if that is the case.
            caecarvalho
            Hi all,
            I'm having problems on windows 8 and SU8 latest MR.
            -The RT doesn't update the sun and shadows position, and used on a havy scene it even crashed my computer by overheating (it turned off- first time this ever heppened with this machine- it's a sager notebook, wich I consider a very well cooled notebook).
            -And seems to be a problem with the progress bar when RT is running, couse it never passes 1%. (I saw in the demostration video that it stays in 97 or 98...)
            -The render needs much more memory than the older version and always runs out of memory in identical scenes that I used to render in the 1.49.01 version with no problems.
            There are many other problems that I found as well. It's definitely unusable for me like it is now.
            I received a link for the video demonstrations of the new features, and I think the guy is using windows 7.It's definitely running way diferent than in my machine with windows 8.
            Does anyone had problems installing on windows 8?
            • dkendigD Offline
              dkendig
              If you haven't done so already, please send us a bug report about this. We haven't seen an out of memory error yet.
              The RT render does not show a progress bar, because generally if you are using RT, you are trying to tweak materials or lighting, rather than producing a final render. It can produce a final result after a while, but generally it's used for previewing.
              We have no known issues with Windows 8, and yes in the video the OS was most likely Windows 7.
              Devin Kendig
              Developer
                caecarvalho
                Hi devin, thanks for the reply.
                I think I found what was causing the memory crash.The file that was crashing had lots of ligths(spots and rectangular) from vray 1.49.01.
                I tryed to render another file that I have, almost the same size as the one that was crashing(65MB), but with no ligths, only the phisical sun and sky,and high quality settings, and there was no crash. Actually the render was faster and had better image quality with same settings that 1.49.01.
                So it seems that the lights, at least rectangular and spots are not fully compatible.
                I had no time to change all the ligths from the other file,to do a new test, but as soon as I can I'll post the results here.
                Other issue is that the RT is not updating the sun and sky position, but materials and camera are updating fine.
                About the bug reports, I think there was a post already in this thread saying that an error occurs when trying to send it.That's happening with me as well.
                • dkendigD Offline
                  dkendig
                  the post I made about sending bug reports says the bug reporting tool isn't working well at the moment for some people, so email is the best way to submit a report to our bug tracker. SketchUcation is NOT the place to report bugs for our product if you want us to actually fix them. We also don't want bug reports in the Chaos Group forums. Forums are a horrible place to sort out bugs. Threads get sidetracked/lost/confusing... oh it's a nightmare! So please send us an email with bug reports. If you want to give fellow VfS users a heads up about a problem, and discuss a bug on the forums, by all means, go ahead. If you're trying to tell myself, or Joe (the other VfS developer) about a bug, we need a bug report or else more than likely it's going to be lost. The email address for bug reports is vfswip@chaosgroup.com
                  Devin Kendig
                  Developer
                    caecarvalho
                    I didn't know obout the e-mail adress, sorry. I'll send the bug reports to it than...Thanks
                    • dkendigD Offline
                      dkendig
                      no worries, I just wanted to stress the importance of it. In the past we have had a very confusing mix of feedback sources, which ended up wasting a lot of time. We want to really tear through this beta at the highest efficiency that we can.
                      Devin Kendig
                      Developer
                      • jiminy-billy-bobJ Offline
                        jiminy-billy-bob
                        By the way, will there be multiple beta releases during these three months, or do you plan to adress all the bugs for the future proper release ?
                        • dkendigD Offline
                          dkendig
                          there will be multiple beta releases prior to a final release.
                          Devin Kendig
                          Developer
                          • kaluK Offline
                            kalu
                            Thank you for all your comments and help "dkendig".
                            Kalu. 😎
                            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                            • dkendigD Offline
                              dkendig
                              glad I can help. Sorry I'm not able to be on here more often. We have a bit of work ahead of us yet. Keep the comments and reports coming though! They are a huge help!
                              Devin Kendig
                              Developer
                                jiminy-billy-bob
                                I think we all prefer you working on the next beta release than lurking SCF all day long ! πŸ˜„
                                  lcarlin247
                                  I am going crazy, i just installed the new vray for sketchup 1.6 beta, and every time that i apply a material on a surface the bugsplat screen appears, does anyone know why is this happening??
                                    Do you have any other render engines installed?
                                    • holmes1977H Offline
                                      holmes1977
                                      Yup me to on my Home Laptop, I deleted everything, plugins the works. Then installed SU 2013 and Vray Beta 1.6 and the same problem happened. Crazy thing is its not happening on my work computer. Ive sent a bug report.
                                      Exaggeration makes a dull story better.
                                      • andybotA Offline
                                        andybot
                                        There's a very painful bug with SU8 where some materials applied from the SU material palette cause an immediate bugsplat. SU7 and SU2013 do not have this problem.
                                        One way to avoid the problem is to right click on the material and select the option "add to model", then you can use the material.
                                          @andybot said:
                                          There's a very painful bug with SU8 where some materials applied from the SU material palette cause an immediate bugsplat. SU7 and SU2013 do not have this problem. Not in SU7? Are you sure?
                                            holmes1977
                                            Oh yes they do. Read my post above. I did a clean sweep, installed 2013 and no other plugins other than Vray. I just can't seem to fix it. I've tried alsorts of things.
                                            • 2 / 5
