    Vray 1.6 open beta
    renderpluginsextensions
    94 Posts 28 Posters 27.9k Views 28 Watching
    • dkendigD Offline
      dkendig
      there will be multiple beta releases prior to a final release.
      Devin Kendig
      Developer
      • kaluK Offline
        kalu
        Thank you for all your comments and help "dkendig".
        Kalu. 😎
        THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        • dkendigD Offline
          dkendig
          glad I can help. Sorry I'm not able to be on here more often. We have a bit of work ahead of us yet. Keep the comments and reports coming though! They are a huge help!
          Devin Kendig
          Developer
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            I think we all prefer you working on the next beta release than lurking SCF all day long ! πŸ˜„
              lcarlin247
              I am going crazy, i just installed the new vray for sketchup 1.6 beta, and every time that i apply a material on a surface the bugsplat screen appears, does anyone know why is this happening??
                Do you have any other render engines installed?
                • holmes1977H Offline
                  holmes1977
                  Yup me to on my Home Laptop, I deleted everything, plugins the works. Then installed SU 2013 and Vray Beta 1.6 and the same problem happened. Crazy thing is its not happening on my work computer. Ive sent a bug report.
                  Exaggeration makes a dull story better.
                  • andybotA Offline
                    andybot
                    There's a very painful bug with SU8 where some materials applied from the SU material palette cause an immediate bugsplat. SU7 and SU2013 do not have this problem.
                    One way to avoid the problem is to right click on the material and select the option "add to model", then you can use the material.
                      @andybot said:
                      There's a very painful bug with SU8 where some materials applied from the SU material palette cause an immediate bugsplat. SU7 and SU2013 do not have this problem. Not in SU7? Are you sure?
                        holmes1977
                        Oh yes they do. Read my post above. I did a clean sweep, installed 2013 and no other plugins other than Vray. I just can't seem to fix it. I've tried alsorts of things.
                        • andybotA Offline
                          andybot
                          Dunno, I've tried it with both SU7 and SU2013. I get crashes in 2013, but not consistently like with SU8. As in, I can apply a material from the SU palette and it doesn't crash immediately like with SU8. However, I gave up on 2013. I was getting all sorts of random crashes. I have actual work to do, so I removed 2013, I just don't have time to deal with this $h!t
                          • andybotA Offline
                            andybot
                            There was a discussion thread with dkendig and valerostudio on the CG forum a little while back where this was elaborated on. For whatever reason, this error surfaced in SU8 only.
                            • dkendigD Offline
                              dkendig
                              It was a SU observer bug. The Maxwell guys actually reported it before I was able to, but I did give them a high five for reporting it.
                              Devin Kendig
                              Developer
                              • H Offline
                                hussy
                                Vray 1.6 is good..
                                but whenever i start sketchup it produce bug splat .. 😞
                                without vray 1.6 it works fine
                                .. please some one help
                                • dkendigD Offline
                                  dkendig
                                  sounds like a faulty install. Be sure that SketchUp and XMLDRSpawner processes are not running when you try to install the 1.6 beta. Also be sure that the license server isn't running. DO NOT UNCHECK ANYTHING when installing the 1.6 beta, and if you are prompted to restart at any point during the installation, do so immediately, do not click "No" and continue the installation. After the restart you will need to run the installer again most likely, because Windows had to remove some files that were locked during the attempted uninstall process.
                                  Devin Kendig
                                  Developer
                                    petrusyap
                                    @andybot said:
                                    @anteolic said:
                                    I really dont know where to ask this question than i ask here.
                                    Does vrayforsu 1.6 beta has some limitation or what cause i cant get more prepass in IRRADIANCE MAP than just one.
                                    There's an option for "multi-pass" (under "advanced options") If it's unchecked, you will only see one pass even though it is doing all the calculations. See if that is the case.
                                    Correct me if I am wrong. So you mean we have to uncheck the Multipass option when doing render to ensure multi prepass in IR?
                                    • andybotA Offline
                                      andybot
                                      No, AFAIK that button only affects what you see in the render window, not what is going on "behind the scenes"
                                        petrusyap
                                        I found out, if we previously render using RT, after we back to the usual common render processing, the multi prepass won't process more than 1 prepass. If wanna have prepass rendering processing again, we have to reset the rendering option.
                                        • kaluK Offline
                                          kalu
                                          So Vray 1.6 doesen't work in Sketchup Pro 2013. Do I may have to wait? What I should do?
                                          Thanks.
                                          • dkendigD Offline
                                            dkendig
                                            Thanks.
                                            We developed this beta, using the SketchUp 2013 Beta on one development machine, and SketchUp 8 on another. We should be 100% compatible with both versions.
                                            Devin Kendig
                                            Developer
                                            • 4 / 5
