    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 444.8k Views 80 Watching
      Anton_S
      @jorge2011 said:
      thanks for this update.
      A small error.
      In option: Owned Popups - "Show / Hide" does not work correctly.
      When you hide and show, the windows can not be uncoupled and refitted.
      The issue was already reported, and I don't seem to have success in fixing it πŸ˜’
      Working on it.. πŸ€“
        jorge2011
        sorry, but that option is the same option of the menu: Window> hide dialog boxes?
        in your plugin is just adding an access to this function. no?
        • renderizaR Offline
          renderiza
          This is awesome! I am soon to be finishing another of my plugins called "Key Scene" and this will greatly enhance it...Thank you so much!
          Renderiza
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            matt.gordon320
            Anton, this is amazingly helpful! I teach Sketchup as well as being a heavy user in Architecture, and I do a lot of screencasts for my students. I got really tired of turning all my plugins off and moving my toolbars all over whenever I had to record. Now, I don't ever have to again!
            Just wanted to say a VERY sincere thanks, you've saved me hours and hours of tedious work that goes completely unnoticed to everyone but me πŸ˜„
              Pete
              I am really benefiting from using this plugin!! I really appreciate the work you are doing!! Thank you for sharing.
              Here is an idea for a feature: can the dialog height for the component options window be overridden to use the entire height of the screen above the windows task bar?
              Demonstration:
              http://www.youtube.com/watch?v=vtWd1cb2ee4
                Anton_S
                Hello Pete,
                Component Options is a tool, written by Google SketchUp. I honestly have no rights modifying the way its dialog interacts. Change it would probably end me in the SketchUp jail, well, unless I already violated enough dialogs. πŸ˜’ It would be great if you post your suggestion to the SU Wishes or somewhere in that category, they'd probably be convinced with it πŸ˜‰
                πŸ’š
                • CadFatherC Offline
                  CadFather
                  on the other hand, i guess you could use winsize (it's a must for windows users anyway)
                  http://winsize2.sourceforge.net/en/index.html
                  the drawback is that it resizes a window by its name, so if you have the palette called 'components',
                  and you set it to 900x500 pixels, that will also resize the window's folder by the same name when you are browsing in explorer.
                    Pete
                    CadFather, winsize is doing just what I want!! Thank you.
                    In case someone has a native SketchUp way to do this I have moved this discussion to http://sketchucation.com/forums/viewtopic.php?f=289&t=52060
                      Anton_S
                      Version 2.0.1 ( May 8, 2013 )
                      • Added show/hide/close dialogs and floating toolbars
                      • Added set menubar on close checkbox option
                      • ~Fixed the corrupted window bug, after show hidden popups; now windows can be connected, uncoupled and refitted.
                      • Stabilized the css file.
                      • Extended title text features, added onCaptionChanged observer.
                      • Optimized script
                      See first post πŸ˜‰
                        JuanV.Soler
                        Hi Anton_S ,
                        I am not able anymore to keep retain or save the settings with this new upgrade 😞
                        thanks for this fantastic plugin
                          Anton_S
                          Version 2.0.2 ( May 9, 2013 )
                          • Fixed retain button and save_settings function
                            JuanV.Soler
                            yes Β‘ πŸ‘ πŸ‘ πŸ‘
                            thanks πŸ˜„
                              CadFather
                              Thank You! this is one of those i can't do without... makes all my mac friends just a bit sad.. πŸ’š
                              • Gus RG Offline
                                Gus R
                                • Optimized script
                                See first post πŸ˜‰
                                Just discovered this plugin thanks to the update. This is really nice Anton. πŸ‘
                                www.instagram.com/gusrobatto/
                                www.facebook.com/gusrobatto
                                  Anton_S
                                  Yep, I just changed the subject plugin from SU Window Settings to Sketchup FullScreen so that it describes the right way.
                                    This is one of those essentials for SketchUp
                                    Anton deserves some PayPal karma for this plugin.
                                    The latest version is a winner. Well done
                                    • W Offline
                                      wsxqaz
                                      How do you do! This how do localization into Chinese, I can't find the related file that is the correct fileζœͺ命名.jpg
                                      • cmeedC Offline
                                        cmeed
                                        This looks like a great help - An idea struck me - there is only so much screen space, Su is very plugin dependent and su is so versatile, it got me thinking - does su let you extend this plugin so you could customise your work area by displaying certain tool pallettes/windows for certain jobs....much like photoshop does
                                        example
                                        custom arrangement1 - Job:organic modelling - vertex tools, artisan- are open
                                        custom arrangement 2 - Job:working in 2d - 2d tools- are open
                                        just a thought...
                                        c
                                          Anton_S
                                          I guess you want the Chinese translation, right?
                                          I will add it in the newer version πŸ˜„ ❗
                                            Anton_S
                                            example
                                            just a thought...
                                            Hmm, so you want to have different project panels? Great Idea!!! πŸ‘ I will have to think about that...
                                            Maybe this idea may be incorporated into SketchUcation Plugin Store by Rich O Brien. His plugins manager allows you to enable/disable certain plugins. Maybe Rich could add custom arrangement templates. πŸŽ‰
                                            • 14
                                            • 15
                                            • 4 / 15
