    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      matt.gordon320
      Anton, this is amazingly helpful! I teach Sketchup as well as being a heavy user in Architecture, and I do a lot of screencasts for my students. I got really tired of turning all my plugins off and moving my toolbars all over whenever I had to record. Now, I don't ever have to again!
      Just wanted to say a VERY sincere thanks, you've saved me hours and hours of tedious work that goes completely unnoticed to everyone but me πŸ˜„
      • P
        Pete
        I am really benefiting from using this plugin!! I really appreciate the work you are doing!! Thank you for sharing.
        Here is an idea for a feature: can the dialog height for the component options window be overridden to use the entire height of the screen above the windows task bar?
        Demonstration:
        http://www.youtube.com/watch?v=vtWd1cb2ee4
          Anton_S
          Hello Pete,
          Component Options is a tool, written by Google SketchUp. I honestly have no rights modifying the way its dialog interacts. Change it would probably end me in the SketchUp jail, well, unless I already violated enough dialogs. πŸ˜’ It would be great if you post your suggestion to the SU Wishes or somewhere in that category, they'd probably be convinced with it πŸ˜‰
          πŸ’š
          • CadFatherC
            CadFather
            on the other hand, i guess you could use winsize (it's a must for windows users anyway)
            http://winsize2.sourceforge.net/en/index.html
            the drawback is that it resizes a window by its name, so if you have the palette called 'components',
            and you set it to 900x500 pixels, that will also resize the window's folder by the same name when you are browsing in explorer.
            • P
              Pete
              CadFather, winsize is doing just what I want!! Thank you.
              In case someone has a native SketchUp way to do this I have moved this discussion to http://sketchucation.com/forums/viewtopic.php?f=289&t=52060
                Anton_S
                Version 2.0.1 ( May 8, 2013 )
                • Added show/hide/close dialogs and floating toolbars
                • Added set menubar on close checkbox option
                • ~Fixed the corrupted window bug, after show hidden popups; now windows can be connected, uncoupled and refitted.
                • Stabilized the css file.
                • Extended title text features, added onCaptionChanged observer.
                • Optimized script
                See first post πŸ˜‰
                  JuanV.Soler
                  Hi Anton_S ,
                  I am not able anymore to keep retain or save the settings with this new upgrade 😞
                  thanks for this fantastic plugin
                    Anton_S
                    Version 2.0.2 ( May 9, 2013 )
                    • Fixed retain button and save_settings function
                      JuanV.Soler
                      yes Β‘ πŸ‘ πŸ‘ πŸ‘
                      thanks πŸ˜„
                      • CadFatherC
                        CadFather
                        Thank You! this is one of those i can't do without... makes all my mac friends just a bit sad.. πŸ’š
                        • Gus RG
                          Gus R
                          • Optimized script
                          See first post πŸ˜‰
                          Just discovered this plugin thanks to the update. This is really nice Anton. πŸ‘
                          www.instagram.com/gusrobatto/
                          www.facebook.com/gusrobatto
                            Anton_S
                            Yep, I just changed the subject plugin from SU Window Settings to Sketchup FullScreen so that it describes the right way.
                              This is one of those essentials for SketchUp
                              Anton deserves some PayPal karma for this plugin.
                              The latest version is a winner. Well done
                              • W
                                wsxqaz
                                How do you do! This how do localization into Chinese, I can't find the related file that is the correct fileζœͺ命名.jpg
                                • cmeedC
                                  cmeed
                                  This looks like a great help - An idea struck me - there is only so much screen space, Su is very plugin dependent and su is so versatile, it got me thinking - does su let you extend this plugin so you could customise your work area by displaying certain tool pallettes/windows for certain jobs....much like photoshop does
                                  example
                                  custom arrangement1 - Job:organic modelling - vertex tools, artisan- are open
                                  custom arrangement 2 - Job:working in 2d - 2d tools- are open
                                  just a thought...
                                  c
                                    Anton_S
                                    I guess you want the Chinese translation, right?
                                    I will add it in the newer version πŸ˜„ ❗
                                      Anton_S
                                      example
                                      just a thought...
                                      Hmm, so you want to have different project panels? Great Idea!!! πŸ‘ I will have to think about that...
                                      Maybe this idea may be incorporated into SketchUcation Plugin Store by Rich O Brien. His plugins manager allows you to enable/disable certain plugins. Maybe Rich could add custom arrangement templates. πŸŽ‰
                                      • cmeedC
                                        cmeed
                                        I didn't know about richs' I'll take a look.
                                        cheers
                                        c
                                        • U
                                          unearthed
                                          Hi Anton,
                                          Seconding the profiles idea: I'd use a stripped-to-nothing profile for online live-model presentations, and a normal modelling profile.
                                          Growplan - People ∩ Plants ∩ Place
                                          windows 7 64b, 4GB RAM, SU 8.0.16846
                                          Gimp, QGIS, Vectorworks 12, Bricscad 11
                                          • U
                                            unearthed
                                            Thank again - that's a very time-saving plugin, and it doesn't seem to mess up my normal toolbar/menu settings.
                                            • 14
                                            • 15
                                            • 4 / 15
