    [Plugin] Front Face - 1.2
    57 Posts 29 Posters 88.4k Views 29 Watching
      Jrudd
      Hi all,
      Proud to announce that there is finally a solution to the face flipping problem. You can now reverse faces and preserve UV coordinates! I tested it and the results are accurate!
      The UV Toolkit makes it possible. You also need to download the TT_Lib and put it in your plugins folder.
      To reverse a face, first select what you want reversed, then go to Plugins > UV Toolkit > Frontface material to Backface (or the opposite).
      Hope it helps,
      Jeremy
        simoni
        I find it works 50% of the time, sometimes textures are mapped wrongly, maybe I am doing something wrong?
        • N
          Need2SeeAttachments
          LOOK AT MY USER NAME, ENOUGH SAID. Need2SeeAttachments.
          I WANT TO DOWNLOAD, NOW BYE FOREVER SKETCHUCATION.
          Meant no offence, k thx bai.
            Bye bye.
              desunvn
              Thank you for plugin this
              • danchoD
                dancho
                Hi Tomasz,
                I was installed Fredo Additional Plugin folder plugin http://sketchucation.com/forums/viewtopic.php?p=345150#p345150
                and have a problem with finding icons if I use your plugin in another dir.
                Its only work with Sketchup 2013/Plugins place. Can you look at this?
                Regards,
                Daniel
                  @dancho said:
                  Hi Tomasz,
                  Regards,
                  Daniel
                  This is an old script...
                  You are unlikely to get it chnaged now...
                  BUT you can adjust the tool's code yourself.
                  It is quite easy...
                  Open the file frontface.rb using Notepad, or another plain text editor like Notepad++ - BUT NEVER USE a word-processor!
                  Near the beginning there are three lines that setup the button icons [#36/40/44]
                  The first line reads:
                  cursor_path = Sketchup.find_support_file("FrontFaceCursor.png", "Plugins/FrontFace_files")
                  You must rewrite it to read:
                  cursor_path = File.join(File.dirname(__FILE__), "FrontFace_files", "FrontFaceCursor.png")
                  so it now looks in a folder named FrontFace_files that is in the folder with the .rb file [wherever that is located], rather than always the main Plugins folder as the original code sets.
                  The other two entries for cursor_path = need to be similarly recast, using: FrontFaceCursorOff and FrontFace_OnDef for the .png respectively...
                  • danchoD
                    dancho
                    Hi TIG,
                    thanks for help, I do it like you wrote
                    class FrontFaceTool
                    def initialize
                    @ip = Sketchup::InputPoint.new
                    cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFaceCursor.png"
                    if cursor_path
                    	@cursor_on = UI.create_cursor(cursor_path, 12, 12)
                    cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFaceCursorOff.png"
                    if cursor_path
                    	@cursor_off = UI.create_cursor(cursor_path, 12, 12)
                    cursor_path = File.join(File.dirname(__FILE__) ,"FrontFace_files","FrontFace_OnDef.png"
                    if cursor_path
                    	@cursor_on_def= UI.create_cursor(cursor_path, 12, 12)
                    and receive this error message, have you any idea?
                    THX
                    Dancho
                      You have mistyped.
                      It should be:
                      cursor_path = File.join(File.dirname(__FILE__), "FrontFace_files", "FrontFaceCursor.png"**)**
                      The error message tells you the error...
                      Add the final ) to the three lines and it will work OK...
                        samothrace41
                        A great THANK YOU Tomasz !!!
                          A Former User
                          Is the current FaceFront ruby current with SU 2015 version? I downloaded it and installed it in my Plug in file but it doesn't show up. Any thoughts
                            Hi Tom,
                            Small world. πŸ˜‰
                            So did you try installing it with the SCF PluginStore plugin? Or did you download the file as .rbz from here?
                            • 3 / 3
