    New rendering plugin
    30 Posts 10 Posters 3.1k Views 10 Watching
      mics_54
      Maybe...but for now I can put lipstick on all my pigs.
      I have been playing with kerkythea too....but I like working inside SUjust a doodle.not bad for 60 secondswith adaptive antialiasing  selected
      • BoxB
        I couldn't resist the cube's cube.
        In fact, resistance was futile.
        • Didier BurD
          Didier Bur
          @mics_54:Thanks for the head up.
          But I cannot install it! When running setup.exe (with admin privileges) this message pops up:
          I'm running Windows 7 ... 😲
          Anyone else encountered this ?
          DB
            mics_54
            no, sorry I didn't have that issue.
            I didn't recall seeing any thing on his forum about it.
            • KrisidiousK
              Krisidious
              Didier... If you don't know what's going on then who the hell does?
              this might help?
              http://www.brighter3d.com/windows-xp-support/
              By: Kristoff Rand
              • BoxB
                Ask in the brighter forum, they are very good at responding.
                I've had a long chat via email with them.
                • Mistro11M
                  Mistro11
                  I only have Windows XP and hope they support it soon.
                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                  • Didier BurD
                    Didier Bur
                    I recommend everyone to test and use the plugin. The staff at Brighter3d sent me very quickly an installer which does not check the Win version, they are very aware of problems when you post at their forum.
                    DB
                      Does it exact that maxi is 800 x 450 pixels ?
                      • Didier BurD
                        Didier Bur
                        @Pilou: Yes 800x450 (16:9) is the max 😞
                        Higher resolutions will be payware I guess.
                        But the plugin is simple, easy to use, and quite fast at renderings
                        DB
                        • BoxB
                          From what I understand, the plugin is still being developed so max res is bound to change.
                          But it is simple to use and blindingly fast and well worth helping to develop further, even at this stage it is a very useful tool for creating quick well rendered sketches totally within sketchup.
                          • Didier BurD
                            Didier Bur
                            @Box: +1
                            It seems to have some problems with FaceMe components that use PNG images (see trees in the background). Pixels that are totally transparent are not rendered as such.
                            Be careful with smoothed faces too (see black areas at the roof top). But maybe it's just my render settings that must be fine tuned.
                            DB
                              Could it be that you where running in Compatibility Mode?
                              • Didier BurD
                                Didier Bur
                                @thomthom: Good point. Stupid me...
                                DB
                                • BoxB
                                  Just posting this to show how a very quick sketch can look without any fiddling about.
                                  And I'm a total novice at rendering.
                                  Model took about 30min (already had the cello), and render time about a minute.
                                    mics_54
                                    do you have glass in the window?
                                    I haven't been able to get any transparencies to work..yet
                                    • BoxB
                                      No, no glass, he's still working on transparent and translucent.
                                        mics_54
                                        it doesn't support layers either... hide what you do want visible
                                        • 2 / 2
