    New rendering plugin
    30 Posts 10 Posters 2.6k Views 10 Watching
    • dukejazzD Offline
      dukejazz
      Hey every one
      Use brightness material for lighting
      This is what I get when I move my mouse wheel durring rendering it works
      brightness
      Where you should go for help.
      http://www.brighter3d.com/start/
      • KrisidiousK Offline
        Krisidious
        I could have sworn I had sketchup turned off when I installed. But apparently not as that seemed to do the trick.
        By: Kristoff Rand
          Krisidious
          Test run... Seems very powerful.
          By: Kristoff Rand
          • BoxB Offline
            It's nice and simple, very quick, but it has a few bugs.
            As a render virgin I didn't have much trouble getting the basics working.
            Certainly made it easy to give my Av a very different look.
            • mitcorbM Offline
              mitcorb
              Perhaps this new discovery should be added to this topic/ thread:
              http://sketchucation.com/forums/viewtopic.php?f=81&t=3220#p15472
              Just a thought...
                Krisidious
                I added a note to that thread.
                By: Kristoff Rand
                  Krisidious
                  I guess they'll be charging later and thus the rather small renderings.
                  By: Kristoff Rand
                    mics_54
                    Maybe...but for now I can put lipstick on all my pigs.
                    I have been playing with kerkythea too....but I like working inside SUjust a doodle.not bad for 60 secondswith adaptive antialiasing  selected
                    • BoxB Offline
                      I couldn't resist the cube's cube.
                      In fact, resistance was futile.
                      • Didier BurD Offline
                        Didier Bur
                        @mics_54:Thanks for the head up.
                        But I cannot install it! When running setup.exe (with admin privileges) this message pops up:
                        I'm running Windows 7 ... 😲
                        Anyone else encountered this ?
                        DB
                          mics_54
                          no, sorry I didn't have that issue.
                          I didn't recall seeing any thing on his forum about it.
                            Krisidious
                            Didier... If you don't know what's going on then who the hell does?
                            this might help?
                            http://www.brighter3d.com/windows-xp-support/
                            By: Kristoff Rand
                            • BoxB Offline
                              Ask in the brighter forum, they are very good at responding.
                              I've had a long chat via email with them.
                              • Mistro11M Offline
                                Mistro11
                                I only have Windows XP and hope they support it soon.
                                i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                  Didier Bur
                                  I recommend everyone to test and use the plugin. The staff at Brighter3d sent me very quickly an installer which does not check the Win version, they are very aware of problems when you post at their forum.
                                  DB
                                    Does it exact that maxi is 800 x 450 pixels ?
                                      Didier Bur
                                      @Pilou: Yes 800x450 (16:9) is the max 😞
                                      Higher resolutions will be payware I guess.
                                      But the plugin is simple, easy to use, and quite fast at renderings
                                      DB
                                      • BoxB Offline
                                        From what I understand, the plugin is still being developed so max res is bound to change.
                                        But it is simple to use and blindingly fast and well worth helping to develop further, even at this stage it is a very useful tool for creating quick well rendered sketches totally within sketchup.
                                          Didier Bur
                                          @Box: +1
                                          It seems to have some problems with FaceMe components that use PNG images (see trees in the background). Pixels that are totally transparent are not rendered as such.
                                          Be careful with smoothed faces too (see black areas at the roof top). But maybe it's just my render settings that must be fine tuned.
                                          DB
                                            Could it be that you where running in Compatibility Mode?
