    New rendering plugin
    30 Posts 10 Posters 3.1k Views 10 Watching
      mics_54
      I downloaded and installed it... the toolbar and menu items show up but do nothing
      http://www.brighter3d.com/start/
      I had to follow that short instructional.
      • dukejazzD
        dukejazz
        Hey every one
        Use brightness material for lighting
        This is what I get when I move my mouse wheel durring rendering it works
        brightness
        Where you should go for help.
        • KrisidiousK
          Krisidious
          I could have sworn I had sketchup turned off when I installed. But apparently not as that seemed to do the trick.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            Test run... Seems very powerful.
            By: Kristoff Rand
            • BoxB
              It's nice and simple, very quick, but it has a few bugs.
              As a render virgin I didn't have much trouble getting the basics working.
              Certainly made it easy to give my Av a very different look.
              • mitcorbM
                mitcorb
                Perhaps this new discovery should be added to this topic/ thread:
                404 Not Found
                (sketchucation.com)
                Just a thought...
                • KrisidiousK
                  Krisidious
                  I added a note to that thread.
                  By: Kristoff Rand
                  • KrisidiousK
                    Krisidious
                    I guess they'll be charging later and thus the rather small renderings.
                    By: Kristoff Rand
                      mics_54
                      Maybe...but for now I can put lipstick on all my pigs.
                      I have been playing with kerkythea too....but I like working inside SUjust a doodle.not bad for 60 secondswith adaptive antialiasing  selected
                      • BoxB
                        I couldn't resist the cube's cube.
                        In fact, resistance was futile.
                        • Didier BurD
                          Didier Bur
                          @mics_54:Thanks for the head up.
                          But I cannot install it! When running setup.exe (with admin privileges) this message pops up:
                          I'm running Windows 7 ... 😲
                          Anyone else encountered this ?
                          DB
                            mics_54
                            no, sorry I didn't have that issue.
                            I didn't recall seeing any thing on his forum about it.
                            • KrisidiousK
                              Krisidious
                              Didier... If you don't know what's going on then who the hell does?
                              this might help?
                              http://www.brighter3d.com/windows-xp-support/
                              By: Kristoff Rand
                              • BoxB
                                Ask in the brighter forum, they are very good at responding.
                                I've had a long chat via email with them.
                                • Mistro11M
                                  Mistro11
                                  I only have Windows XP and hope they support it soon.
                                  Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                  • Didier BurD
                                    Didier Bur
                                    I recommend everyone to test and use the plugin. The staff at Brighter3d sent me very quickly an installer which does not check the Win version, they are very aware of problems when you post at their forum.
                                    DB
                                      Does it exact that maxi is 800 x 450 pixels ?
                                      • Didier BurD
                                        Didier Bur
                                        @Pilou: Yes 800x450 (16:9) is the max 😞
                                        Higher resolutions will be payware I guess.
                                        But the plugin is simple, easy to use, and quite fast at renderings
                                        DB
                                        • BoxB
                                          From what I understand, the plugin is still being developed so max res is bound to change.
                                          But it is simple to use and blindingly fast and well worth helping to develop further, even at this stage it is a very useful tool for creating quick well rendered sketches totally within sketchup.
                                          • Didier BurD
                                            Didier Bur
                                            @Box: +1
                                            It seems to have some problems with FaceMe components that use PNG images (see trees in the background). Pixels that are totally transparent are not rendered as such.
                                            Be careful with smoothed faces too (see black areas at the roof top). But maybe it's just my render settings that must be fine tuned.
                                            DB
