    New rendering plugin
    30 Posts 10 Posters 2.0k Views 10 Watching
      mics_54
      no, sorry I didn't have that issue.
      I didn't recall seeing any thing on his forum about it.
      • KrisidiousK Offline
        Krisidious
        Didier... If you don't know what's going on then who the hell does?
        this might help?
        404 – Oops! You’re lost | Brighter3D
        (www.brighter3d.com)
        By: Kristoff Rand
        • BoxB Offline
          Ask in the brighter forum, they are very good at responding.
          I've had a long chat via email with them.
          • Mistro11M Offline
            Mistro11
            I only have Windows XP and hope they support it soon.
            i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
            Structural Integrity is Not Just Physical...It's in the Design and Purpose
            • Didier BurD Offline
              Didier Bur
              I recommend everyone to test and use the plugin. The staff at Brighter3d sent me very quickly an installer which does not check the Win version, they are very aware of problems when you post at their forum.
              DB
                Does it exact that maxi is 800 x 450 pixels ?
                  Didier Bur
                  @Pilou: Yes 800x450 (16:9) is the max 😞
                  Higher resolutions will be payware I guess.
                  But the plugin is simple, easy to use, and quite fast at renderings
                  DB
                  • BoxB Offline
                    From what I understand, the plugin is still being developed so max res is bound to change.
                    But it is simple to use and blindingly fast and well worth helping to develop further, even at this stage it is a very useful tool for creating quick well rendered sketches totally within sketchup.
                      Didier Bur
                      @Box: +1
                      It seems to have some problems with FaceMe components that use PNG images (see trees in the background). Pixels that are totally transparent are not rendered as such.
                      Be careful with smoothed faces too (see black areas at the roof top). But maybe it's just my render settings that must be fine tuned.
                      DB
                        @didier bur said:
                        @mics_54:Thanks for the head up.
                        But I cannot install it! When running setup.exe (with admin privileges) this message pops up:
                        I'm running Windows 7 ... 😲
                        Anyone else encountered this ?
                        Could it be that you where running in Compatibility Mode?
                          Didier Bur
                          @thomthom: Good point. Stupid me...
                          DB
                          • BoxB Offline
                            Just posting this to show how a very quick sketch can look without any fiddling about.
                            And I'm a total novice at rendering.
                            Model took about 30min (already had the cello), and render time about a minute.
                              mics_54
                              do you have glass in the window?
                              I haven't been able to get any transparencies to work..yet
                              • BoxB Offline
                                No, no glass, he's still working on transparent and translucent.
                                  mics_54
                                  it doesn't support layers either... hide what you do want visible
                                  • 2 / 2
